Groups can be created and edited from the Interface panel (Configurations 1-4), Rigid Wall panel (Configuration 5), and Ale Setup panel (Configuration 6). An LS-DYNA entity that utilizes a *SET_ [NODE, SHELL, PART, etc.] keyword card belongs to a group, with the exception of Rigid Bodies/RBE2’s.
REVIEW allows you to efficiently visualize the entities defining master and slave. A transparency mode as well as the ability to turn on/off master and slave entities is also available. In review mode, review opts allows you to customize the graphical review of the interfaces.
Use the Interface panel to define groups with configurations of 1, 2, 3, and 4. The difference among these configurations is the type of entities contained within the group.
Config 1
Holds master and slave elements.
Config 2
Holds master elements and slave nodes.
Config 3
Holds slave elements.
Config 4
Holds slave nodes.
Use the Rigid Wall panel to define a group with the configuration 5. This group configuration holds the additional geometric data for LS-DYNA rigid wall definitions.
Sliding Interfaces
• | Accessed via the Rigid Wall panel. |
• | The Keyword _TITLE option is supported. The _THERMAL(IREAD==3) option is not supported. |
• | Use the additional cards option in Keyword decks to select number of lines of data. If this is on, two additional cards are available. |
• | In Structured, additional cards are controlled by using the IREAD variable. Valid values are 0, 1, and 2. |
• | Boxes, part sets, and sets are supported. |
• | The $HMNAME fields are used for names. When using the _TITLE option, the 70-character field is considered a comment. |
• | If the line following the keyword (No TITLE option), or the first line of the Structured card contains $HM_NAME, the name supplied is read and used as the group's name. If the string $HM_ID also exists, this is used as the group’s ID. NAME is 16 characters, starting in Column 9. ID field is 8 characters, starting in Column 35. |
• | The HyperMesh interface type defines the general type of the LS-DYNA Sliding Interface. Use the card previewer to make changes to the LS-DYNA type. |
Engineering Solutions
Option
Keyword *CONTACT_
Structured
SlidingOnly
Defines a *CONTACT_SLIDING_ONLY_option card.
Off
<nothing>
Type 1
On
PENALTY
Type p1
SurfaceToSurface
Defines a *CONTACT_option_SURFACE_TO_SURFACE card.
None
<nothing>
Type 3
Automatic
AUTOMATIC_
Type a3
The None and Automatic options have an additional option to define a OneWayInterface. If this option is on, the following cards are created.
None and OneWay
ONE_WAY_
Type 10
Automatic and OneWay
AUTOMATIC_ONE_WAY_
Type a10
Constraint
CONSTRAINT_
Type 17
Eroding
ERODING_
Type 14
TieBreak
TIEBREAK_
Type 9
The Tied option has an additional option to define OFFSET.
Tied
TIED
Type 2
Tied and offset
TIED_OFFSET
Tiedshell
TIED_SHELL_EDGE
Tiedshell and offset
TIED_SHELL_EDGE_OFFSET
NodesToSurface
Defines a *CONTACT_option_NODES_TO_SURFACE card.
None
<nothing>
Type 5
Automatic
AUTOMATIC
Type a5
Constraint
CONSTRAINT_
Type 18
Eroding
ERODING_
Type 16
TieBreak
TIEBREAK_
Type 8
Tied
TIED_
Type 6
Tied and offset
TIED_OFFSET
SingleSurface
Defines a *CONTACT_option_SINGLE_SURFACE card.
none
<nothing>
Type 4
Automatic
AUTOMATIC_
Type 13
Airbag
AIRBAG_
Type a13
Eroding
ERODING_
Type 15
RgdBodyToRgd
Body
Defines a *CONTACT_RIGID_BODY_option_TO RIGID_BODY card
Off
ONE_WAY_
Type 21
On
TWO_WAY_
Type 19
RgdNodeToRgdBody
N/A
RIGID_NODES_TO_RIGID BODY
Type 20
DrawBead
N/A
DRAW_BEAD
Type 23
Interior
Defines a *CONTACT_INTERIOR card.
AutomaticGeneral
Defines a *CONTACT_AUTOMATIC_GENERAL card.
ForceTransducer
Defines a *CONTACT_FORCE_TRANSDUCER_option card
On
PENALTY
Off
CONSTRAINT
ContactSpotweld
Defines a *CONTACT_SPOTWELD card
none
Torsion
WITH_TORSION
ContactSIngEdge
Defines a *CONTACT_SINGLE_EDGE card
Supported Card
Solver Description
Supported Parameters
Notes
*ALE_MULTI-
MATERIAL_GROUP
Defines the appropriate ALE material groupings for interface reconstruction when many ALE Multi-Material Groups are present in a model.
PSID TBD
*ALE_REFERENCE_
SYSTEM_CURVE
Defines a motion and/or a deformation prescribed for a geometric entity (where a geometric entity may be any part, part set, node set or segment set).
curveCount
*ALE_REFERENCE_
SYSTEM_GROUP
Used to associate a geometric entity to a reference system type.
SID TBD, PRTYPE, XC, YC, ZC, EXPLIM
*ALE_REFERENCE_
SYSTEM_NODE
Defines a group of nodes that control the motion of an ALE mesh.
NodeCount
*ALE_REFERENCE_
SYSTEM_SWITCH
Allows many choices of the reference system types for any ALE geometric entity.
T1 - T7
TYPE1 - TYPE8
IdCount
*ALE_SMOOTHING
Smoothing constraint that keeps a node at its initial parametric location along a line between two other nodes.
IPRE, SNID TBD, MNID1 TBD, MNID2 TBD
*ALE_TANK_TEST
Allows for the airbag information input of the control volume approach to be used as input for the ALE/Eulerian fluid-structure interaction model of the airbag.
MDOTLC, TANKVOL, PAMB, PFINAL, MACHLIM, VELMAX, AORIF, AMMGIDG, AMMGIDA, NUMPNT
*BOUNDARY_AMBIENT_
EOS
Defines the IDs of 2 load curves: 1) internal energy per unit reference specific volume and 2) relative volume.
PID, LCID
*BOUNDARY_FLUX_SET
Define flux boundary conditions for a thermal or coupled thermal/structural analysis.
LCID, MLC1-4, LOC
Heat Flux Options (None, Function vs. Time, Function vs. Temperature)
*BOUNDARY_SPH_FLOW
Define a flow of particle
STYP, DOF, VAD, LCID, SF, DEATH, BIRTH, VID
*CONSTRAINED_BUTT_WELD
Define a line of coincident nodes that represent a structural butt weld between two parts defined by shell elements.
SNSID, MNSID, EPPF, SIGF, BETA
*CONSTRAINED_
LAGRANGE_IN_SOLID
Provides the coupling mechanism for modeling Fluid-Structure Interaction.
TITLE, NQUAD, CTYPE, DIREC, MCOUP, PSID TBD (START/END), PFAC, FRIC, FRCMIN, NORM, NORMTYP, DAMP, CQ, HMIN, HMAX, ILEAK, PLEAK, LCIDPOR, NVENT, IBLOCk
MCOUP_SetMultiMatGrp
PFAC_curve
OptionalCard
*CONSTRAINED_RIGID_
BODIES
Merge two rigid bodies.
PIDM, PIDS
*CONSTRAINED_SPOTWELD
Defines massless spot welds between non-contiguous nodal pairs.
*CONSTRAINED_TIE-
BREAK
Define a tied shell edge to shell edge interface that can release locally as a function of plastic strain of the shells surrounding the interface nodes.
SNSID TBD
MNSID TBD
*CONSTRAINED_TIED_
NODES_FAILURE
Define a tied node set with failure based on plastic strain.
EPPF, ETYPE, NSID TBD
TiedNodesFailureHelp
*CONTACT_AIRBAG_
SINGLE_SURFACE(ID)
Define a contact interface.
HEADING, SBOXID, MBOXID, SPR, MPR, SSID TBD, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_AIRBAG_
SINGLE_SURFACE_MPP
(ID)
HEADING, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID TBD, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTO_MOVE
Move the master surface in a contact definition to close an initial gap between the slave and master surfaces.
CID, VID, LCID, ATIME
*CONTACT_AUTOMATIC_
GENERAL(ID)
SlaveMasterAddHelp
interiorOption
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
GENERAL_INTERIOR(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
GENERAL_INTERIOR_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
GENERAL_MPP(ID)
SlaveMasterAddHelp
interiorOption
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
NODES_TO_SURFACE(ID)
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
SMOOTH
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
NODES_TO_SURFACE_
MPP(ID)
HEADING, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID TBD, MSID TBD,FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
NODES_TO_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
NODES_TO_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
ONE_WAY_SURFACE_TO
_SURFACE(ID)
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
ONE_WAY_SURFACE_TO
_SURFACE_ORTHO_FRICTION(ID)
SSID, MSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, FS1_S, FD1_S, DC1_S, VC1_S, LC1_S, QACS_S, LCFS, LCPS, FS2_S, FD2_S, DC2_S, VC2_S, LC2_S, FS1_M, FD1_M, DC1_M, VC1_M, LC1_M, QACS_M, LCFM, LCPM, FS2_M, FD2_M, DC2_M, VC2_M, LC2_M
Additionalcards
*CONTACT_AUTOMATIC_
ONE_WAY_SURFACE_TO
_SURFACE_SMOOTH(ID)
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
ONE_WAY_SURFACE_TO
_SURFACE_TIEBREAK
(ID)
HEADING, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, SFLS, CN
SlaveMasterAddHelp
AdditionalCards
*CONTACT_AUTOMATIC_
SINGLE_SURFACE(ID)
SlaveMasterAddHelp
SMOOTH
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR(ID)
HEADING, SSID, TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
SINGLE_SURFACE_MPP
(ID)
SlaveMasterAddHelp
SMOOTH
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
SINGLE_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
SINGLE_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE
(ID)
SlaveMasterAddHelp
mppOption
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_MORTAR
(ID)
HEADING, MSID, SSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_MORTAR_TIED
(ID)
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ORTHO_FRICTION(ID)
SSID, MSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, FS1_S, FD1_S, DC1_S, VC1_S, LC1_S, OACS_S, LCFS, LCPS, FS2_S, FD2_S, DC2_S, VC2_S, LC2_S, FS1_M, FD1_M, DC1_M, VC1_M, LC1_M, OACS_M, LCFM, LCPM, FS2_M, FD2_M, DC2_M, VC2_M, LC2_M
AdditionalCards
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_FRICTION(ID)
HEADING, MSID, SSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCFST, LCFDT, FORMULA, a, b, c, d, LCH
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_
TIEBREAK(ID)
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, OPTION, SFLS
SlaveMasterAddHelp
mppOption
*CONTACT_AUTOMATIC_
SURFACE_TO_SURFACE_
TIEBREAK_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_CONSTRAINT_
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, KPF
SlaveMasterAddHelp
mppOption
AdditionalCards
NODES_TO_SURFACE_
MPP(ID)
HEADING, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID TBD, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, KPF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
SURFACE_TO_SURFACE
(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
SURFACE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_DRAWBEAD
(ID)
HEADING, SBOXID, MBOXID, SPR, MPR, SSID, MSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCIDRF, LCIDNF, DBDTH, DFSCL, NUMINT, DBPID, ELOFF
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_DRAWBEAD_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCIDRF, LCIDNF, DBDTH, DFSCL, NUMINT, DBPID, ELOFF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ENTITY(ID)
Define a contact entity
PARTID, SF, df, cf, intord, SSID, BT, DT, SO, GO, AX, AY, AZ, BX, BY, BZ, InOut
ContEntityHelp
mppOption
*CONTACT_ENTITY_MPP
(ID)
TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, PARTID, SF, df, cf, intord, SSID, BT, DT, SO, GO, AX, AY, AZ, BX, BY, BZ, InOut
ContEntityHelp
OptionalCard
