Engineering Solutions
CYLINDER Option
CYLINDER Option
CYLINDER Option
analytical_rigid_surface_define_cylinder
Analytical rigid surface of type CYLINDER
Select the following options on the Define tab for cylindrical rigid surfaces:
Plane definition
Plane/axis:
Choose User Defined if you want to create or select the system, or choose XY, YZ, or XZ to define it in the respective plane.
If you choose to manually define the plane/axis, you must enter values for three points (the origin, x axis, and generator axis) that define the local plane on which the line segments will be defined.
You can also use the following buttons to define the plane:
Pick System
Click to select an existing system from the model. Once you select a system from the graphic area and click proceed, the values are populated in the table.
Create/Edit System
Click to create a new coordinate system using the Systems panel.
Line definition
No. of line segment datalines
In this field you specify the number of datalines needed to define the line segments. The actual number of line segments is one less than this number.
Start by typing the number of segment datalines to define the surface and click the Set button. The corresponding number of rows appears in the Line Type table below. In this table, specify the coordinates of the ends of each line segment.
The first entry in the table is always the START node. This value specifies the beginning point of the first segment. The subsequent segments’ starting point is always the end point of the previous segment, or the START node if the segment is the first in the definition.
For each line type, select a type from the Line Type column: LINE, CIRCL, or PARAB. Each selection activates the appropriate number of columns for the segment definition.
The segments can be circles, parabolas, or lines. Enter data in the columns as described below:
Lines are defined with the local x- and local y-coordinates of the end point in the two active columns.
For circles, specify the local-x and local-y coordinate of the end point in the first two columns and then, define the local-x and local-y coordinate of the center in the last two columns.
For parabolas, specify the local-x and local-y coordinate of the mid point in the first two columns and then, define the local-x and local-y coordinate of the end point in the last two columns.
Note:The local x- and local y-coordinates must be relative to the plane defined in the Plane/axis table.
You can also pick nodes or lines from existing geometry using the following buttons:
Pick Nodes…
Click to pick nodes from the model for selected line segments. When you click proceed, the coordinate values of the selected nodes in terms of the defined plane will appear in selected line segment cells. In addition, temporary line segments (white color) will also be drawn in the graphic area from the picked nodes. Ensure that you select two nodes in the correct order for circles and parabolas.
Pick Lines…
Use this option to define line segments from existing lines in Engineering Solutions. These lines must be single curvature, connected and node1 of a line must be same as the node2 of the previous line.
Click to pick a line from the model. When you click proceed, the coordinate values relative to the defined plane and line types for the selected lines will appear in the table.
Sweep Distance
Abaqus does not need the sweep distance. The CYLINDER type surfaces are swept to infinity in Abaqus. However, in Engineering Solutions, you must define a sweeping distance to draw the three dimensional surface. Select the Sweep distance check box to specify a sweep distance and type a value in the adjacent box. Select the Both directions check box to sweep in opposite directions along the generator vector.
Click the Update button to update the database with your settings.
See Also:
SEGMENTS Option
REVOLUTION Option
Analytical Rigid Surface
Abaqus Contact Manager
