The GES macro displays a GES browser that lets you manage sets in the model. Because general entity selection is mapped as a set of sets in the PAM-CRASH 2G interface, the need to manage the sets becomes more crucial for the effective and efficient handling of the model.
Functionalities included in the GES Browser |
DELNOD Card |
The following parameters are available via the DELNOD card: ELE GRP PART NOD SEG EDG ELE > NOD PART > NOD GRP > NOD DELNOD DELELE DELPART DELGRP DELELE > NOD DELPART > NOD DELGRP > NOD |
When you add a set to the GES using drag and drop functionality of the browser, a new set is created with the exact copy of the contents of the original set, therefore, the changes made to this new set are local in effect but in case of adding a group to the GES, only a reference is made to the existing GROUP definition. You can modify the GROUP by using the references also but there exist only one copy of the group in the model. Therefore while modifying one of the references, you should always keep in mind that this change will also affect all the other references to this group and the group itself is modified. In case the group does not exist in the model, it is created. If you do not want to create the group, instead use the functionality Unresolved Groups > Edit and add the group there. This will be exported correctly.
You can also create a config file, which saves all information about various GES browser options, such as DisplayComments (Yes/No), DisplayRanges (Yes/No), confirmChanges (Yes/No), etc. Later on, this config file can be used to restore these settings. By default, a config file (gesbrowser.cfg) is saved in the working directory for each session of the GES browser and settings from this file are applied every time the browser is built. These functionalities can be invoked from the buttons LoadCFG/SaveCFG.
See Also:
