Engineering Solutions
Load Step: DSLOAD: Parameter Tab
The Parameter tab allows you to define optional parameters for the *DSLOAD card.
The supported parameters are Amplitude, OP, Load Case, Cyclic Mode, and Region Type.
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the Engineering Solutions database.
step_mgr_dsload_parameter_tab
See Also:
Load Step: DSLOAD
