Engineering Solutions
HyperLaminate Menus
HyperLaminate Menus
HyperLaminate Menus
The HyperLaminate menu bar contains five menus:
menubar
The following chart lists each menu option.
File
New
Generates a new entity, depending on the selected sub-topic in the Laminate Browser.
Export to File
Exports material and laminate information to a text file. This text file can be printed.
Exit
Exit HyperLaminate.
At this point the current HyperMesh database is updated with the information in the current HyperLaminate session.
Edit
Cut
Removes the selected data from an entry field and places it on the clipboard for pasting.
Can also remove rows from a ply lay-up order table and place these on the clipboard for pasting.
Copy
Places selected data from an entry field on the clipboard for pasting.
Can also place rows from a ply lay-up order table on the clipboard for pasting.
Paste
Pastes data from the clipboard in selected entry fields.
Can also paste rows from the clipboard above selected rows on a ply lay-up order table.
Delete
When the cursor is active in the Laminate Browser, this deletes the selected entity from the Laminate Browser. (A dialog is displayed to confirm the deletion).
When the cursor is active in the Define/Edit pane, this deletes the selected text from a text box or the selected rows from a ply lay-up order table.
Tools
Laminate Options
Displays the Laminate Options dialog.
plylayupoptions
This dialog allows you to select defaults for new Laminates for:
color
Convention
Repetitions
Ply thickness
Common thickness
HLS Options
Displays the HLS Options dialog.
hls_options_dialog.zoom80
This allows you to retain the input and result files for the HyperLaminate Solver. You can also choose the location these files are written to.
The default behavior is to delete these files once HLS is run.
View
Toolbar
Display/hide toolbar.
Status Bar
Display/hide status bar.
Help
About HyperLaminate
Displays version, contact, and copyright information.
Help Topics
Activates the HyperLaminate online help.
See Also:
HyperLaminate Module
Laminate Browser
Define/Edit Pane
Review/Results Pane
