Engineering Solutions
Load Collectors entityLoadCollectors-24
Previous topic Next topic Expand/collapse all hidden text
Load collectors collect and organize loads and equations.  Load collectors are created, edited, and deleted from the Model browser and are shown under the LoadCollector folder.
Loads and equations can be organized into a load collector using the Organize panel.  Every load and equation must be organized into one, and only one, load collector and therefore are mutually exclusive to a load collector.  Newly created loads and equations are automatically organized into the current load collector.
The current load collector is shown in the status bar and is also bold in the Model browser.  The current load collector can be set using the Model browser context menu on a selected load collector within the LoadCollector folder.  Load collectors can also be card edited using the Model browser context menu on selected load collectors within the LoadCollector folder.
Load collectors have a display state, on or off, which control the display of all loads and equations organized within the load collector in the graphics area.  The display state of a load collector can be controlled using the icons next to the load collector in the Model browser.  Geometry and element display states can be controlled separately for load collectors.
Load collectors also have an active and export state.  The active state of a load collector controls the display state of the load collector and the listing of the load collector in the Model browser and any of its views.  If a load collector is active, then its display state is available to be turned on or off and it is listed in the Model browser and any of its views.  If a load collector is inactive, then its display state is turned off permanently and it is not listed in the Model browser or any of its views.  If a find operation "finds" an inactive load collector, that load collector will automatically be set to active.
The export state of a load collector controls whether or not that load collector and all loads and equations organized within the load collector are exported when the custom export option is utilized.  The all export option is not affected by the export state of a load collector.  The active and export states of load collectors can be controlled using the Entity State browser.
Operations performed on a load collector affect loads and equations within the load collector.  For example, if you delete a load collector, the loads and equations within the load collector are also deleted.
The data names associated with load collectors can be found in the data names section of the HyperMesh Reference Guide.
Solver Card Support for Load Collectors
hmtoggle_arrow1RADIOSS
When working with RADIOSS (Block Format), Engineering Solutions requires that all the loads be placed in the load collectors with one of the following valid card images:
Supported Cards
Solver Description
Supported Parameters
Notes
/ACTIV
Describes the deactivation/activation of element groups.
/ALE/BCS
Describes the ALE boundary conditions.
/BCS
Defines boundary conditions.
ALE_BCS_option
RADIOSS_COMMENT_FLAG
Translation_Vx
Translation_Vy
Translation_Vz
Rotation_Wx
Rotation_Wy
Rotation_Wz
/CLOAD
Describes the concentrated loads.
GRNodeBox
/CONVEC
Describes the imposed convective flux.
Surface Type (Sets, ContactSurfs, Blocks)
/DFS/DETLINE
Describes the line detonators
/DFS/DETPOIN
Describes the point detonators.
/DFS/LASER
/DFS/WAV_SHA
/EBCS
Describes the elementary boundary condition sets.
/GRAV
Describes the gravity load.
GRNodeBox
/IMPACC
Describes the imposed accelerations.
GRNodeBox
/IMPDISP
Describes the imposed displacements.
/IMPTEMP
Defines imposed temperatures on a group of nodes.
/IMPVEL
Describes the imposed velocities.
/INITEMP
Describes the initial nodal temperature.
/INIVEL
Describes the initial velocities.
/INIVEL/AXIS
Describes the initial velocities around the axis.
/LOAD/CENTRI
Computes a load according to the rotational velocity around an axis.
Grnod_Options (Set, Block)
/LOAD/PFLUID
Build simple fluid pressure effect model on a structure.
/PLOAD
Describes the pressure loads.
/SPHBCS
Describes the SPH symmetry conditions.
/SPH/INOUT
Describes the SPH inlet/outlet conditions.
There are two choices for assigning loads to a load collector:
Create individual loads, all of the same type and degree of freedom, and store them in the appropriate load collector.
Identify the nodes on which loads/BCs act by selecting them through a set.  The selection of the set is possible by editing the card image of the load collector.
hmtoggle_arrow1OptiStruct
Specific load collectors are used for specialized loading cards, such as EIGRL, SPCADD, GRAV, RLOAD, DTABLEi, etc.  Specific load collectors have card images, which can be edited to do the following:
Group other load collectors together for simultaneous application in a single subcase.
Provide special information for a specific analysis type (such as modal analysis, or frequency response analysis).
General boundary conditions should not be collected into specific load collectors.  Organizing loads and constraints into a specific load collector may result in an error termination.
The following is a list of OptiStruct cards, which are represented as specific load collectors.
Supported Cards
Solver Description
Notes
ACSRCE
Defines acoustic source as a function of power vs. frequency.
DELAY_OPTION
DPHASE_OPTION
CAALOAD
Defines the CFD pressure that is transferred to the structural side for frequency response analysis.
CDSMETH
Used in the component dynamic synthesis method for generating component dynamic matrices at each loading frequency.
CMSOUT
CMSMETH
Defines the method, frequency upper limit, and number of modes to be used in component mode synthesis for flexibly-body preparation solution sequence.
TYPE (Structure Only, Fluid Structure)
PRELOAD
LOADSET
DMIGDV
CNTSTB
Parameters for Stabilization Control of Surface-to-Surface (S2S) Contact and Large Displacement Node-to-Surface (N2S) Contact
Refers to Subcase information entry CNTSTB
DLOAD
Defines a dynamic loading condition for frequency response problems as a linear combination of load sets defined via RLOAD1 and RLOAD2 entries, or for transient problems as a linear combination of load sets defined via TLOAD1 and TLOAD2 entries.
DTI, SPECSEL
Correlates spectra lines specified on TABLED1 entries with damping values.
EIGC
Defines data needed to perform complex eigenvalue analysis.
EIGRA
Defines the data needed to perform real eigenvalue analysis with the Automated Multi-Level Sub-structuring technique.
EIGRL
Defines data needed to perform real eigenvalue analysis (vibration or buckling) with the Lanczos Method.
FATDEF
Defines elements, and associated fatigue properties, for consideration in a fatigue analysis.
ELSET
PSHELL
PSOLID
XELSET
XELEM
FATEVNT
Defines loading events for fatigue analysis.
FATLOAD
Defines fatigue loading parameters.
FATEVNT_NUM_FLOAD
FATPARM
Defines fatigue analysis parameters.
FATSEQ
Defines a loading sequence for fatigue analysis.
FATSEQ_NUM
FLLWER
Parameters for Calculation of Loads Dependent on Deformation
FREQ
Defines a set of frequencies to be used in the solution of frequency response problems.
FREQ
FREQ1 - FREQ5
FREQ1
Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
FREQ
FREQ1 - FREQ5
Defined using FREQi
FREQ2
Alternative form of frequency list. Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, final frequency, and the number of logarithmic increments desired.
FREQ
FREQ1 - FREQ5
Defined using FREQi
FREQ3
Frequency List, Alternate Form 3. Defines a set of frequencies for the modal method of frequency response analysis by specifying the number of frequencies between modal frequencies.
FREQ
FREQ1 - FREQ5
Defined using FREQi
FREQ4
Frequency List, Alternate Form 4. Defines a set of frequencies for the modal method of frequency response analysis by specifying the amount of "spread" around each modal frequency and the number of equally spaced frequencies within the spread.
FREQ
FREQ1 - FREQ5
Defined using FREQi
FREQ5
Frequency List, Alternate Form 5. Defines a set of frequencies for the modal method of frequency response analysis by specification of a frequency range and fractions of the natural frequencies within that range.
FREQ
FREQ1 - FREQ5
Defined using FREQi
FSI
Defines the settings for Fluid Structure Interaction Analysis with AcuSolve.
GRAV
Defines the gravity vectors for use in determining gravity loading for the structural model.
HYBDAMP
Defines the application of modal damping to the residual structure in a direct or transient frequency response analysis.
INVELB
Defines initial velocity in a multi-body situation.
LOAD
Defines a static load as a linear combination of load sets defined via FORCE, MOMENT, FORCE1, MOMENT1, PLOAD, PLOAD1, PLOAD2, PLOAD4, RFORCE, and GRAV entries.
LOAD_Num_Set
MBACT
Defines the entity/set to be activated in the multi-body system for the subsequent simulation.
THRU
MBACT_NUMIDS
MBDEACT
Defines the entity/set to be deactivated in the multi-body system for the subsequent simulation.
THRU
MBEACT_NUMIDS
MBLIN
Defines the parameters for a multi-body system linear analysis.
MBREQ
Defines a multi-body as a combination of request sets defined via MBREQE, MBREQM.
R1
MBREQ_NUM
MBREQE
Defines a multi-body solver output request to output the results of a set of expressions.
MBREQM
Defines a multi-body solver output request to output displacement, velocity, acceleration, or force with respect to markers.
MBSEQ
Defines the simulation sequence for the multi-body solver.
MBSEQ_NUM_ID
MBSIM
Defines the parameters for a multi-body simulation.
Simulation Type (Transient, Static, Quasi-static)
MBSIMP
Parameters for subsequent multi-body simulation.
MBVAR
Defines a multi-body solver variable which can be referred to by multiple Expressions.
EXPR
MBVAR_NUM_EQ
MFLUID
Defines the parameters and damp shell elements for a fluid volume.
CID, ZFS, RHO, WSURF1, WSURF2, PLANE1, PLANE2, RMAX
MLOAD
Defines a multi-body as a linear combination of load sets defined via GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, MBSMNTE.
MLOAD_NUM_L
MOTION
Defines a multi-body as a combination of motion sets defined via MOTNJ, MOTNJC, MOTNJE, MOTNG, MOTNGC, MOTNGE
MOTION_Num_Set
MPCADD
Multi-point constraint set combination.
