Applies a displacement result to the nodes. |
Verifies the quality of elements. Checks warp, aspect, skew, angles, length, jacobian, connectivity, and duplicates. |
Changes the configuration of existing elements. |
Allows you to exchange some data between different solver formats |
Detaches elements from adjoining elements. |
Deletes data from the database. |
Finds nodes that have multiple DOF constraints. |
Finds the distance or angle between nodes. |
Finds free edges and equivalences nodes on edges. |
Performs many edge-specific alterations. |
Builds, combines, and splits elements. |
Selects and changes existing element types. |
Finds free faces and equivalences nodes of solid elements. |
Provides a visualization tool to see the edges of a complex model. |
Finds entities (and IDs) in the database. |
Combines lines, splits lines at a point, at a joint, at a line, or at a plane, and smoothes lines. |
Determines the length of a group of selected lines. |
Masks entities from the display list. |
Associates, moves, or places nodes on a surface. |
Displays and adjusts the normal of elements or surfaces. |
Displays the IDs of entities. |
Changes elements from first to second order, or vise versa. |
Checks groups for initial penetration problems. |
Switches x, y, z data of entities. |
Positions entities in space by selecting nodes. |
Projects entities to a plane, vector, or surface. |
Mirrors entities about a plane. |
Renumbers entities. |
Manually equivalences nodes. |
Rotates entities about a vector. |
Modifies the size of entities. |
Improves element quality on a surface mesh. |
Splits elements into pre-defined patterns. |
Trims surface with lines or surfaces, split surface edges, create lines from surface edges, and remove trim lines. |
Moves entities along a vector. |
