Engineering Solutions
Load Step: DSLOAD
Load Step: DSLOAD
Load Step: DSLOAD
The DSLOAD dialog allows you to define the *DSLOAD card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select DSLOAD from the tree and a Load collector from the table.
The dialog contains three tabs:
Define
Parameter
step_mgr_dsload
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
