Engineering Solutions
Element Panels
Element Panels
Element Panels
one-dimensional
Bars
Creates or updates bar2 or bar3 elements.
Beam Xsect
Calculates beam section properties
Config Edit
Changes the configuration of existing elements.
Edges
Finds free edges and equivalences nodes on edges.
Features
Provides a visualization tool to see the edges of a complex model.
FE Joints
Creates, reviews, or updates joints.
Gaps
Creates or updates gap elements.
HyperBeam
Defines beam section entities before entering the HyperBeam module.
Linear 1D
Creates one-dimensional plot elements.
Line Mesh
Creates 1-D elements between nodes or along a line.
Masses
Creates or updates mass elements.
rbe3
Creates or updates RBE3 elements.
Rigids
Creates or updates rigid or rigidlink elements.
Rods
Creates or updates rod elements.
Spotweld
Creates or updates spotweld elements.
Springs
Creates or updates spring elements.
shells
Automesh
Interactively or automatically creates meshes on surfaces.
Cones
Creates a surface or mesh for cones or cylinders.
Config Edit
Detach
Detaches elements from adjoining elements.
Drag
Creates a surface or mesh by dragging nodes, lines, or elements.
Edit Element
Builds, combines, and splits elements.
Elem Offset
Creates solid elements or layers of plate or shell elements based on a plate or shell element by offsetting the shell elements in a direction normal to the surface they form.
Elem Types
Selects and changes existing element types.
Faces
Finds free faces and equivalences nodes of solid elements.
Line Drag
Creates a surface or mesh by dragging nodes, lines, or elements along a line.
Order Change
Changes elements from first to second order, or vise versa.
Penetration
Checks groups for initial penetration problems.
Planes
Creates a planar surface or mesh bounded by planar lines.
Ruled
Creates a surface or mesh from nodes or lines which are unconnected.
Skin
Creates a surface or mesh skin across a set of lines.
Smooth
Improves element quality on a surface mesh.
Spheres
Creates a spherical surface or mesh.
Spin
Creates a surface or mesh by rotating nodes, lines, or elements about a vector.
Spline
Creates a surface or mesh with lines.
Split
Splits elements into pre-defined patterns.
Torus
Creates a toroidal surface or mesh.
solids
Torus
CFD tetramesh
Create tetramesh for Computational Fluid Dynamics analyses.
Config Edit
Detach
Drag
Edit Element
Elem Offset
Elem Types
Line Drag
Linear Solid
Creates solid elements between two groups of plate elements.
Order Change
Smooth
Solid Map
Creates a solid mesh by defining source, destination, and along surfaces.
Solid Mesh
Creates a solid mesh within a volume defined by edge lines.
Spin
Split
Tetramesh
Allows you to fill an enclosed volume with first or second-order tetrahedral elements.
