The Pre-Tension Section dialog allows you to define the *PRE-TENSION SECTION section and related assembly loads and constraints. This dialog contains two tabs:
The Pre-Tension Section dialog contains the following buttons:
OK |
Updates the Engineering Solutions database with the changes and closes the Pre-tension Section dialog. |
Apply |
Updates the Engineering Solutions database with the changes without closing the Pre-tension Section dialog. |
Cancel |
Closes the Pre-tension Section dialog without updates. |
