Engineering Solutions
Output Blocks entityOutputBlocks-24
Previous topic Next topic Expand/collapse all hidden text
Output block entities are used to define and store solver output requests.  Output blocks are shown under the OutputBlock folder within the Model browser.
Output blocks do not have a display state.
Output blocks have an active and export state.  The active state of an output block controls the listing of the output block in the Model browser and any of its views.  If an output block entity is active, then it is listed in the Model browser and any of its views.  If an output block entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of an output block entity controls whether or not that set is exported when the custom export option is utilized.  The all export option is not affected by the export state of a output block.  The active and export states of output block entities can be controlled using the Entity State browser.
The data names associated with output blocks can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit output blocks:
Output Block
Solver Card Support for Output Blocks
hmtoggle_arrow1RADIOSS
The supported RADIOSS cards in RADIOSS 100 are listed below. You can quickly create these cards by right-clicking in the Solver browser and selecting Create Cards.
Supported Card
Solver Description
Supported Parameters
Notes
/TH/ACCEL/
Describes the time history - Accelerometer
NUM_VARIABLES
Var
Keyword (ACCEL, SECTIO)
RADIOSS_COMMENT_FLAG
Options to assign ATH...ITH
/TH/BEAM/
Describes the time history - Beams
/TH/BRIC/
Describes the time history - Solids
/TH/CYL_JO/
Describes the time history - Cylindrical joints
/TH/FRAME/
Describes the time history - Frame
NUM_VARIABLES
Var
/TH/GAUGE
Describes the time history for gauges.
/TH/INTER/
Describes the time history - Interface
NUM_VARIABLES
Var
Keyword (INTER, RWALL)
/TH/MONVOL/
Describes the time history - Monitored volume and Airbag
NUM_VARIABLES
Var
/TH/NODE/
Describes the time history - Nodes
NUM_VARIABLES
lskew
NODname
/TH/QUAD/
Describes the time history - 2D quads
/TH/PART/
Describes the time history - Parts
NUM_VARIABLES
lskew
Var
/TH/RBODY/
Describes the time history - Rigid body
/TH/RWALL/
Describes the time history - Rigid wall
NUM_VARIABLES
Var
/TH/SECTIO/
Describes the time history - Section
NUM_VARIABLES
Var
/TH/SH3N/
Describes the time history - 3 node shells
/TH/SHEL/
Describes the time history - 4 node shells
NUM_VARIABLES
Var
ElName
/TH/SPHCEL/
Describes the SPH cell output to time history.
/TH/SPRING/
Describes the time history - Springs
/TH/SUBS/
Describes the time history - Subsets
NUM_VARIABLES
Var
/TH/TRUSS/
Describes the time history - Trusses
hmtoggle_arrow1OptiStruct
Supported Card
Solver Description
Notes
XHIST
DEF
ACCE
VR
AR
XYZ
hmtoggle_arrow1Abaqus
An output block is a repository for output requests.  Output blocks are added to load steps (*STEP) from the Load Steps panel.  Output requests organized into the output blocks are written out within the corresponding step definition in the Abaqus input deck.  It is recommended that all output requests be defined from the Step Manager in the Abaqus user profile.
Supported Card
Solver Description
Notes
*CONTACT FILE
Define results file requests for contact variables
NSET
FREQUENCY
MASTER
SLAVE
*CONTACT OUTPUT
Specify contact variables to be written to the output database
NSET
MASTER
SLAVE
VARIABLE = {ALL, PRESELECT}
CPSET
GENERAL CONTACT
*CONTACT PRINT
Define print requests for contact variables
NSET
FREQUENCY
*EL FILE
Define results file requests for element variables
ELSET
FREQUENCY
POSITION = {NODES, AVERAGED AT NODES, CENTROIDAL, INTEGRATION POINTS}
DIRECTIONS
LAST MODE
MODE
REBAR
*EL PRINT
Define data file requests for element variables
ELSET
FREQUENCY
SUMMARY
TOTALS
LAST MODE
MODE
*ELEMENT OUTPUT
Define output database requests for element variables
DIRECTION
ELSET
POSITION = {NODES, CENTROIDAL, INTEGRATION POINTS}
*ENERGY FILE
Write energy output to the results file
ELSET
FREQUENCY
*ENERGY OUTPUT
Define output database requests for whole model or element set energy data
ELSET
*ENERGY PRINT
Print a summary of the total energies
NSET
FREQUENCY
MASTER
SLAVE
SUMMARY
TOTAL
*INCREMENTATION OUTPUT
Define output database requests for time incrementation data
VARIABLE = {ALL/PRESELECT}
Explicit template only. History data. Only for *OUTPUT, HISTORY.
