Engineering Solutions
OptiStruct Summary Templates
The optistruct template generates OptiStruct input decks.
The optistructlf template generates OptiStruct input decks using the long format for CELAS, CONM2, FORCE, GRID, MAT1, MAT2, MAT8, MAT9, MOMENT, MPC, PBEAM, PBEAML, PCOMP, PCOMPG, PBARL, PROD and PSHELL bulk data entries.
DVGRID bulk data entries are written in long format with both templates.
All settings necessary to interface with OptiStruct can be loaded by loading the OptiStruct user profile.
The following summary templates are available for OptiStruct:
components
Summarizes the name, number, material, mass and number of elements for each component in the current database.
constraints
Summarizes the name, number, response, lower and upper bounds for each constraint in an optimization problem defined in the current database.
ctr of gravity
Calculates the center of gravity of the model.
elements
Summarizes the number of each element type in the current database.
loads
Summarizes the forces and moments applied to the current model.
mom of inertia
The mom_of_inertia template calculates the moments of inertia of the model.
errorcheck
Summarizes the model errors.
responses
Summarizes the name and type of responses in an optimization problem defined in the current database.
See Also:
OptiStruct Interface
