The M2 menu contains options that set the correct element or load type and enter the appropriate panel. The following macros are included.
Auxiliaries: |
FRICT |
Enters the Components panel, selects the props collector, and sets card image = to FRICTION. |
RUPMO |
Enters the Components panel, selects the props collector, and sets card image = to RUPTURE_MODEL. |
SENSO |
Enters the Sensors panel. |
CURVES |
Enters the Edit Curves panel and set the radio button to modify. |
Safety: |
SLIPR |
Sets element type mass = to SLIPRING and enters the Mass panel. |
RETRA |
Sets element type mass = to RETRACTR and enters the Mass panel. |
BAGIN |
Enters the Airbag panel and sets the card image to BAGIN. |
CHAMB |
Enters the Airbag panel and sets the card image to CHAMBER. |
GASPC |
Enters the Components panel, selects the props collector, and sets card image = to GASPEC. |
Plot output: |
THNOD |
Enters the Output Blocks panel and changes the type to nodes. |
THELE |
Enters the Output Blocks panel and changes the type to elements. |
SENPT |
Sets element type mass = to SENPT and enters the Mass panel. |
SECFO_SECTION |
Enters the Interfaces panel and sets card image = to SECFO_SECTION. |
SECFO_SUPPORT |
Enters the Interfaces panel and sets card image = to SECFO_SUPPORT. |
SECFO_VOLFRAC |
Enters the Interfaces panel and sets card image = to SECFO_VOLFRAC. |
SECFO_PLANE |
Enters the Rigid Walls panel and sets card image = to SECFO_PLANE. |
Nodals: |
FRAME |
Enters the Systems panel. |
NODE |
Enters the Nodes panel. |
INVEL |
Sets load type velocity = to INVEL and enters the Velocity panel. |
VEL3D |
Sets load type velocity = to VEL3D and enters the Velocity panel. |
RVE3D |
Sets load type velocity = to RVE3D and enters the Velocity panel. |
ACC3D |
Sets load type acceleration = to ACC3D and enters the Acceleration panel. |
RDV3D |
Sets load type velocity = to RDV3D and enters the Velocity panel. |
RDA3D |
Sets load type acceleration = to RDA3D and enters the Acceleration panel. |
RAC3D |
Sets load type acceleration = to RAC3D and enters the Acceleration panel. |
BOUNC |
Sets load type constraint = to BOUNC and enters the Constraints panel. |
DIS3D |
Sets load type constraint = to DIS3D and enters the Constraints panel. |
DIS3DX |
Sets load type constraint = to DIS3DX and enters the Constraints panel. |
DIS3DM |
Sets load type constraint= to DIS3DM and enters the Constraints panel. |
RAN3D |
Sets load type constraint= to RAN3D and enters the Constraints panel. |
RDD3D |
Sets load type constraint= to RDD3D and enters the Constraints panel. |
CONLO |
Sets load type force= to CONLO and enters the Forces panel. |
Analysis by keyword: |
LOADCOLS |
Enters the Collector panel, switches the type to loadcols and sets the card image to INVEL. |
See Also:
