Engineering Solutions
Load Step: SRADIATE
Load Step: SRADIATE
Load Step: SRADIATE
The SRADIATE dialog allows you to define the *SFILM card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select SRADIATE from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_sradiate
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