*CONTACT_ERODING_
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, ISYM, EROSOP, IADJ
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ERODING_
NODES_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, ISYM, EROSOP, IADJ
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ERODING_
SINGLE_SURFACE(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ERODING_
SINGLE_SURFACE_MPP
(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ERODING_
SURFACE_TO_SURFACE
(ID)
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, ISYM, EROSOP, IADF
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ERODING_
SURFACE_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, ISYM, EROSOP, IADF
SlaveMasterAddHelp
*CONTACT_FORCE_
TRANSDUCER_
CONSTRAINT(ID)
mppOption
AdditionalCards
*CONTACT_FORCE_
TRANSDUCER_
CONSTRAINT_MPP(ID)
IGNORE, BUCKET, LCBUCKET, NS2TRACK, INITITER, PARMAX, CPARM8, SSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
OptionalCard
AdditionalCards
*CONTACT_FORCE_
TRANSDUCER_PENALTY
(ID)
mppOption
AdditionalCards
*CONTACT_FORCE_
TRANSDUCER_PENALTY_
MPP(ID)
IGNORE, BUCKET, LCBUCKET, NS2TRACK, INITITER, PARAMAX, CPARM8, SSID, MSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
OptionalCard
AdditionalCards
*CONTACT_FORMING_NODES_TO_SURFACE(ID)
SlaveMasterAddHelp
SMOOTH
mppOption
AdditionalCards
*CONTACT_FORMING_
NODES_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID, MSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
NODES_TO_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_FORMING_
NODES_TO_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE(ID)
SlaveMasterAddHelp
SMOOTH
mppOption
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_CONSTRAINED
_OFFSET(ID)
Heading, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SMOOTH
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_CONSTRAINED
_OFFSET_MPP(ID)
SlaveMasterAddHelp
SMOOTH
OptionalCard
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_CONSTRAINED
_OFFSET_SMOOTH(ID)
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_CONSTRAINED
_OFFSET_SMOOTH_MPP
(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_FORMING_
ONEWAY_SURFACE_TO_
SURFACE_SMOOTH_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE
(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET
(ID)
SlaveMasterAddHelp
OneWay, SMOOTH
mppOption
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
OneWay, SMOOTH
OptionalCard
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET_
SMOOTH(ID)
SlaveMasterAddHelp
OneWay, SMOOTH
mppOption
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET_
SMOOTH_mpp(ID)
OneWay, SMOOTH
OptionalCard
*CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR(ID)
SlaveMasterAddHelp
mppOptions
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_FORMING_
SURFACE_TO_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_INTERIOR(ID)
Define interior contact for foam hexahedral and tetrahedral elements.
PSID
SlaveDefnSelectHelp
mppOption
*CONTACT_INTERIOR_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, PSID
*CONTACT_NODES_TO_
SURFACE(ID)
SlaveMasterAddHelp
SMOOTH
mppOption
AdditionalCards
*CONTACT_NODES_TO_
SURFACE_
INTERFERENCE(ID)
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, FSF, VSF, LCID1, LCID2
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_NODES_TO_
SURFACE_
INTERFERENCE_MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID, MSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID1, LCID2
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_NODES_TO_
SURFACE_MPP(ID)
SlaveMasterAddHelp
SMOOTH
OptionalCard
AdditionalCards
*CONTACT_NODES_TO_
SURFACE_SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_NODES_TO_
SURFACE_SMOOTH_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
Supported Cards
Solver Descriptions
Notes
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE
(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
INTERFERENCE(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
INTERFERENCE_
CONSTRAINED_OFFSET
(ID)
Heading, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID1, LCID2
SlaveMasterAddHelp
OneWay
mppOption
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
INTERFERENCE_
CONSTRAINED_OFFSET_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
SMOOTH(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_ONE_WAY_
SURFACE_TO_SURFACE_
SMOOTH_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
ONE_WAY_TO_RIGID_
BODY(ID)
Define rigid surface contact.
