Engineering Solutions
Components entityComponents-24
Previous topic Next topic Expand/collapse all hidden text
Components collect and organize points, lines, surfaces, solids, elements and connectors. Components are intended to be organizational containers for the geometry and FE idealization of a physical part which makes up a product. Components are created, edited, and deleted from the Model browser and are shown under the Component folder. Components also have a component view within the Model browser which lists only components and has advanced options for component creation and editing.
Points, lines, surfaces, solids, elements, and connectors can be organized into a component using the Organize panel. Every point, line, surface, solid, element, and connector must be organized into one, and only one, component and therefore are mutually exclusive to a component. Newly created points, lines, surfaces, solids, elements, and connectors are automatically organized into the current component.
The current component is shown in the status bar and is also bold in the Model browser. The current component can be set using the Model browser context sensitive menu on a selected component within the component folder. Components can also be card edited using the Model browser context sensitive menu on selected components.
Components have a display state, on or off, which control the display of all points, lines, surfaces, solids, elements, and connectors organized within the component in the graphics area. The display state of a component can be controlled using the icons next to the component in the Model browser. Geometry and element display states can be controlled separately for components.
Components also have an active and export state. The active state of a component controls the display state of the component and the listing of the component in the Model browser and any of its views. If a component is active, then its display state is available to be turned on or off and it is listed in the Model browser and any of its views. If a component is inactive, then its display state is turned off permanently and it is not listed in the Model browser or any of its views.  If a find operation "finds" an inactive component, that component will automatically be set to active.
The export state of a component controls whether or not that component and all points, lines, surfaces, solids, elements, and connectors organized within the component are exported when the custom export option is utilized. The all export option is not affected by the export state of a component. The active and export states of components can be controlled using the Entity State browser.
Components can also be assigned properties and materials. Component property and material assignments are user profile (solver interface) dependent, and are described in the section Element Property and Material Assignment Rules. In general, when a component is assigned a property or material, that property or material assignment is applied to all elements organized within that component. The method of assigning properties and materials at the component level is therefore referred to as indirect property and material assignment. Direct property and material assignment is performed directly on the elements themselves. Direct property and material assignments always take precedence over indirect property and material assignments.
Operations performed on a component affect all points, lines, surfaces, solids, elements, and connectors within the component. For example, if you delete a component, the points, lines, surfaces, solids, elements, and connectors within the component are also deleted.
The data names associated with components can be found in the data names section of the HyperMesh Reference Guide.
Solver Card Support for Components
hmtoggle_arrow1RADIOSS
The supported RADIOSS cards in RADIOSS (Block Format) up to 110 are listed below. To create these cards, right-click in the Solver browser and select Create Cards from the context menu.
Supported Cards
Solver Description
Supported Parameters
Notes
/PART
Defines a part.
Prop_ID, Mat_ID, Subset_ID, Thick
hmtoggle_arrow1ANSYS
Supported Cards
Solver Description
Notes
*HM_COMP
TYPE, MAT, REAL
ET card, R card, MAT, and SECDATA card
hmtoggle_arrow1LS-DYNA
Supported Cards
Solver Description
Notes
*PART
Define parts for part adaptivity.
comment
EOSID, HGID, GRAV, ADPOPT, TMID
Options (None, Inertia, Reposition, Interia_Contact, Reposition_Contact, Contact)
PrintOption
RigidBodyMerge
DampingMass
DampingStiffness
IncludeStampPart
PartMove
*PART_COMPOSITE
Provides a simplified method of defining a composite material model for shell elements that eliminates the need for user defined integration rules and part IDs for each composite layer.
HEADING, ELFORM, SHRF, NLOC, MAREA, HGID, ADPOPT, MID, THICK, B
ContactOption
Number_of_Plies
*PART_COMPOSITE_
CONTACT
Allows part based contact parameters to be used with the automatic contact types a3, 4, a5, a10, 13, 15 and 26.
HEADING, ELFORM, SHRF, NLOC, MAREA, HGID, ADPOPT, FS, FD, DC, VC, OPTT, SFT, SSF
Number_of_Plies
*PART_COMPOSITE_
TSHELL
*PART_CONTACT
Allows part-based contact parameters to be used with the automatic contact types a3, a5, a10, a13, 15 and 26
comment, EOSID, HGID, GRAV, ADPOPT, TMID, SCFC, DCFC, EDC, VCFC, OPTT, SFT, SSF
ConRigidBodiesHelp
*PART_CONTACT_PRINT
comment, EOSID, HGID, GRAV, ADPOPT, TMID, SCFC, DCFC, EDC, VCFC, OPTT, SFT, SSF, PRBF
ConRigidBodiesHelp
*PART_INERTIA
Allows the inertial properties and initial conditions to be defined rather than calculated from the finite element mesh.
comment, EOSID, HGID, GRAV, ADPOPT, TMID, XC, YC, ZC, TM, IRCS, NODEID, IXX, IXY, IXZ, IYY, IYZ, IZZ, VTX, VTY, VTZ, VRX, VRY, VRZ
*PART_INERTIA_CONTACT
comment, EOSID, HGID, GRAV, ADPOPT, TMID, XC, YC, ZC, TM, IRCS, NODEID, IXX, IXY, IXZ, IYY, IYZ, IZZ, VTX, VTY, VTZ, VRX, VRY, VRZ, PRBF
_PRINT
comment, EOSID, HGID, GRAV, ADPOPT, TMID, XC, YC, ZC, TM, IRCS, NODEID, IXX, IXY, IXZ, IYY, IYZ, IZZ, VTX, VTY, VTZ, VRX, VRY, VRZ, SCFC, DCFC, EDC, VCFC, OPTT, SFT, SSF, PRBF
*PART_INERTIA_PRINT
comment, EOSID, HGID, GRAV, ADPOPT, TMID, XC, YC, ZC, TM, IRCS, NODEID, IXX, IXY, IXZ, IYY, IYZ, IZZ, VTX, VTY, VTZ, VRY, VRZ, PRBF
*PART_MOVE
Translate a part by an incremental displacement in either a local or a global coordinate system.
XMOV, YMOV, ZMOV, CID
*PART_PRINT
Allows user control over whether output data is written into the ASCII files MATSUM and RBDOUT.
comment
EOSID, HGID, GRAV, ADPOPT, TMID, PRBF
*PART_REPOSITION
Applies to deformable materials and is used to reposition deformable materials attached to rigid dummy components whose motion is controlled by either CAL3D or MADYMO.
comment
EOSID, HGID, GRAV, ADPOPT, TMID, CMSN, MDEP, MOVOPT
*PART_REPOSITION_
CONTACT
comment
EOSID, HGID, GRAV, ADPOPT, TMID, CMSN, MDEP, MOVOPT, SCFC, DCFC, EDC, VCFC, OPTT, SFT, SSF
*PART_REPOSITION_
CONTACT_PRINT
comment
EOSID, HGID, GRAV, ADPOPT, TMID, CMSN, MDEP, MOVOPT, SCFC, DCFC, EDC, VCFC, OPTT, SFT, SSF, PRBF
*PART_REPOSITION_
PRINT
comment
EOSID, HGID, GRAV, ADPOPT, TMID, CMSN, MDEP, MOVOPT, PRBF
hmtoggle_arrow1PAM-CRASH 2G
Supported Cards
Solver Description
Notes
PART /
Part_3D
SOLID, BSHEL, TETRA
PART /
Part_2D
TSHEL, SHELL, MEMBR
PART /
Part_1D
BAR, BEAM, SPRING, JOINT, KJOIN, MBSPR, MBKJN, SPRGBM
PART /
PART_LINK
TIED, SLINK, ELINK, PLINK, LLINK
See Also:
Browsers
Entities & Solver Interfaces
Include Files
Assemblies
