Engineering Solutions
Surfaces
Surfaces
Surfaces
A surface represents the geometry associated with a physical part. A surface is a two dimensional geometric entity that may be used in automatic mesh generation.
A surface is comprised of one or more faces. Each face contains a mathematical surface and edges to trim the surface, if required. When a surface has several faces, Engineering Solutions maintains all of the faces as a single surface entity. Operations performed on the surface affect all the faces that comprise the surface. In general, Engineering Solutions automatically uses the appropriate number of and type of surface faces to represent the geometry.
Surface edges are different from lines and are sometimes handled differently for certain operations.
The connectivity of surface edges constitutes the geometric topology.
The following panels can be used to create and edit surfaces:
Surfaces
Surface Edit
Defeature
Midsurface
Quick Edit
Edge Edit
Autocleanup
The data names associated with surfaces can be found in the data names section of the HyperMesh Reference Guide.
See Also:
Geometry Terminology
CAD Interfacing
Geometry Functionality
Include Files
Assemblies
Components
