Engineering Solutions
Load Step: SRADIATE: Delete Tab
The Delete tab allows you to delete *SRADIATE and other loads from Engineering Solutions.  There are three options:
All loads in current collector
The Delete button deletes all the loads from the current load collector.
All 'SRADIATE' in current collector
The Delete button deletes only *SRADIATE loads from the current load collector
By selection
The Pick Loads button opens the Load Selector panel.  Pick the loads you want to delete and click proceed.
The corresponding Reset button resets the selected loads.
The Delete button deletes the selected loads.
See Also:
Load Step: SRADIATE
