Engineering Solutions
Load Step: SFILM: Parameter Tab
The Parameter tab allows you to define optional parameters for the *SFILM card.
The supported parameters are Amplitude, Film Amplitude, OP, and Region Type
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the database.
See Also:
Load Step: SFILM
