Engineering Solutions
Connector Panels
Connector Panels
Connector Panels
Spot
Create spot welds and similar spot-type connectors.
Bolt
Create bolt connectors.
Seam
Create line-based connections.
Area
Create area-based connectors such as adhesives.
Apply Mass
Use a "dummy" connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
FE Absorb
Add (absorb) existing FE weld entities as realization to connectors.
Add Links
Add entities to existing connectors.
Unrealize
Remove existing welds.
Compare
Compares the model’s current connectors with a master connection file (mcf) so that you can quickly locate discrepancies.
Quality
Perform FE quality checks on connector entities.
