Engineering Solutions
Load Step: DLOAD: Delete Tab
The Delete tab allows you to delete DLOAD and other loads from Engineering Solutions. There are three options:
All loads in current collector
The Delete button deletes all the loads from the current load collector.
All 'Distributed loads' in current collector
The Delete button deletes all distributed (*DLOAD, *FILM) loads from the current load collector.
By selection
The Pick Loads button opens the Load Selector panel.  Pick the loads you want to delete and click proceed.
The corresponding Reset button resets the selected loads.
The Delete button deletes the selected loads.
step_mgr_dload_delete_tab
See Also:
Load Step: DLOAD
