Engineering Solutions
Connectors
Connectors
Connectors
Connectors are geometric entities (not FE) used to create connections between link entities.  Assemblies, components, elements, surfaces, nodes, and tags may act as link entities. Connectors are used to realize FE idealizations of the physical connection between the link entities.  Just as you create a FE elements on a surface, you create FE connections by realizing a connector.
The following panels can be used to create and edit connectors:
Connectors
See Also:
Include Files
Assemblies
Components
