In the Quality Index Cleanup Tools secondary panel you can access numerous tools that assist you in manually relocating nodes and optimizing element topology.
The Quality Index Cleanup Tools secondary panel's layout changes dynamically depending on the cleanup tool you select. The list of cleanup tools is always displayed along the left-hand side of the panel. The criteria for the currently active cleanup tool displays in the second column, and the current composite Quality Index, patch checker, and action buttons display in the third column.
There are no subpanels on the Quality Index Cleanup Tools secondary panel. However, the following cleanup tools each use their own set of entry fields:
Panel Inputs
Panel Inputs
Use the Swap Edge tool to consider the elements to which the edge belongs, and find alternative orientations for it. Each time you click an edge in the graphics area, it switches to the next valid configuration. If an edge swap will not improve element quality, a message to that effect displays in the status bar. To force the swap anyways, click the edge a second time. Additional clicks will cycle through the possible edge positions. The number of possible edge positions depends on the types of elements involved. For a pair of trias, there are two possible positions for their shared edge. For a pair of quads, there are three possible positions. For a quad and a tria, there are six possible positions.
Use the Node Optimize tool to automatically move a selected node to optimize the overall quality of its surrounding elements. The options along surface, normal to surface, and along and normal to surface work exactly as described for the place node tool. The only difference is that node optimize moves the node automatically, while place node requires you to choose the location manually. To move the midnodes attached to the node you are optimizing, select the with attached midnodes check box. This option is useful when you are working with second order elements. The mouse indicates the node that will be moved in each of the following examples Moving along surface Moving normal to surface Moving along and normal to surface
Use the Element Optimize tool to automatically optimize the shape of the selected element and the elements surrounding it. It is similar to Node Optimize, except that its effects are wider-spread. To move the midnodes attached to the element you are optimizing, select the with attached midnodes check box. This option is useful when you are working with second order elements.
Use the Smooth cleanup tool to improve element quality in a surface-based mesh. This cleanup tool uses one or more algorithms to adjust node positions to moderate sharp variations in size or quality in adjacent elements, and to adjust the position of the free nodes of the selected shell elements to smooth out variations in element quality and size. A node of a shell element is free if none of the following statements are true:
Panel InputsThe Smooth panel contains the following subpanels and command buttons:
For any elements that are not associated to surfaces, HyperMesh infers an approximation to the shape of the surface that most likely produced these elements.
Use the split/collapse edge cleanup tool to split or collapse the edges of elements in your model. To use the split edge tool, left-click on one edge. HyperMesh splits the elements that share the selected edge in a way that will achieve the optimum quality. To use the collapse tool, right-click on the edge you wish to collapse. HyperMesh collapses the selected edge, as well as any edges that are associated with it.
Use the drag tria element cleanup tool to drag a tria element to a different location in the model, or out of the model completely. To use the drag tria element cleanup tool, left-click on a tria element and drag it to a desired location. HyperMesh highlights the selected tria element in pink. To drag two tria elements together and merge them into one quad element, select the merge trias check box. Merge trias check box selected. Merge trias check box unselected.
Use the split quad element cleanup tool to split a quad element into two tria elements. To split a quad element, left-click on the quad element you wish to split. Hypermesh splits the quad element into two tria elements.
Use the combine tria elements cleanup tool to combine two tria elements into one quad element. To combine two tria elements, left-click on their shared edge. HyperMesh combines the two tria elements into one quad element.
Use the Patch Checker to review "patches" of failed elements, as well as quality results. Each patch contains failed element with layers of elements around it. To increase or decrease the number of layers, click The Patch Checker displays the comp. QI value, the number of failed elements, and the percent of failed elements in each patch. To reduce the number of failed elements, use the Quality Index cleanup tools. Once you have corrected all of the elements in the patch, you can move on to the next patch. You will no longer be able to display the previous patch, as all elements are corrected.
The following action buttons appear:
