Engineering Solutions
To Define a new HyperLaminate Solver loadcase
Use one of the following three methods to create a new HLS loadcase in HyperLaminate:
Method 1:
1.Select a sub-type under the HLS loadcases branch of the Laminate Browser.
2.Right-click the selected sub-type.
A context-sensitive menu appears with one option: New.
3.Click New.
A new loadcase appears under the selected branch.
Method 2:
2.Select New from the File pull-down menu.
Method 3:
2.Click the New icon, new_button , on the toolbar.
A default name and ID are assigned to newly created HLS loadcases.
The newly created loadcase is automatically selected in the Laminate Browser and the Define/Edit pane takes on the appropriate configuration.
3.If desired, a new name for the laminate may be entered in the Loadcase: field.
4.Provide the loadcase definition by filling in the entry fields in the Define/Edit pane.
5.Click Apply to save the changes for the current HyperLaminate session. (It is important to remember that the HyperMesh database is only updated on exit from HyperLaminate.)