*INTEGRATED OUTPUT
Specify variables integrated over a surface to be written to the output database
SECTION
SURFACE
*MODAL OUTPUT
Write generalized coordinate (modal amplitude) data to the output database during a mode-based dynamic or complex eigenvalue extraction procedure
VARIABLE = ALL
Standard 2D and 3D templates only. History data. Only for *OUTPUT, HISTORY.
*NODE FILE
Define results file requests for nodal data
NSET
FREQUENCY
GLOBAL
LAST MODE
MODE
*NODE OUTPUT
Define output database requests for nodal data
NSET
GLOBAL
*NODE PRINT
Define print requests for nodal variables
NSET
FREQUENCY
GLOBAL
LAST MODE
MODE
SUMMARY
TOTALS
*OUTPUT
Define output requests to the output database
FIELD
HISTORY
OP
VARIABLE
FREQUENCY
TIME MARKS
TIME INTERVAL
NUMBER INTERVAL
MODE LIST
FILTER
NAME
Note:Output blocks must be added to the corresponding load steps for them to be written out to the Abaqus deck.
All types of output requests in an output block are defined from the card image.  The edit button in the panel displays the card image of the currently loaded output block.  The entity selector buttons available in the Output Block panel are not useful for Abaqus.  They should be ignored.
hmtoggle_arrow1LS-DYNA
Data on LS-DYNA output blocks cannot be edited.
Supported Card
Solver Description
Notes
*DATABASE_HISTORY_
BEAM(ID)
Describe time history for beam elements.
*DATABASE_HISTORY_
BEAM_SET
Describe time history for beam element sets.
*DATABASE_HISTORY_
DISCRETE
*DATABASE_HISTORY_
DISCRETE_SET
*DATABASE_HISTORY_
NODE(ID)
Describe time history for nodes.
LocalOption
ID
*DATABASE_HISTORY_
NODE_LOCAL(ID)
*DATABASE_HISTORY_
NODE_SET
Describe time history for node sets.
LocalOption
*DATABASE_HISTORY_
NODE_SET_LOCAL
CID
REF
*DATABASE_HISTORY_
NODE_SET_LOCAL(ID)
n/a
*DATABASE_HISTORY_
SEATBELT
Define time history on seat belt element.
ID
*DATABASE_HISTORY_
SHELL
Describe time history for shell elements.
n/a
*DATABASE_HISTORY_
SHELL(ID)
ID
*DATABASE_HISTORY_
SHELL_SET
Describe time history for shell element sets.
*DATABASE_HISTORY_
SOLID
Describe time history for solid elements.
*DATABASE_HISTORY_
SOLID(ID)
*DATABASE_HISTORY_
SOLID_SET
Describe time history for solid element sets.
*DATABASE_HISTORY_
SPH
Describe time history for SPH elements.
*DATABASE_HISTORY_
TSHELL
Describe time history for TSHELL elements.
*DATABASE_HISTORY_
TSHELL(ID)
*DATABASE_HISTORY_
TSHELL_SET
Describe time history for TSHELL element sets.
hmtoggle_arrow1PAM-CRASH 2G
Keyword selection for output blocks is supported as GES selection.
The appropriate keyword is output when selecting elements for time-history output.
Supported Card
Solver Description
Notes
PLANE
SECFO /
Section definition for force output
Transmission forces are supported through the Interfaces panel.  Slave nodes and master elements define the cross section.  To define non-shell elements, create an entity set first.  The master definition must be by sets.
SECTION
SENPT /
Sensor point output definition
SENPTG /
SUPPORT
THELE /
Element time history
TITLE
Definition Mode (Use EntityId List, Define Using General Entity Selection)
Uses element output block.
THLOC /
Local frame definition for node output
IFRAM
ICORR
IDAFLD
TITLE
GES
Coordinate System (Local System, Nodes N1 and N2)
In card previewer, a toggle switches between THLNO and THLOC.  Additional input fields are shown in the card previewer for THLOC keyword.
THNOD /
Nodal time history
TITLE
GES
Uses output block including nodes.
VOLFRAC
See Also:
Browsers
Entities & Solver Interfaces
Include Files
Properties
Element Property and Material Assignment Rules
Model Setup