Number_Of_Sets
NLADAPT
Parameters for Nonlinear Analysis to define time-stepping and convergence criteria.
Refers to Subcase information entry NLADAPT.
NLOAD
Defines a loading condition for nonlinear problems as a linear combination of load sets defined via NLOAD1.
NLOAD_NUM
NLOAD1
Defines a time-dependent load or enforced motion for use in geometric nonlinear analysis.
SENSID_OPTION
NLOUT
Controls the incremental result output for Small Displacement Nonlinear Analysis and Large Displacement Analysis.
Refers to Subcase information entry NLOUT.
NLPARM
Defines parameters for nonlinear static analysis iteration strategy.
NLPARMX
NLPARMX
Defines additional parameters for geometric nonlinear implicit static analysis
Supported as an extension to the NLPARM load collector.
TOUT
NSMADD
Defines non-structural mass as the sum of the sets listed.
PEAKOUT
The PEAKOUT command can be used in the Subcase Information section to select the criteria for automatic identification of loading frequencies at which result peaks occur.  Other result output may then be requested at these “peak” loading frequencies.  This data selector is for frequency response solution sequences only.
NUM_PEAKOUT
NUM_GRIDC
PFAT
Defines element properties for fatigue analysis
FINISH_REAL
TREATMENT_REAL
PFPATH
Entry for One-Step Transfer Path Analysis.
PTADD
Defines a pretension load as a linear combination of load sets defined via PTFORCE, PTFORC1, PTADJST and PTADJS1 entries.
RANDPS
Power Spectral Density Specification
RANDT1
RFORCE
Defines a static loading condition due to a centrifugal force field.
RGYRO
Bulk Data Entry for the inclusion of data required to perform Rotor Dynamics analysis in Modal Frequency Response Analysis and/or Modal Complex Eigenvalue Analysis. The RGYRO Bulk Data Entry is referenced by a corresponding RGYRO Subcase Information Entry in a specific subcase.
SYNCFLG, REFROTR, SPDUNIT, SPDLOW, SPDHIGH, SPEED_ID
RLOAD1
Defines a frequency-dependent dynamic load for use in frequency response problems.
rload1new
DELAY_OPTION
DPHASE_OPTION
RLOAD2
rload2_equation
DELAY_OPTION
DPHASE_OPTION
RSPEC
Defines a directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for response spectrum analysis.
RSPEED
Specifies a set of reference rotor speed values for asynchronous analysis in Rotor Dynamics.
S1, DS, NDS
RWALADD
Defines a rigid wall set as a union of rigid walls defined via RWALL entries.
RWALADD_Num_set
SOLVTYP
Defines the solver to be used for static analysis.
Solver Type (PCG, BCS, MIXED, AUTO, MUMPS)
SPCADD
Single-point constraint set combination.
SPCADD_Num_Set
TABDMP1
Defines modal damping as a tabular function of natural frequency.
TABDMP1_NUM
TABFAT
Defines y values of each point on the loading time history.
TABLED1
Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.
TABLED1_NUM
TABLED2
Dynamic Load Tabular Function, Form 2. Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.  Also contains parametric data for use with the table.
TABLED2_NUM
TABLED3
Dynamic Load Tabular Function, Form 3. Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.  Also contains parametric data for use with the table.
TABLED3_NUM
TABLED4
Dynamic Load Tabular Function, Form 4.Defines the coefficients of a power series for use in generating frequency-dependent and time-dependent dynamic loads.  Also contains parametric data for use with the table.
TABLEM1
Defines a tabular function for use in generating temperature-dependent material properties.
TABLEM2
Material Property Table, Form 2. Defines a tabular function for use in generating temperature-dependent material properties.  Also contains parametric data for use with the table.
TABLEM3
Material Property Table, Form 3. Defines a tabular function for use in generating temperature-dependent material properties.  Also contains parametric data for use with the table.
TABLEM4
Material Property Table, Form 4. Defines coefficients of a power series for use in generating temperature-dependent material properties.  Also contains parametric data for use with the table.
TABLES1
Defines a tabular function for use as stress-strain curve in one-step stamping material property MATHF
TABLES1_NUM
TABLEST
Specifies the material property tables for elasto-plastic, temperature-dependent materials.
TABRND1
Defines power spectral density as a tabular function of frequency for use in random analysis.
TABRND1_NUM
TEMPD
Defines a temperature value for all grid points of the structural model that have not been given a temperature on a TEMP entry.
TICA
Explicit Analysis Initial Velocity Relative to an Axis.
GA, GB
TLOAD1
Defines a time-dependent dynamic load or enforced motion of the form:
trans_cond_eqa
for use in transient response analysis.
DELAY OPTION
TLOAD2
Defines a time-dependent dynamic excitation or enforced motion of the form:
trans__cond_eq1
for use in a transient response problem, where
tload2_where
DELAY OPTION
TSTEP
Defines time step intervals at which a solution will be generated and output in transient analysis.
TSTEPNL
Defines parameters for geometric nonlinear implicit dynamic analysis strategy.
TSTEPNX
TSTEPNX
Defines additional parameters for geometric nonlinear implicit dynamic analysis.
Supported as an extension to the TSTEPNL load collector.
TOUT
UNBALNC
Defines the unbalanced rotating load during a rotor dynamic analysis in Frequency Response solution sequences. The unbalanced load is specified in a cylindrical system where the rotor rotation axis is the Z-axis.
MASS, GRID, X1, X2, X3, ROFFSET, THETA, ZOFFSET, FON, FOFF
XHISADD
Defines a time history output set as a union of time history outputs defined via XHIST entries.
XHISADD_Num_set
XSTEP
Defines explicit analysis control.
XSTEP_NUM
hmtoggle_arrow1Abaqus
A load collector is a repository for loads and constraints.  Each load or constraint must belong to a load collector.  There are two card images called HISTORY and INITIAL_CONDITION.  Loads or constraints that are to be used as history data (under *STEP) should be collected into load collectors with the HISTORY card image.  These load collectors also need to be added to the corresponding load steps (*STEP) from the load steps panel.  In contrast, loads or constraints for model data should be collected into load collectors with INITIAL_CONDITION card image.  They will automatically be written out in the model portion of the Abaqus input deck.
Note:The Import tab - Options section provides the user to select to Expand Loads on Sets. Selecting this option means that all loads and boundary conditions on sets are expanded to individual nodes and elements.
Supported Card
Solver Description
Notes
*CFILM
Define film coefficients and associated sink temperatures at one or more nodes or vertices
AMPLITUDE, FILM AMPLITUDE, REGION TYPE = {LAGRANGIAN/SLIDING, EULEREIAN}, OP
Only in HISTORY card image
*CONNECTOR HARDENING
*CONNECTOR LOAD
Specify loads for available components of relative motion in connector elements
AMPLITUDE, LOAD CASE, OP
*CONNECTOR MOTION
Specify the motion of available components of relative motion in connector elements
In both HISTORY and INTIAL_CONDITION card image
*DSLOAD
Specify distributed surface loads
AMPLITUDE, LOAD CASE, CYLIC MODE, OP
*INERTIA RELIEF
Apply inertia-based load balancing
FIXED, ORIENTATION, REMOVE
Only in HISTORY card image of Standard template
*INITIAL_CONDITION_FLUID_PRESSURE
Specifies initial pressures for hydrostatic fluid filled cavities.
*INITIAL_CONDITION_TEMPERATURE
Specifies initial temperatures for heat transfer analysis.
*INITIAL_CONDITION_TYPE_STRESS
Specifies initial stresses.
*INITIAL_CONDITION_VELOCITY
Specifies initial velocities for dynamic analysis.
*SFILM
Define film coefficients and associated sink temperatures over a surface for heat transfer analysis
AMPLITUDE, FILM AMPLITUDE, OP
hmtoggle_arrow1LS-DYNA
Load collector information is specified with a required $HMNAME comment card and an optional $HMCOLOR comment card.  If an input translator encounters one of these comments while reading a load card, a new load collector is created.  For the comments to be valid, they must follow a load keyword or the last line of the previous Structured block.  The loads that follow a $HMNAME LOADCOLS comment are read into that collector.  If there is a new keyword or structured block, the previous load collector information is ignored.
For non-Engineering Solutions generated input decks, loads are divided into collectors based on classification.  The following load collectors are created:
Mechanical loads for forces and moments
Constraints/Displacements
Velocities
Accelerations
Pressures
If translational or rotational constraints are defined in the input model, they are placed in a separate load collector named Nodal Constraints.
Load collectors are not used by LS-DYNA, but are useful for visualization.  Additional load collectors can be defined to describe other entities.
Supported Cards
Solver Description
Notes
*BOUNDARY_
CONVECTION_SET
Define convection boundary conditions for a thermal or coupled thermal/structural analysis. Two cards are defined for each option.
SSID, HLCID, HMULT, TLCID, TMULT, LOC
*BOUNDARY_NON_
REFLECTING
Define a non-reflecting boundary.
SSID, AD, AS
2D_Option
*BOUNDARY_NON_
REFLECTING_2D
NSID
*BOUNDARY_RADIATION_SET
Defines surface segment sets that transfer energy by radiation to the environment.
SSID, TYPE, RAD_GRP, FILE_NO, RFLCID, RFMULT, TILCID, TIMULT
*BOUNDARY_SPC_SET
Define nodal single point constraints.
