Engineering Solutions
Sets entitySets-24
Sets entitySets-24
Previous topic Next topic Expand/collapse all hidden text
Sets entitySets-24
Set entities are used to define and store lists of entity IDs for a specific entity.  Sets can be generated for nodes, elements, components, assemblies, properties, materials, ellipsoids, multibody planes, multibody joints, and multibodies which contain entity IDs for that specific entity.  Sets can also be generated as sets of sets, or lists of set IDs.  Sets are shown under the Set folder within the Model browser. The Set browser can be used to create, edit, and review sets.
Sets do not have a display state.
Sets have an active and export state.  The active state of a set controls the listing of the set in the Model browser and any of its views.  If a set entity is active, then it is listed in the Model browser and any of its views.  If a set entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of a set entity controls wether or not that set is exported when the custom export option is utilized.  The all export option is not affected by the export state of a set.  The active and export states of set entities can be controlled using the Entity State browser.
The data names associated with sets can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit sets:
Entity Sets
Solver Card Support for Sets
hmtoggle_arrow1RADIOSS
Note: Sets of different types but with the same ID are supported.
Supported Card
Solver Description
Supported Parameters
Notes
/GRBEAM
Describes the beam groups.
/GRBEAM/BEAM
Describes the beam number groups.
/GRBEAM/BOX
/GRBEAM/BOX2
/GRBEAM/GRBEAM
/GRBEAM/MAT
Describes the beam material groups.
/GRBEAM/PART
Describes the beam part groups.
/GRBEAM/PROP
Describes the beam property groups.
/GRBEAM/SUBSET
Describes the beam subset groups.
/GRBRIC
Describes the brick groups.
/GRBRIC/BOX
Describes the brick box groups.
/GRBRIC/BOX2
/GRBRIC/BRIC
Describes the brick number groups.
/GRBRIC/GRBRIC
/GRBRIC/MAT
Describes the brick material groups.
/GRBRIC/PART
Describes the brick part groups.
/GRBRIC/PROP
Describes the brick property groups.
/GRBRIC/SUBSET
Describes the brick subset groups.
/GRNOD
Describes a node group
/GRNOD/BOX
Describes the node box groups.
/GRNOD/GENE
Describes the node groups.
/GRNOD/GRBEAM
/GRNOD/GRBRIC
/GRNOD/GRQUAD
/GRNOD/GRSH3N
Describes the 3 node shell groups.
/GRNOD/GRSHEL
Describes the 4 node shell groups.
/GRNOD/GRSPRI
Describes the node spring groups.
/GRNOD/GRTRUS
Describes the node truss groups.
/GRNOD/MAT
Describes the node material groups.
/GRNOD/NODE
/GRNOD/NODENS
Describes the unsortable node number groups.
/GRNOD/PART
Describes the node part groups.
/GRNOD/PROP
Describes the node property groups.
/GRNOD/SUBSET
Describes the node subset groups.
/GRNOD/SURF
Describes the node surface groups.
/GRPART
Describes the part groups.
/GRQUAD
Describes the quad groups.
/GRQUAD/BOX
/GRQUAD/BOX2
/GRQUAD/GRQUAD
/GRQUAD/MAT
Describes the quad material groups.
/GRQUAD/PART
Describes the quad part groups.
/GRQUAD/PROP
Describes the quad property groups.
/GRQUAD/QUAD
Describes the quad number groups.
/GRQUAD/SUBSET
Describes the quad subset groups.
/GRSH3N
/GRSH3N/BOX
/GRSH3N/BOX2
/GRSH3N/GRSH3N
/GRSH3N/MAT
Describes the 3 node shell material groups.
/GRSH3N/PART
Describes the 3 node shell part groups.
/GRSH3N/PROP
Describes the 3 node shell property groups.
/GRSH3N/SH3N
/GRSH3N/SUBSET
Describes the 3 node shell subset groups.
/GRSHEL
Describes the shell groups.
/GRSHEL/BOX
Describes the shell box groups.
/GRSHEL/BOX2
/GRSHEL/GRSHEL
/GRSHEL/MAT
Describes the shell material groups.
/GRSHEL/PART
Describes the shell part groups.
/GRSHEL/PROP
Describes the shell property groups.
/GRSHEL/SHEL
Describes the shell number groups.
/GRSHEL/SUBSET
Describes the shell subset groups.
/GRSPRI
Describes the spring groups.
/GRSPRI/BOX
/GRSPRI/BOX2
/GRSPRI/GRSPRI
/GRSPRI/PART
Describes the spring part groups.
/GRSPRI/PROP
Describes the spring property groups.
/GRSPRI/SPRI
/GRSPRI/SUBSET
Describes the spring subset groups.
/GRTRUS
Describes the truss groups.
/GRTRUS/BOX
Describes the truss box groups.
/GRTRUS/BOX2
/GRTRUS/GRTRUS
/GRTRUS/MAT
Describes the truss material groups.
/GRTRUS/PART
Describes the truss part groups.
/GRTRUS/PROP
Describes the truss property groups.
/GRTRUS/SUBSET
Describes the truss subset groups.
/GRTRUS/TRUS
/LINE
Definition of the line.
/LINE/BOX
Definition of the line box.
/LINE/BOX2
/LINE/EDGE
Definition of the line edges of the surfaces.
/LINE/GRBEAM
/LINE/GRTRUS
/LINE/MAT
Definition of the line material.
/LINE/PROP
Definition of the line property.
/LINE/SURF
Definition of the line surface.
/SURF
Describes the surface definition.
/SURF/BOX
/SURF/BOX/ALL
Describes the box surface definition (All).
/SURF/BOX/EXT
Describes the external box surface definition.
/SURF/BOX2
/SURF/GRSHELL
Describes the surface definition of a group of shells.
/SURF/MAT
Describes the material surface definition.
/SURF/MAT/ALL
Describes the material surface definition (All).
/SURF/MAT/EXT
Describes the external material surface definition.
/SURF/PART
Describes the parts surface definition.
/SURF/PART/ALL
Describes the parts surface definition (All).
/SURF/PART/EXT
Describes the external parts surface definition.
/SURF/PROP
Describes the property surface definition.
/SURF/PROP/ALL
Describes the property surface definition (All).
/SURF/PROP/EXT
Describes the external property surface definition.
/SURF/SUBSET
Describes the subset surface definition.
/SURF/SUBSET/ALL
Describes the subset surface definition (All).
/SURF/SUBSET/EXT
Describes the external subset surface definition.
/SURF/SURF
hmtoggle_arrow1OptiStruct
OptiStruct sets are represented in HyperMesh as entity sets, and are controlled in the Entity Sets panel.  The sets can be composed of grids, elements, design variables, MBD entities, mode numbers, frequencies or times for reference by other input definitions.  In addition to the definition of entity sets through the explicit selection of the constituents, it is possible to define a set of nodes or a set of elements through a combination of formulaic expressions.
Supported Card
Solver Description
Notes
BORE
Bored Deformation
ERPPNL
Defines one or more sets of elements as panels for equivalent radiated power output for a frequency response analysis of a coupled fluid-structural model.
MBDCRV
Defines an ordered list of grids as a Multi-body Deformable Curve.
MBDSRF
Defines a Multi-body Deformable Surface.
MBPCRV
Defines a Multi-body Parametric Curve using node sets.
PANEL
Defines up to four sets of grid points as panels for panel participation output for a frequency response analysis of a coupled fluid-structural model.
n/a
PANELG
Defines a set of grid points and/or elements as a generic panel.
ROTORG
Used for the specification of grids that determine the Rotor Line model.
RSPINR
RSPINR
Defines the relative spin rates between rotors during a rotor dynamic analysis in Modal Complex Eigenvalue or Frequency Response solution sequences.
SET
Defines a set of grids, elements, design variables, MBD entities, mode numbers, frequencies or times for reference by other input definitions.
SET_DESVAR - Contains design variables
SET_ELEM - Contains elements, properties, blocks or materials.
SET_FREQ - Contains real values.
SET_GRID - Contains nodes or blocks.
SET_GRIDC - Contains grid and component list.
SET_MODE - Contains real values.
SET_PLOTEL - Contains output commands for grid and plot elements.
SET_PLY - Contains plies.
SET_TIME - Contains real values.
Sets of integer and real values are supported as entity sets.
SET3
Defines a set of grids or elements.
NODE
ELEM
PROP
Note:        Sets that are created in Engineering Solutions are maintained on I/O by using $HMSET comment cards.
hmtoggle_arrow1Abaqus
Sets can be created of nodes, elements, components, and other sets.
Supported Card
Solver Description
Notes
*DISTRIBUTION
Define spatial distributions
LOCATION
NAME
TYPE
*ELSET
Assign elements to an element set
ELSET
GENERATE
*EMBEDDED ELEMENT
Specify an element or a group of elements that lie embedded in a group of “host” elements in a model
ABSOLUTE EXTERIOR TOLERANCE
EXTERIOR TOLERANCE
HOST ELSET
ROUNDOFF TOLERANCE
*NODAL THICKNESS
Define shell or membrane thickness at nodes
GENERATE
*NSET
Assign nodes to a node set
NSET
ELSET
GENERATE
UNSORTED
Sets can be specified directly from nodes and elements in the model or by a formula. Sets of sets and components are also supported in Abaqus templates. To create sets that contain a combination of sets and individual nodes or elements, select the add by IDs option in a formula-based set.
A User Comments block is supported for all sets.  See the information below on how to add comments to any set card image. These comments will be preserved during import and export of the Abaqus input deck.
Sets using the GENERATE parameter can be expanded upon imported using the Expand sets defined by range solver option in the Import panel. This is useful for when node/element IDs are renumbered during import.
hmtoggle_arrow1ANSYS
Supported Card
Solver Description
Notes
CMGRP
Groups components and assemblies into an assembly.
Name
This is supported as sets of sets.
hmtoggle_arrow1LS-DYNA
The default LS-DYNA attribute values for the set can be edited.  Individual values cannot be edited.
Supported Card
Solver Description
Notes
*DEFINE_HEX_SPOTWELD
_ASSEMBLY
Assembly of elements that describes a spotweld.
NumID
_ASSEMBLY_N
*SET_BEAM(TITLE)
Define a set of beam elements.
GenerateOption
Title
*SET_BEAM_ADD
Define a beam set by combining beam sets.
Title
*SET_BEAM_GENERATE
(TITLE)
Generates a block of beam element IDs between a starting ID and an ending ID.
GenerateOption
Title
*SET_DISCRETE(TITLE)
Define a set of discrete elements.
GenerateOption
Title
*SET_DISCRETE_ADD
Define a discrete set by combining discrete sets.
Title
*SET_DISCRETE_
GENERATE(TITLE)
Generates a block of discrete element IDs between a starting ID and an ending ID.
GenerateOption
Title
*SET_NODE_ADD
Define a node set by combining node sets.
A1 - A4
SOLVER (MECH, CESE, ICFD)
Title
*SET_NODE_ADD_
ADVANCED
Define a node set by combining node sets or by combining NODE, SHELL, SOLID, BEAM, SEGMENT, DISCRETE and THICK SHELL sets.
A1 - A4
Title
*SET_NODE_COLUMN
Define a nodal set with some identical or unique attributes.
DA1 - DA4
Title
*SET_NODE_LIST(TITLE)
DA1 - DA4
Options (None, Generate, Column)
Title
*SET_NODE_LIST_
GENERATE(TITLE)
Generate a block of node IDs between a starting nodal ID number and an ending nodal ID number.
DA1 - DA4
NBEG, NEND
Title
*SET_PART_ADD
Define a part set by combining part sets.
DA1 - DA4
Title
*SET_PART_COLUMN
(TITLE)
Define a set of parts with optional attributes.
DA1 - DA4
Title
*SET_PART_LIST_
GENERATE(TITLE)
Generate a block of part IDs between a starting part ID number and an ending part ID number.
DA1 - DA4
Title
*SET_SEGMENT_
GENERAL
Definition of contact surface from parts, elements, box.
DA1 - DA4
Title
*SET_SHELL_ADD
Define a shell set by combining shell sets.
Title
*SET_SHELL_COLUMN
Define a set of shell elements with optional identical or unique attributes.
DA1 - DA4
Title
*SET_SHELL_LIST(TITLE)
DA1 - DA4
Title
*SET_SHELL_LIST_
GENERATE(TITLE)
DA1 - DA4
NBEG, NEND
Title
*SET_SOLID(TITLE)
Define a set of solid elements.
GenerateOption
Title
*SET_SOLID_ADD
Define a solid set by combining solid sets.
Title
*SET_SOLID_GENERAL
*SET_SOLID_GENERATE
(TITLE)
Generate a block of solid element IDs between a starting ID and an ending ID.
GenerateOption
Title
*SET_TSHELL(TITLE)
Define a set of thick shell elements.
GenerateOption
Title
*SET_TSHELL_GENERAL
*SET_TSHELL_GENERATE
(TITLE)
Generate a block of thick shell element IDs between a starting ID and an ending ID.
GenerateOption
Title
hmtoggle_arrow1Nastran
Supported Card
Solver Description
Notes
BCPROP
Defines a 3D contact region by element properties.
Set Type (non-ordered, ordered, formula)
BNDFREE1
C
BOLT
Defines a rigid bolt by a set of MPC constraints.
ETYPE
BOLTLD
CSUPER
Defines the grid or scalar point connections for identical or mirror image superelements or superelements from an external source.
SSID, PSID
CSUPEXT
Assigns exterior points to a superelement.
SEID
ERPPNL
Defines one or more panels by referencing sets of elements or properties.
SETID - SET3 Bulk Data entry
PANEL
Defines one or more panels by referencing sets of grid points, elements or properties.
NAME, SETID,
ROTORG
Specifies grids that compose the rotor line model.
RSPINR
RSPINT
RSPINR
Specifies the relative spin rates between rotors for complex eigenvalue, frequency response, and static analysis.
Supported in conjunction with ROTORG
RSPINT
Specifies rotor spin rates for Transient analysis.
SEBNDRY
Defines a list of grid points in a partitioned superelement for the automatic boundary search between a specified superelement or between all other superelements in the model.
SEIDB Options (ALL, VALUE)
SEBSET1
Defines boundary degrees-of-freedom to be fixed (b-set) during generalized dynamic reduction or component mode calculations.
SEID, C
SECSET1
Defines boundary degrees-of-freedom to be free (c-set) during generalized dynamic reduction or component mode synthesis calculations.
SEID, C
ALL
SEQSET1
Defines the generalized degrees-of-freedom of the superelement to be used in generalized dynamic reduction or component mode synthesis.
SEID, C
SESET
Defines interior grid points for a superelement.
SEID
SET
Defines a set of element or grid point numbers to be plotted.
ID
Node and element sets supported with the THRU option.
SET1
Defines a list of structural grid points or element identification numbers.
ID
SKIN
SEUSET1
Defines a degree-of-freedom set for a superelement.
SEID, SNAME, C
Note:When reading input decks that were not created in Engineering Solutions, an attempt is made to create two sets for each set found: one containing elements and one containing nodes.  You can delete the unnecessary set.
Sets that are created are maintained as node or element sets by using $HMSET comment cards.
hmtoggle_arrow1PAM-CRASH 2G
During import, entity sets are automatically generated. PAM-CRASH 2G cards with general entity selection generate entity sets.
Supported Card
Solver Description
Notes
GES /
GROUP /
Keyword selection
PAM-CRASH 2G GROUP / card and general entity selection (GES) are mapped as set of sets.
A set is created if only one keyword is used.
A set of sets is created in the following cases:
If the definition uses more than one keyword.
Unresolved groups are used in the definition.
More than one GRP keyword is present in the definition.
A GROUP definition is always implemented as set of set.
In card previewer a toggle switches between PAM-CRASH 2G GROUP and General Entity Selection.
See Also:
Browsers
Entities & Solver Interfaces
Include Files
Model Setup
