Engineering Solutions
Load Step: Boundary: Define Tab
The Define tab allows you to define *BOUNDARY cards on individual nodes or geometry (surfaces, points, lines). You can also define the boundary on node sets. There are five different types of boundary conditions available:
Boundary types
Abaqus keyword
Default (disp)
*BOUNDARY
Velocity
*BOUNDARY, TYPE = VELOCITY
Acceleration
*BOUNDARY, TYPE = ACCELERATION
Temperature
*BOUNDARY on dof 11
Electric potential
*BOUNDARY on dof 9
It is recommended that you use only one boundary type per load collector in Engineering Solutions. If you need to use multiple boundary types in the same STEP, define each type in a separate load collector and add them to the same load step.
You can define a *BOUNDARY card on nodes/geometry or on node sets.  For Define Boundary on:, the following options are available:
Nodes or geometry
Node sets
step_mgr_boundary
The layout of the Define tab changes, based on your selection.
See Also:
Load Step: Boundary
