Engineering Solutions
HyperLaminate Environment
The HyperLaminate environment consists of five general areas, as shown here:
Menus
The HyperLaminate menu bar contains five menus that allow you to manage files, edit materials, laminates, HLS loadcases and design variables, change views, and access online help.
The HyperLaminate toolbar contains five tools that allow you to generate new materials, laminates, HLS loadcases or design variables, and to cut, copy, paste, and delete entries in text boxes.
This browser, located on the left side of the HyperLaminate window, provides a vertical tree view of materials, laminates, HLS loadcases and size design variables in your model.
Left-clicking on an entity populates the Define/Edit and Review panes with details of that branch.
Right-clicking on a branch offers context-sensitive operations for that branch.
This is the central pane of the HyperLaminate module. Here you may enter or change data related to a material, laminate, HLS loadcase or design variable definition (depending on the selected branch in the Laminate Browser).
This is the right-hand pane of the HyperLaminate module. The Review/Results pane has a number of tabs that display the current state of the selected branch.
h-lam_environment.zoom80
See Also:
HyperLaminate Module
Laminate Browser
Define/Edit Pane
Review Pane
HyperLaminate Solver
