Engineering Solutions
M1 Menu
M1 Menu
M1 Menu
The M1 menu contains options that set the correct element or load type and enter the appropriate panel.  The following macros are included.
PART/:
3D/2D/1D/LINK
Enters the Components panel, selects the comps collector, and sets the correct card image.
MATER/:
3D/2D/1D/LINK
Enters the Components panel, selects the mats collector, and sets the correct card image.
PLY_DATA
Enters the Components panel, selects the mats collector, and sets the correct dictionary.
Mass elements:
MASS
Sets the element type mass = to MASS and enters the Mass panel.
NSMAS
Enters the Interfaces panel and sets the card image to nsmas.
Constraints:
RBODY
Sets the element type rigid = to RBODY and enters the Rigids panel.
NODCO
Sets the element type rigid = to NODCO and enters the Rigids panel.
RWALL
Enters the Rigid Walls panel and set the card image = to RWALL.
CNTAC
Enters the Interfaces panel and sets the card image = to CNTAC.
TIED
Enters the Interfaces panel and sets the card image = to TIED.
Elements:
BAR
Sets the element type 1dele = to BAR and enters the 1d Elems panel.
BEAM
Sets the element type beam = to BEAM and enters the Beams panel.
KJOINT
Sets the element type 1dele = to KJOIN and enters the 1d Elems panel.
JOINT
Sets the element type 1dele = to JOINT and enters the 1d Elems panel.
SPRING
Sets the element type spring = to SPRING and enters the Springs panel.
SHELL
Sets the element type tria3 = and quad4 = to SHELL.
MEMBR
TRIA_C
Sets the element type tria3 = TRIA_C.
SOLID
Sets the element type tetra4, pyramid5, penta6, and hex8 = to SOLID.
BSHEL
Sets the element type hex8 = to BSHEL.
Link elements:
PLINK
Sets the element type mass = to PLINK and enters the Mass panel.
ELINK
Sets the element type 1dele = to ELINK and enters the 1d Elems panel.
LLINK
Sets the element type 1dele = to LLINK and enters the 1d Elems panel.
SLINK
Sets the element type tria3 = and quad4 = to SLINK.
See Also:
Conn
Card
Find
M2
Sum
Tool
