Engineering Solutions
Load Step: RADIATE: Parameter Tab
The Parameter tab allows you to define optional parameters for the *RADIATE card.
The supported parameters are Amplitude curve, OP, and Region Type
See the Abaqus Online Documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the database.
step_mgr_radiate_parameter
See Also:
Load Step: RADIATE
