The Find menu contains options that help you find and visualize data. The following macros are included.
Temporary Nodes |
CNODE Clr/All/Dis |
Clr: deletes all temp nodes from the model. All/Dis: Finds CNODEs in the complete/displayed model and highlights the nodes as temp nodes. |
Find Components: |
By Elems |
Finds all components which have elements in the current (masked) display. |
Rbody visualization: |
All/Dis/Sel |
Updates the rigid bodies definition by resolving the references to a GES (set/setofset) by converting them into node lists and displaying the web on the screen. All: Updates all rigid bodies Dis/Sel: Updates displayed or selected rigid bodies, respectively |
Find/Mask |
Finds/Masks the respective entities. Review the buttons’ tool tips to see the full entity name. |
See Also:
