Creates nodes by specifying the x, y, z coordinates, picking on existing geometry, on line, or between nodes. |
Finds the distance or angle between nodes. |
Associates, moves, or places nodes on a surface. |
Adds or removes temporary nodes. |
Create, remove, and view preserved nodes. |
Creates zero-dimensional geometric entities, either from user-specified coordinates or based upon existing higher-order geometry. |
Determines the length of a group of selected lines. |
Combines lines, splits lines at a point, at a joint, at a line, or at a plane, and smoothes lines. |
Creates lines by picking nodes. |
Performs automatic geometry cleanup and prepares it for meshing based on the parameters set in the panel. |
Creates a surface or mesh for cones or cylinders. |
Removes surface features. |
Creates a surface or mesh by dragging nodes, lines, or elements. |
Modify specific dimensions of surfaces, possibly altering their shapes. |
Creates a surface or mesh by dragging nodes, lines, or elements along a line. |
Allows you to extract the midsurface representation of a solid part. |
Creates a planar surface or mesh bounded by planar lines. |
Creates and modifies simple ribs between two surfaces. |
Creates a surface or mesh from nodes or lines which are unconnected. |
Creates a surface or mesh skin across a set of lines. |
Creates a spherical surface or mesh. |
Creates a surface or mesh by rotating nodes, lines, or elements about a vector. |
Creates a surface or mesh with lines. |
Trims surfaces with lines or surfaces, untrims surfaces, and creates surfaces that fill gaps in the model. |
Creates surfaces using a variety of techniques. |
Creates a toroidal surface or mesh. |
Modify specific dimensions of solids, possibly altering their shapes. |
Trims/splits, merges, and performs Boolean operations on solids. |
Creates solid entities using various methods. |
