Engineering Solutions
Saving Assemblies as HyperMesh Binary Files
In the Part browser, right-click on a part assembly and select Save Part Assembly As from the context menu. In the Save As dialog, save the binary in the representations directory for the current binary file. The part assembly binary file is self-contained and includes the part assembly based hierarchy and attributes such as components, properties, and materials.
In the image below, the LeftRail_A_000433_Safety part assembly in the Frame_Assembly_000495 part assembly is being saved as a Engineering Solutions binary file.
part_assembly_save_assembly_as
Because the saved part assembly is self-contained, all Engineering Solutions entities shown in the Part browser are saved to the binary file. Opening the saved binary file in a new Engineering Solutions session results in the following view in the Part browser.
part_assembly_save_assembly_as_2
You can perform all necessary tasks such as geometry updates and meshing in the distributed Engineering Solutions binary file. The completed file can then be imported into the master Engineering Solutions session by importing a model.
See Also:
Importing Models
Part Browser
Part Browser Context Menu
