Engineering Solutions
Node Based Surface: Define Tab
The Define tab allows you to define surfaces with individual nodes.  You can also define the surface by specifying a node set.  There are two available surface definition options:
Individual nodes
Node set
The layout of the Define tab changes based on your selections.
See Also:
Node Based Surface: Delete Surface Node Tab
Node Based Surface: Optional Parameters Tab
Node Based Surface