HEADING, SBOXID, MBOXID, SPR, MPR, SSID, MSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID, FCM, US, LCDC, DSF, UNLCID
SlaveMasterAddHelp
TwoWayOption
mppOption
AdditionalCards
ONE_WAY_TO_RIGID_
BODY_MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID, MSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID, FCM, US, LCDC, DSF, UNLCID
SlaveMasterAddHelp
TwoWayOption
OptionalCard
AdditionalCards
TWO_WAY_TO_RIGID_
BODY(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
TWO_WAY_TO_RIGID_
BODY_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_RIGID_NODES
_TO_RIGID_BODY(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
_TO_RIGID_BODY_MPP
(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_RIGID_
SURFACE(ID)
BOXID, SEGID, FS, FD, DC, VC, LCIDX, LCIDY, LCIDZ, FSLCID, FDLCID, SFS, STTHK, SFTHK, XPENE, BSORT
mppOption
*CONTACT_RIGID_
SURFACE_MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, BOXID, SEGID, FS, FD, DC, VC, LCIDX, LCIDY, LCIDZ, FSLCID, FDLCID, SFS, STTHK, SFTHK, XPENE, BSORT
Supported Cards
Solver Description
Notes
*CONTACT_SINGLE_
EDGE(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_SINGLE_
EDGE_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SINGLE_
SURFACE(ID)
HEADING, SBOXID, MBOXID, SPR, MPR, SSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_SINGLE_
SURFACE_MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, SSID, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SLIDING_
ONLY(ID)
HEADING, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
PenaltyOption
mppOption
AdditionalCards
*CONTACT_SLIDING_
ONLY_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SLIDING_
ONLY_PENALTY(ID)
SlaveMasterAddHelp
PenaltyOption
mppOption
AdditionalCards
*CONTACT_SLIDING_
ONLY_PENALTY_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SPOTWELD
(ID)
SlaveMasterAddHelp
Options (None, Torsion)
mppOption
AdditionalCards
*CONTACT_SPOTWELD_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SPOTWELD_
WITH_TORSION(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_SPOTWELD_
WITH_TORSION_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
Supported Cards
Solver Description
Notes
*CONTACT_SURFACE_TO
_SURFACE(ID)
Heading, SSID TBD, MSID TBD. SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
*CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT(ID)
HEADING, MSID, SSID, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, MTCJ, ALPHA, BETA, TSVX, TSVY, TSVZ
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_
INTERFERENCE(ID)
Heading, SSID TBD, MSID TBD. SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID1, LCID2
SlaveMasterAddHelp
OneWay
mppOption
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_
INTERFERENCE_
CONSTRAINED_OFFSET
SlaveMasterAddHelp
OneWay
mppOption
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_
INTERFERENCE_
CONSTRAINED_OFFSET_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD. SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, LCID1, LCID2
SlaveMasterAddHelp
OneWay
OptionalCard
AdditionalCard
*CONTACT_SURFACE_TO
_SURFACE_
SlaveMasterAddHelp
OneWay
OptionalCard
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_MPP(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
OptionalCard
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_SMOOTH(ID)
SlaveMasterAddHelp
OneWay, THERMAL, SMOOTH
mppOption
AdditionalCards
*CONTACT_SURFACE_TO
