Engineering Solutions
Load Step: RADIATE: Modifying the Emissivity
There are two options for defining the emissivity for a RADIATE card created on individual elements or geometry:
By selection
The Pick loads button opens the Load Selector panel. Pick the RADIATE loads to which you want to assign emissivity, and click proceed.
The corresponding Reset button resets the selected loads.
The Update button assigns the value specified in the Emissivity: field to all selected RADIATE loads.
All RADIATE in current collector
The Update button assigns the value specified in the Emissivity: text box to all the RADIATE loads in the current load collector.
emmisivity
In a similar way, for shell elements, it is possible to change the element face (RPOS or RNEG) on which the RADIATE load is applied.