NSID, CID, DOFX, DOFY, DOFZ, DOFRX, DOFRY, DOFRZ
Title
*BOUNDARY_SPC_SET_
ID
Dyna_Name
*BOUNDARY_
TEMPERATURE_SET
Define temperature boundary conditions for a thermal or coupled thermal/structural analysis.
NCID, LCID, CMULT, LOC
*CONSTRAINED_RIGID_
BODY_STOPPERS
Stops the motion based on a time dependent constraint. The stopper overrides prescribed motion boundary conditions (except relative displacement) operating in the same direction for both the master and slaved rigid bodies.
PID, LCMAX, LCMIN, PSIDMX, PSIDMN, LCVMNX, DIR, VID, TB, TD
LCMAX_as_displacment
LCMIN_as_displacement
*DEFINE_CURVE_
FEEDBACK
Define information that is used as the solution evolves to scale the ordinate values of the specified load curve ID.
LCID, PID, BOXID, FLDID, FSL, TSL, SFF, SFT, BIAS
Title
*DEFINE_CURVE_
FEEDBACK_TITLE
Title, LCID, PID, BOXID, FLDID, FSL, TSL, SFF, SFT, BIAS
*DEFORMABLE_TO_RIGID
Define materials to be switched to rigid at the start of the calculation.
ArrayCount
PSID, MRB
DeformToRigidHelp
Options (NONE, AUTOMATIC)
Select an arraycount for the PSID and MRB pairs.
_AUTOMATIC
Define materials to be switched to rigid or to deformable at some stage in the calculation.
SWSET, CODE, TIME1, TIME2, TIME3, ENTNO, RELSW, PAIRED, NRBF, NCSF, RWF, DTMAX, #D2R, #R2D
DeformToRigidHelp
D2R_Flag
R2D_Flag
Change the option to automatic and card edit. In the D2R fields enter the number of PIDs that need to be converted to Rigid.  Create an entity set of comps of the slave PIDs and select the set.
_INERTIA
Inertial properties can be defined for the new rigid bodies that are created when the deformable parts are switched. These can only be defined in the initial input if they are needed in a later restart.
PID, XC, YC, ZC, TM, IXX, IXY, IXZ, IYY, IYZ, IZZ
*INITIAL_AXIAL_FORCE_
BEAM
Initialize axial force in the beam for modeling bolt
BSID, LCID
*INITIAL_DETONATION
Define points to initiate the location of high explosive detonations in part IDs which use the material (type 8) *MAT_HIGH_EXPLOSIVE_BURN.
PID, X, Y, Z, LT
PartOption
*INITIAL_STRESS_
SECTION
Initialize stress in solid sections
CSID, LCID, PSID, VID
*INITIAL_TEMPERATURE_
SET
Define initial nodal point temperatures using nodal set IDs or node numbers.
NSID, TEMP, LOC
*INITIAL_VEHICLE_
KINEMATICS
Define initial kinematical information for a vehicle.
GRAV, PSID, XO, YO, ZO, XF, YF, ZF, VX, VY, VZ, AAXIS, BAXIS, CAXIS, AANG, BANG, CANG, WA, WB, WB
*INITIAL_VELOCITY
Define initial nodal point translational velocities using nodal set IDs. This may also be used for sets in which some nodes have other velocities.
Card 30
NSID, NSIDEX, BOXID, IRIGID, VX, VY, VZ, VXR, VYR, VZR
Options (NONE, Generation, Rigidbody)
InitialVel
This card changes the INITV definition on Control Card 11.  Only the first card defined is valid for Structured.
*INITIAL_VELOCITY_GENERATION
Define initial velocities for rotating and translating bodies.
PSID, OMEGA, VX, VY, VZ, IVATN, XC, YC, ZC, NX, NY, NZ, PHASE
STYP (Part Set ID, Part ID, Node Set ID, ENTIRE MODEL)
*INITIAL_VELOCITY_GENERATION_START_TIME
Define a time to initialize velocities after time zero.
STIME
*INITIAL_VELOCITY_RIGID_
BODY
Define the initial translational and rotational velocities at the center of gravity for a rigid body or a nodal rigid body.
PID, VX, VY, VZ, VXR, VYR, VZR
*INTERFACE_
SPRINGBACK
Define a material subset for an implicit springback calculation in LS-DYNA and any nodal constraint to eliminate rigid body degrees-of-freedom.
PSID, NSHV, FTYPE
Option1 (NONE, LSDYNA, NASTRAN, SEAMLESS)
Option2 (None, THICKNESS, NO THICKNESS)
*INTERFACE_
SPRINGBACK_LSDYNA
PSID, NSHV, FTYPE
Option1 (LSDYNA, NASTRAN, SEAMLESS, NONE)
Option2 (None, THICKNESS, NOTHICKNESS)
*INTERFACE_
SPRINGBACK_LSDYNA_
NOTHICKNESS
Define a material subset for an implicit springback calculation in LS-DYNA and any nodal constraints to eliminate rigid body degrees-of-freedom.
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_LSDYNA_
THICKNESS
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_NASTRAN
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_NASTRAN_
NOTHICKNESS
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_NASTRAN_
THICKNESS
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_SEAMLESS
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_SEAMLESS
_NOTHICKNESS
PSID, NSHV, FTYPE
*INTERFACE_
SPRINGBACK_SEAMLESS
_THICKNESS
PSID, NSHV, FTYPE
*LOAD_BEAM_SET
Defines load on beam element set
ESID, DAL, LCID, SF
*LOAD_BLAST
Define an airblast function for the application of pressure loads due to explosives in conventional weapons.
WGT, XBO, YBO, ZBO, TBO, IUNIT, ISURF, CFM, CFL, CFT, CFP
*LOAD_BODY_
GENERALIZED
Define body force loads due to a prescribed base acceleration or prescribed angular velocity over a subset of the complete problem.
Card 46
N1, N2, LCID, DRLCID, XC, YC, ZC, AX, AY, AZ, OMX, OMY, OMZ
*LOAD_BODY_PARTS
Define body force loads due to a prescribed base acceleration or angular velocity using global axes directions
Card 45
PSID
Select component set.
*LOAD_BODY_X
Define body force loads due to a prescribed base acceleration using global axes directions
Card 39
LCID, SF, LCIDDR, CID
Activate the proper option and enter the data.  Only the first card defined is valid for Structured.
*LOAD_BODY_Y
Card 40
*LOAD_BODY_Z
Card 41
*LOAD_BODY_RX
Define body force loads due to a prescribed angular velocity using global axes directions
Card 42
LCID, SF, LCIDDR, XC, YC, ZC, CID
*LOAD_BODY_RY
Card 43
*LOAD_BODY_RZ
Card 44
*LOAD_BRODE
Define Brode function for application of pressure loads due to explosion.
YLD, BHT, XBO, YBO, ZBO, TBO, TALC, SFLC, CFL, CFT, CFP
*LOAD_MASK
Apply a distributed pressure load over a three-dimensional shell part.
PID, LCID, VID1, OFF, BOXID, LCIDM, VID2, INOUT, ICYCLE
*LOAD_NODE_SET
Apply a concentrated nodal force to a node or a set of nodes.
NSID, DOFX, LCID, SF, CID
FollowerForce
*LOAD_RIGID_BODY
PID, DOF, LCID, SF, CID, M1, M2, M3
LCID_as_displacement
*LOAD_SEGMENT_SET
Apply the distributed pressure load over each segment in a segment set.
SSID, LCID, SF, AT
LCIDoption
*LOAD_SHELL_SET
Apply the distributed pressure load over one shell element or shell element set.
ESID, LCID, SF, AT
LCIDoption
*LOAD_SUPERELASTIC_
FORMING
LCP1, CSP1, NCP1, LCP1, CSP1, NCP1, ERATE, SCMIN, SCMAX, NCYL
*LOAD_THERMAL_
CONSTANT
Define nodal sets giving the temperature that remains constant for the duration of the calculation.
NSID, INSIDEX, BOXID, T, TE
*LOAD_THERMAL_LOAD_
CURVE
LCID, LCIDDR
*LOAD_THERMAL_
VARIABLE
Define nodal sets giving the temperature that is variable in the duration of the calculation.
NSID, NSIDEX, BOXID, TS, TB, LCID, TSE, TBE, LCIDE
hmtoggle_arrow1Nastran
There are two types of load collectors for Nastran:
Specific load collectors with a card image
Generic load collectors without a card image
Generic load collectors are used to collect loads and constraints for display purposes and to assign an ID to the loads. Specific load collectors are used for specialized loading cards, such as SPCADD, MPCADD, EIGRL, EIGB, EIGC, EIGP, EIGR, FREQ, FREQ1, LOAD, GRAV, RFORCE, and TEMPD.  Specific load collectors have card images which can be edited to do the following:
Provide special information for a specific analysis type (such as modal analysis)
General boundary conditions, such as loads and constraints, should not be collected into specific load collectors.
When reading in a Nastran deck, loads that have the same SID are collected into the same load collector.  If a load collector already exists in the database with the same SID, one of the following can occur:
If overwrite is off (default), the new load collector’s ID is offset and all loads in that collector will have a new SID upon export.
If overwrite is on, the new load collector replaces the existing load collector.  The original load collector and the loads it contains are deleted.
Supported Cards
Solver Description
Notes
ACSRCE
Defines the power versus frequency curve for a simple acoustic source.
EXCITEID, DELAY, DPHASE, TP, RHO, B
DELAY_OPTION
DPHASE_OPTION
AEFACT
Defines real numbers for aeroelastic analysis.
Total_Number
BCPARA
Defines contact parameters.