_SURFACE_SMOOTH_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_SURFACE_TO_SURFACE_THERMAL_FRICTION(ID)
SlaveMasterAddHelp
UseDefineFriction
mppOption
AdditionalCards
*CONTACT_THERMAL_
SURFACE_TO_SURFACE_(ID)
Heading, SSID TBD, MSID TBD. SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, K, FRAD, H0, LMIN, LMAX, CHLM, BC_FLAG, ALGO
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_THERMAL_
SURFACE_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD. SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, K, FRAD, H0, LMIN, LMAX, CHLM, BC_FLAG, ALGO
SlaveMasterAddHelp
OptionalCard
AdditionalCards
Supported Cards
Solver Description
Notes
*CONTACT_TIEBREAK_
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, NFLF, SFLF, NEN, MES
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_TIEBREAK_
NODES_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, NFLF, SFLF, NEN, MES
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIEBREAK_
SURFACE_TO_SURFACE
(ID)
Heading, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, NFLS, SFLS, TBLCID, THKOFF
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_TIEBREAK_
SURFACE_TO_SURFACE_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SSID TBD, MSID TBD, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFST, SFMT, FSF, VSF, NFLS, SFLS, TBLCID, THKOFF
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIED_NODES_
TO_SURFACE(ID)
HEADING, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFMT, FSF, VSF
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
TO_SURFACE_
CONSTRAINED_OFFSET
(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
TO_SURFACE_
CONSTRAINED_OFFSET_
MPP(ID)
Heading, TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, SBOXID, MBOXID, SPR, MPR, FS, FD, DC, VC, VDC, PENCHK, BT, DT, SFS, SFM, SST, MST, SFMT, FSF, VSF
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
OptionalCard
AdditionalCards
TO_SURFACE_MPP(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
OptionalCard
AdditionalCards
TO_SURFACE_OFFSET
(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
TO_SURFACE_OFFSET
_MPP(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
OptionalCard
AdditionalCards
*CONTACT_TIED_SHELL_
EDGE_TO_SURFACE(ID)
SlaveMasterAddHelp
TiedOptions (None, Offset, BeamOffset, Constrained Offset)
mppOption
AdditionalCards
EDGE_TO_SURFACE_
BEAM_OFFSET(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
EDGE_TO_SURFACE_
BEAM_OFFSET_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
EDGE_TO_SURFACE_
CONSTRAINED_OFFSET
(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
EDGE_TO_SURFACE_
CONSTRAINED_OFFSET_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
EDGE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
EDGE_TO_SURFACE_
OFFSET(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
EDGE_TO_SURFACE_
OFFSET_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE
(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET
(ID)
SlaveMasterAddHelp
OFFSET
CONSTRAINED_OFFSET
mppOption
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
CONSTRAINED_OFFSET_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
OFFSET(ID)
SlaveMasterAddHelp
mppOption
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
OFFSET_MPP(ID)
SlaveMasterAddHelp
OptionalCard
AdditionalCards
*CONTACT_TIED_
SURFACE_TO_SURFACE_
TITLE(ID)
Supported Cards
Solver Descriptions
Notes
*CONTACT_2D_
AUTOMATIC_SURFACE_
TO_SURFACE(ID)
Define a 2-dimensional contact or slide line.
