The Delete tab allows you to delete *CLOAD and other loads from Engineering Solutions. There are three options for deletion:
All loads in current collector |
The Delete button deletes all the loads from the current load collector. |
All 'CLOAD' in current collector |
The Delete button deletes only *CLOAD loads from the current load collector. |
By selection |
The Pick Loads button opens the load selector panel. Pick the loads you want to delete and click proceed. The corresponding Reset button resets the selected loads. The Delete button deletes the selected loads. |
