The Delete tab allows you to delete RADIATE and other loads from Engineering Solutions. There are three deletion options:
All loads in current collector |
The Delete button deletes all the loads from the current load collector. |
All 'Distributed loads' in current collector |
The Delete button deletes all distributed (*DLOAD, *RADIATE) loads from the current load collector. |
By selection |
The Pick Loads button opens the Load Selector panel. Pick the loads you want to delete and click proceed. The corresponding Reset button resets the selected loads. The Delete button deletes the selected loads. |