*CONTACT_2D_
AUTOMATIC_SURFACE_
TO_SURFACE_THERMAL_
TITLE(ID)
Dyna_Name, SFACT, FREQ, FS, FD, DC, MEMBS, TBIRTH, TDEATH, SOS, SOM, NDS, NDM, IPF, INIT, K, FRAD, H0, LMIN, LMAX, CHLM, BC_FLAG, ALGO
SlaveMasterAddHelp
Options (Automatic)
mppOption
AdditionalCards
*CONTACT_2D_
AUTOMATIC_SURFACE_
TO_SURFACE_THERMAL_
TITLE_MPP(ID)
TRACKPEN, BUCKET, LCBUCKET, NSEG2TRACK, INITITER, PARMAX, CPARM8, Dyna_Name, SFACT, FREQ, FS, FD, DC, MEMBS, TBIRTH, TDEATH, SOS, SOM, NDS, NDM, IPF, INIT, K, FRAD, H0, LMIN, LMAX, CHLM, BC_FLAG, ALGO
SlaveMasterAddHelp
Options (Automatic)
OptionalCard
AdditionalCards
*CONTACT_2D_
AUTOMATIC_SURFACE_
TO_SURFACE_TITLE(ID)
SlaveMasterAddHelp
Options (Automatic)
THERMAL
mppOption
AdditionalCards
*CONTACT_2D_
AUTOMATIC_SURFACE_
TO_SURFACE_TITLE_MPP
(ID)
SlaveMasterAddHelp
Options (Automatic)
THERMAL
OptionalCard
AdditionalCards
*CONTACT_2D_AUTOMATIC_TIED_TITLE
Defines a 2-dimensional contact or slide line. May be used with rigid body material.
PSIDS, PSIDM, SFACT, FREQ, FS, FD, DC, TBIRTH, TDEATH, SOS, SOM, NDS, NDM, COF, INIT
SlaveMasterAddHelp
AdditionalCardA
*DATABASE_FSI
Used to output information about certain coupled Lagrangian surfaces.
PSID TBD
*DATABASE_NODAL_
FORCE_GROUP
Define a nodal force group for output into ASCII file NODFOR and the binary file XTFILE.
CID
Supported Cards
Solver Description
Notes
*ELEMENT_TRIM
Define a part subset to be trimmed by *DEFINE_CURVE_TRIM
*INITIAL_GAS_MIXTURE
Used to specify a) which ALE multi-material groups may be present inside an ALE mesh set at time zero and b) the corresponding reference gas temperature and density which define the initial thermodynamic state of the gases.
MMGID
TEMP
PSID TBD
RO1 - RO8
*INITIAL_VOID
(PART and SET)
Define initial voided part set IDs or part numbers.
n/a
*INITIAL_VOLUME_
FRACTION
Define initial volume fractions of different materials in multi-material ALE elements.
*INITIAL_VOLUME_
FRACTION_GEOMETRY
Volume filling command for defining the volume fractions of various ALE multi-material group that can occupy certain regions in some specified ALE mesh set.
BAMMG
NTRACE
FILLOPT
FAMMG
Supported Cards
Solver Description
Notes
*INTERFACE_
COMPONENT_NODE
Define an interface for linking calculations.
n/a
*INTERFACE_
COMPONENT_SEGMENT
n/a
*INTERFACE_LINKING_
DISCRETE_NODE_SET
Define an interface for linking discrete nodes to an interface file.
IFID
Edge
*INTERFACE_LINKING_
EDGE
Define an interface for linking a series of nodes in a shell structure to an interface file for the second analysis using L=isf2 on the execution command line.
IFID
*INTERFACE_LINKING_
SEGMENT
Define an interface for linking segments to an interface file for the second analysis using L=isf2 on the execution command line.
IFID
Supported Cards
Solver Description
Notes
*RIGIDWALL_GEOMETRIC
_CYLINDER_ID
Define a rigid wall with an analytically described form.
Name, exclude, BOXID, BIRTH, DEATH, Fric
_CYLINDER_MOTION_ID
_FLAT_ID
_FLAT (FINITE)
_FLAT_MOTION_ID
_FLAT_MOTION (FINITE)
_PRISM_ID
_PRISM_ID (FINITE)
_PRISM_MOTION_ID
_PRISM_MOTION (FINITE)
_SPHERE_ID
_SPHERE_MOTION_ID
Supported Cards
Solver Description
Notes
*SET_MULTI-
MATERIAL_GROUP_LIST
(TITLE)
Defines an ALE multi-material set ID which contains a collection of one or more ALE multi-material group IDs.
AMMGID1 - AMMGID8
