The Individual nodes option allows you to define the *SURFACE, TYPE = NODE card by specifying individual node IDs. In the graphic area, these nodes are displayed by special single node elements with a SurfaceNodes tag.
The Individual nodes option has the following buttons:
Pick Nodes |
Opens the Node Selector panel and allows you to pick nodes the graphic area. The selected nodes will be highlighted. The corresponding Reset button resets the selected nodes. |
Add |
Adds the selected nodes to the current surface and creates special single-node SurfaceNodes elements for display. The Add button does not check for duplicates and there is no Reject button. |
