The Conn menu contains options that lets you manage connectors in the model. The following macros are included.
Connector organize: |
ByPinkPart |
Organizes the connectors by the parts of the associated Plink elements. |
Renumber: |
NodeID/Plink ID |
Node ID: Renumber nodes for displayed plinks such that plinkId = plinkNodeId. Plink ID: Renumber displayed plinks such that plinkId = plinkNodeId. |
Connector panel: |
Feabsorb/Quality/
Enters the connectors panel, and then fe absorb/quality/fe realize panel, depending on the selected macro. |
Find att to P(X)LINKs |
Ces: finds connectors attached to the displayed link entity. Com: finds all components attached to the displayed link entity. Mcom: finds all master components attached to the displayed link entity. Scom: finds all slave components attached to the displayed link entity. |
Find att to CE |
PL: finds Plinks attached to the displayed connectors. Com: finds all components attached to the displayed connectors. |
Find att to Comps |
Finds entities attached to the displayed components. |
Find/Mask |
Finds/Masks the entities depending upon the selected macros. |
See Also:
