Nastran - Free Body Diagrams
• | Results are supported through the .op2 and .xdb output files. |
• | Grid point force results are requested with the GPFORCE output request. |
• | Displacement results are requested with the DISPLACEMENT output request. |
• | It is recommended practice to output data for only the node set(s) of interest. This procedure reduces the size of the solver results file and helps speed up the FBD extractions. Consider using STRESS=NONE and STRAIN=NONE to further reduce the size of the results file. |
• | MPC forces and moments are properly extracted for the following MPC constraint types: |
RBE2
RBE3
RigidLink
RJOINT
RROD
RBAR
See Also:
Free Body Diagram Tools Overview
FBD Resultant Force and Moment
Grid Point Force Balance Overview
