The RADIATE dialog allows you to define the *RADIATE cards on individual elements or geometry (surfaces). You can also define the RADIATE on element sets. To open this dialog in the Load Step window, select RADIATE from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
