Engineering Solutions
Load Step: SFILM
Load Step: SFILM
Load Step: SFILM
The SFILM dialog allows you to define the *SFILM card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select SFILM from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_sfilm
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