PARAM, VALUE
BCPARA_NUM
BCRPARA
SURF, OFFSET, TYPE, MGP
BMFACE
DAMPING
Defines a parameter and hybrid damping specification.
G, ALPHA1, ALPHA2, HYBRID, GEFACT, W3, W4, WH
DELAY
Defines the time delay term in the equations of the dynamic loading function
Supported as constraints
DLOAD
Defines a dynamic loading condition for frequency response or transient response problems as a linear combination of load sets defined via RLOAD1 or RLOAD2 entries for frequency response or TLOAD1 or TLOAD2 entries for transient response
DLOAD_NUM
DTI SPECSEL
Defines table data blocks
SPECSEL, RECNO, TYPE, TID, DAMP
DTI_TID_NUM
EIGB
Defines data needed to perform buckling analysis
contOpt
EIGC
Cont
EIGP
Defines poles that are used in complex eigenvalue extraction by the Determinant method
n/a
EIGR
contOpt
EIGRL
Defines data needed to perform real eigenvalue (vibration or buckling) analysis with the Lanczos method
n/a
FLFACT
Used to specify density ratios, Mach numbers, reduced frequencies, and velocities for flutter analysis.
FORMAT (IDS, THRU_FORMAT)
FLUTTER
Defines data needed to perform flutter analysis.
n/a
FREQ
n/a
Defined using FREQi.
FREQ1
n/a
FREQ2
FREQ
FREQ1 - FREQ5
FREQ3
FREQ
FREQ1 - FREQ5
FREQ4
FREQ
FREQ1 - FREQ5
FREQ5
FREQ
FREQ1 - FREQ5
GRAV
Defines acceleration vectors for gravity or other acceleration loading
n/a
HYBDAMP
Defines a hybrid modal damping for direct dynamic solutions.
METHOD
SDAMP
KDAMP
LOAD
Defines a static load as a linear combination of load sets defined via FORCE, MOMENT, FORCE1, MOMENT1, FORCE2, MOMENT2, PLOAD, PLOAD1, PLOAD2, PLOAD4, PLOADX1, SLOAD, RFORCE, and GRAV entries.
LOAD_Num_Set
LSEQ
Defines a sequence of static load sets.
EXCITE, LID, TID
MARCOUT
Selects output to be saved on the Marc t16 end/or t19 file(s) used in SOL 600 only.
WHERE, IO
MARCOUT_MAX
MFLUID
Defines the properties of an incompressible fluid volume for the purpose of generating a virtual mass matrix
MPCADD
Defines a multipoint constraint set as a union of multipoint constraint sets defined via MPC entries.
Number_Of_Sets
NLAUTO
Defines parameters for automatic or fixed load/time stepping used in SOL 600 only.
ID, TINIT, TFINAL, RSMALL, RBIG, TSMIN, TSMAX, NSMAX, NRECYC, IENHAN, IDAMP, NSTATE, NCUT, LIMTAR, IFINISH, FTEMP, IFLAG, CRITERIA, SETID, Y1-Y4, X1-X4
NLDAMP
Defines damping constants for nonlinear analysis when Marc is executed from SOL 600 only.
EID1, EID2, ALPHA, BETA, GAMMA
NLPARM
Defines a set of parameters for nonlinear static analysis iteration strategy
ID, NINC, DT, KMETHOD, KSTEP, MAXITER, CONV, INTOUT, EPSU, EPSP, EPSW, MAXDIV, MAXQN, MAXLS, FSTRESS, LSTOL, MAXBIS, MAXR, RTOLB
NLPCI
NLRGAP
Defines a nonlinear radial (circular) gap for transient response or nonlinear harmonic response.
ID, GA, GB, PLANE, TABK, TABG, TABU, RADIUS
NLSTEP
Describes the control parameters for Mechanical, Thermal and Coupled Analysis in SOL 400 and for Linear Contact Analysis in SOL 101.
GENERAL, FIXED, ADAPT, ARCLN, HEAT, MECH, COUP, RCHEAT
NLSTRAT
Defines strategy parameters for nonlinear structural analysis used in SOL 600 only.
PARAM, VALUE
ID options (1, 0, User)
NOLIN1
Defines a forcing function for transient responses or nonlinear harmonic responses.
NOLIN1_NUM
NSMADD
Defines non structural mass as the sum of the sets listed.
S
NTHICK
Defines nodal thickness values for beams, plates and/or shells.
ID, THICK
RADCAV
Identifies the characteristics of each radiant enclosure.
ELEAMB, SHADOW, SCALE, PRTPCH, NFECI, RMAX, NCOMP, RADCAV_SET_NUM=, VIEW3D
RANDPS
Defines load set power spectral density factors for use in random analysis having the frequency dependent form
randps_01
NUMBER_OF_RANDPS
RANDT1
RFORCE
Defines a static loading condition due to an angular velocity and/or acceleration
n/a
RLOAD1
Defines a frequency-dependent dynamic load of the form
rload1_equation
DELAY_OPTION
DPHASE_OPTION
RLOAD2
Defines a frequency-dependent dynamic excitation of the form
rload2_equation
DELAY_OPTION
DPHASE_OPTION
RSPEC
SPC1
Defines a single-point constraint, alternate form.
C
THRU
SPC1_NUMIDS
SPCADD
Defines a single-point constraint set as a union of single-point constraint sets defined on SPC or SPC1 entries
SPCADD_Num_Set
SPCR
Defines an enforced relative displacement value for a load step in SOL 400 and SOL 600.
TABDMP1
TABDMP1_NUM
TABLED1
TABLED1_NUM
TABLED2
TABLED2_NUM
TABLED3
TABLED3_NUM
TABLED4
TABLED4_NUM
TABLEM1
TABLEM1_NUM
TABLEM2
TABLEM2_NUM
TABLEM3
TABLEM3_NUM
TABLEM4
TABLEM4_NUM
TABLES1
Defines a tabular function for stress-dependent material properties such as the stress-strain curve (MATS1 entry), creep parameters (CREEP entry) and hyperelastic material parameters (MATHP entry).
TYPE (1 or 2)
TABLES1_NUM
TABLEST
Specifies the material property tables for nonlinear elastic temperature-dependent materials
TABLEST_NUM
TABRND1
Defines power spectral density as a tabular function of frequency for use in random analysis. Referenced by the RANDPS entry.
TABRND1_NUM
TEMPD
n/a
TIC
Defines values for the initial conditions of variables used in structural transient analysis. Both displacement and velocity values may be specified at independent degrees-of-freedom. This entry may not be used for heat transfer analysis.
TLOAD1
tload1_equation
DELAY_OPTION
TLOAD2
tload2_equation
tload2_equation2
DELAY_OPTION
TRIM
Specifies constraints for aeroelastic trim variables. The SPLINE1 and SPLINE4 entries need to be here for the finite plate spline.
SID, MACH, Q, LABEL, UX, AEQR, NUM_LABEL
TSTEP
TSTEP_NUM
TSTEPNL
Defines parametric controls and data for nonlinear transient structural or heat transfer analysis. TSTEPNL is intended for SOLs 129, 159, and 99.
ID, NDT, DT, NO, KSTEP, MAXITER, CONV, EPSU, EPSP, EPSW, MAXDIV, MAXQN, MAXLS, FSTRESS, MAXBIS, ADJUST, MSTEP, RB, MAXR, UTOL, RTOLB
VIEW
Defines radiation cavity and shadowing for radiation view factor calculations.
ICAVITY, SHADE, NB, NG, DISLIN
VIEW3D
hmtoggle_arrow1PAM-CRASH 2G
Supported Cards
Solver Description
Notes
ACC3D /
Imposed accelerations
IFUN1, IFUN2, IFUN3, SCAL1, SCAL2, SCAL3, IFRAM, ISENS, TITLE, GES
Keyword input
ACFLD /
Acceleration field
IFUN1, SCAF1, IFUN2, SCAF2, IFUN3, SCAF3, TITLE, GES
Keyword input.
BDFOR /
Body force constraints
Type, IFUN1, IFUN2, IFUN3, IFRAM, NODR, GES, TITLE
Keyword input
BOUNC /
Specify boundary conditions on the base body
X Y Z x y z, IFRAM, ISENS, TITLE, GES
Keyword input
CONLO /
Concentrated nodal load
IDR, LC, SCALE, ISENS, ITYPE, TITLE, GES
Follower_Force
Keyword input
DAMP /
Nodal damping group cards
ADAMP, TIDAMP, TFDAMP, IDAMP, TITLE, GES
NUMNOD_option
DAMP START/END (TIME, SENSOR)
Keyword input
DIS3D /
Imposed displacement
Keyword input
DIS3DM /
Imposed minimum displacement
Keyword input
DIS3DX /
Imposed maximum displacement
Keyword input
INVEL /
Specify the initial velocity of the base body
VELX, VELY, VELZ, ROTX, ROTY, ROTZ, IFRAM, IRIGB, TITLE, GES
Keyword input
PREFA /
Pressure on shells
FUNCTION, MULT, ISENS, TITLE, GES
Keyword input
PREBM /
Pressure on beams
Keyword input
RAC3D /
Imposed rotational acceleration
Keyword input
RAN3D /
Imposed angular rotations
Keyword input
RDA3D /
Radial 3D boundary conditions
Keyword input
RDD3D /
Keyword input
RDV3D /
Keyword input
RVE3D /
Imposed rotational velocities
Keyword input
VEL3D /
Imposed velocities
Keyword input
See Also:
Status Bar
Model Browser
Entity State Browser
Entities & Solver Interfaces
Include Files
