Load Step: RADIATE: Define Tab: Elements or Geometry |
The Define RADIATE on: Elements or geometry option allows you to define RADIATE on individual elements or geometric surfaces. RADIATE loads created on elements have special graphical display in Engineering Solutions. Loads created on geometric entities like surfaces are automatically mapped to FEA mesh on export. You can also map them using the Map Loads on Geometry button.
The Define tab for Define RADIATE on: Elements or geometry has the following buttons:
Define from Pressures panels |
Opens the Pressures panel to create/update RADIATE. It only allows you to define the reference sink temperature. To create a RADIATE on elements, go to the create subpanel, select elems using the switch, pick the desired elements from the graphics, click nodes, pick two or three nodes from a face of a selected element, input the magnitude (ambient temperature), and click create. To create a pressure on geometry, go to the create subpanel, select surfs using the switch, pick the desired geometry from the graphics, input the magnitude (ambient temperature), and click create. Note:
Map Loads on Geometry |
Opens the Loads on Geom panel to map loads on geometry to FEA mesh entities. Click the Map loads button to map all geometric loads in the current load collector to FEA entities. Note:
