Engineering Solutions
Load Steps entityLoadsteps-24
Previous topic Next topic Expand/collapse all hidden text
Load step entities are used to define and store load cases for a given analysis.  Load steps are defined by selecting the associated load collectors and output blocks which define the load step.  Load steps are shown under the Loadstep folder within the Model browser.  Some solver interfaces also support the Load Step browser to create and edit load steps.
Load steps have a display state, on or off, which controls the display state of load collectors associated with the load step in the graphics area.  The display state of a load step can be controlled using the icon next to the load step entity in the Model browser.
Load steps also have an active and export state.  The active state of a load step controls the display state of the load step and the listing of the load step in the Model browser and any of its views.  If a load step entity is active, then its display state is available to be turned on or off and it is listed in the Model browser and any of its views.  If a load step entity is inactive, then its display state is turned off permanently and it is not listed in the Model browser or any of its views.
The export state of a load step entity controls whether or not that load step is exported when the custom export option is utilized.  The all export option is not affected by the export state of a load step.  The active and export states of load step entities can be controlled using the Entity State browser.
The data names associated with load steps can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit load steps:
Load Steps
Solver Card Support for Load Steps
hmtoggle_arrow1OptiStruct
The Loadsteps panel generates entities called loadsteps.  These loadsteps directly correspond to OptiStruct subcases.
Use the Loadsteps panel to explicitly define load collectors as the referenced static load (LOAD), constraint (SPC), dynamic load (DLOAD), etc. for a subcase.  Other OptiStruct input data is automatically generated or may be added to the subcase definition through the edit function.
You can choose the analysis type for the subcase being defined.  This will filter the data selectors displayed, so that only those appropriate for the selected analysis type (solution sequence) are displayed.  There is also a generic option which will display all selectors.
The following table describes how different OptiStruct Subcase information and I/O Option entries are generated on a subcase level:
Supported Card
Solver Description
Supported Parameters
Notes
ACCELERATION
Control acceleration results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Acceleration.
ANALYSIS
Define a solution sequence for individual subcases.
Select a subcase (loadstep) and click edit.  Check the box next to ANALYSIS and then select an analysis type.
CMSMETH
Defines the method, frequency upper limit, and number of modes to be used in component mode synthesis for flexibly-body preparation solution sequence.
Select a component mode synthesis method definition for use in a subcase.
Check the box next to CMSMETH and select a load collector with a CMSMETH card image.
CSTRAIN
Control ply strain results output for composites on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Cstrain.
CSTRESS
Control ply stress results output for composites on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Cstress.
DESOBJ
Define a subcase specific objective.
Part of the optimization problem setup, created in the Objectives panel.
DESSUB
Define a subcase specific design constraint.
Part of the optimization problem setup, created in the Dconstraints panel.
DISPLACEMENT
Control displacement results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Displacement.
DLOAD
Select dynamic loading information for a subcase.
Check the box next to DLOAD and select a load collector with dynamic loading information (DLOAD, RLOAD1, RLOAD2, TLOAD1, TLOAD2).
EIGVRETRIEVE
Retrieve eigenvalue and eigenvector results from a normal modes analysis from an external data file.
Select a subcase (loadstep) and click edit.  Check the box next to EIGVRETRIEVE, choose the number of integer values to be defined, and enter the integer values in the card previewer.
EIGVSAVE
Output eigenvalue and eigenvector results from a normal modes analysis to an external data file.
Select a subcase (loadstep) and click edit.  Check the box next to EIGVSAVE, and enter an integer value in the card previewer.
ELFORCE
Control elemental force results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Elforce.
ERP
Control equivalent radiated power output on a subcase level.
Select a subcase (loadstep) and click edit. Check the box next to Output and then the one next to ERP.
ESE
Control element strain energy results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Ese.
EXCLUDE
Select a set of properties to be excluded from a linear buckling analysis.
Select a subcase (loadstep) and click edit.  Check the box next to EXCLUDE, then select a SET definition from the card previewer.
FATDEF
Select elements, and associated fatigue properties for fatigue analysis
Check the box next to FATDEF and select a load collector with a FATDEF card image.
FATPARM
Select parameters for fatigue analysis.
Check the box next to FATPARM and select a load collector with a FATPARM card image.
FATSEQ
Select loading sequence for fatigue analysis.
Check the box next to FATSEQ and select a load collector with a FATSEQ card image.
FREQUENCY
Select the set of forcing frequencies to be solved in a frequency response problem.
Check the box next to FREQ and select a load collector containing frequency information (FREQ, FREQ1, FREQ2, FREQ3, FREQ4, FREQ5).
GLOBSUB
Global Model and Transfer Zone Selection
Select a subcase (loadstep) and click edit.  Check the box next to GLOBSUB and select loadstep and grid set.
GPFORCE
Control grid point force results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Gpforce.
GPSTRESS
Control grid point stress results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Gpstress.
IC
Select initial conditions for a transient analysis subcase.
Check the box next to IC and select a load collector with initial condition information (TIC).
INVEL
Select multi-body dynamics initial velocity information for a subcase.
Check the box next to INVEL and select a load collector with initial velocity information (INVELB).
LABEL
Provide a label for a subcase.
Select a subcase (loadstep) and click edit.  Check the box next to LABEL and enter a label in the card previewer.
LOAD
Select static loading information for a subcase.
Check the box next to LOAD and select a load collector containing static loads (FORCE, MOMENT, PLOAD, PLOAD2, PLOAD4, LOAD), or inertial loading information (GRAV, RFORCE).
MBSIM
Select a multi-body dynamics simulation definition for a subcase.
Check the box next to MBSIM and select the load collector with an MBLIN, MBSEQ or MBSIM card image.
METHOD
Select eigenvalue extraction information for a subcase.
Check the box next to METHOD(STRUCT) or METHOD(FLUID) and select a load collector with an EIGRL card image.
MLOAD
Select multi-body dynamics loading information for a subcase.
Check the box next to MLOAD and select a load collector containing multi-body dynamics loads (GRAV, MBFRC, MBFRCC, MBMNT, MBMNTC, MLOAD).
MODEWEIGHT
Define a multiplier for computed eigenvalues that are to be used in the calculation of the "weighted reciprocal eigenvalue" and "combined compliance index" optimization responses.
Part of the optimization problem setup, created in the Responses panel.
MOTION
Select multi-body dynamics motion information for a subcase.
Check the box next to MOTION and select a load collector containing multi-body dynamics motions (MOTION, MOTNG, MOTNGC).
MPC
Select multi-point constraints for use in a subcase.
Check the box next to MPC and select a load collector containing MPCs.
MPCFORCE
Control MPC force results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Mpcforce.
NLPARM
Select non-linear static analysis settings for use in a subcase.
Check the box next to NLPARM and select a load collector with an NLPARM card image.
NSM
Select non-structural mass input for entire model.
Check the box nex to NSM and select a group with a NSM1 or NSML1 card image or select a load collector with a NSMADD card image.  This option is not allowed in the subcase.
OFREQUENCY
Define a set of frequencies for output requests for a subcase.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Ofrequency.
OLOAD
Request the output of applied loads for a subcase.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Oload.
OMODES
Define a set of modes for output requests for a normal modes or linear buckling subcase.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Omodes.
RESVEC
Control the calculation of modal acceleration vectors.
Select a subcase (loadstep) and click edit.  Check the box next to RESVEC and choose the desired TYPE and OPTION in the card previewer.
RSPEC
Select response spectra information for use in a subcase.
Check the box next to RSPEC and select a load collector containing response spectra analysis information (RSPEC).
RWALL
Defines a rigid wall of the following types: Infinite Plane, Infinite Cylinder, Sphere and Parallelogram.
Check the box next to RWALL or RWLADD and select a group (RWALL) or a load collector (RWALADD).
SDAMPING
Select damping information for use in a subcase.
Check the box next to SDAMPING and select a load collector containing damping information (TABDMP1).
SOLVTYP
Select the iterative solver.
Select a linear static subcase (loadstep) and click edit.  Check the box next to SOLVTYP and then choose a load collector with the SOLVTYP card image.
SPC
Select single-point constraints for use in a subcase.
Check the box next to SPC and select a load collector containing SPCs.
SPCFORCES
Control SPC force results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Spcf.
STATSUB
Select a linear static subcase for linear buckling analysis.
Check the box next to STATSUB and select a static subcase.
STRAIN
Control strain results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Strain.
STRESS
Control stress results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Stress.
SUBCASE
Define a subcase.
Created automatically, when a new subcase is created.  The subcase ID matches the ID of the HyperMesh loadstep entity.
SUBCOM
Defines a combination subcase.
Created automatically, when a new load step of type “Combination Subcase Delimiter” is created.  The SUBCOM ID matches the ID of the HyperMesh loadstep entity.
SUBMODEL
Subcase-specific Model Selection
Select a subcase (loadstep) and click edit.  Check the box next to SUBMODEL and select set ids.
SUBSEQ
Subcase sequence coefficients.
Select a subcom (loadstep) and click edit.  Check the box next to SUBSEQ and input the combination coefficients.
SUBTITLE
Provide a subtitle for a loadstep.
Select a subcase (loadstep) and click edit.  Check the box next to SUBTITLE and enter a subtitle in the card previewer.
SUPORT1
Select fictitious supports for use in a subcase.
Check the box next to SUPORT1 and select a load collector containing SUPORT1 loads.
TEMP
Select thermal loading information for a subcase.
Check the box next to TEMP and select a load collector containing TEMP loads or a load collector with the TEMPD card image.
TSTEP
Select integration and time step information for a transient analysis subcase.
Check the box next to TSTEP and select a load collector with the TSTEP card image.  Set the toggle to either TIME or FOURIER, depending on the type of transient solution desired.
TTERM
Define the termination time of a geometric non-linear subcase
Check the box next to TTERM and input a real value for the termination time.
VELOCITY
Control velocity results output on a subcase level.
Select a subcase (loadstep) and click edit.  Check the box next to Output and then the one next to Velocity.
WEIGHT
Define a weighting factor (multiplier) for the compliance of a linear static or inertia relief subcase, which is used in the calculation of the "weighted compliance" and "combined compliance index" optimization responses.
XHIST
Select time history output for geometric non-linear analysis
Check the box next to XHIST or XHISADD and select a group (XHIST) or a load collector (XHISADD).
hmtoggle_arrow1Abaqus
A load step corresponds to a *STEP definition in Abaqus model history. Load collectors, output blocks and groups within a load step are exported under the corresponding *STEP block in the Abaqus input deck. It is recommended that all history (*STEP) data be defined from the Step Manager in the Abaqus user profile.
Supported Cards
Solver Description
Notes
*ADAPTIVE MESH
Defines an adaptive mesh domain and specifies the frequency and intensity of adaptive meshing for that domain.
EISet
AdaptiveMeshOP
Controls
Frequency
MeshSweeps
Defined in the load step card image.
*BUCKLE
Obtain eigenvalue buckling estimates
EigenSolver (None, Subspace, Lanczos)
*BULK VISCOSITY
Modify bulk viscosity parameters
b1, b2
Explicit template only. History data.
*COUPLED TEMP-DISPLACEMENT
Analyze problems where the simultaneous solution of the temperature and stress/displacement fields are necessary.
SteadyState
Deltmx
TimeIncrement
TotalTimePeriod
Minimum
Maximum
*DYNAMIC
(Explicit)
Dynamic stress/displacement analysis
Time Incrementation Option (None, Direct_User_Control, Element_By_Element, Fixed_Time_Incrementation)
Adiabatic
Scale Factor
ImprovedDtMethod (YES, NO)
Time Period
*DYNAMIC
(Standard)
Subspace
Adiabatic
Alpha
SingularMass
Application (TRANSIENT FIDELITY, MODERATE DISSIPATION, QUASI-STATIC)
EigenSolver (None, Haftol, Direct, Direct_No_Stop)
Initial
NoHaf
Initial Increment
Total Period
Minimum Increment
Maximum Increment
*FILE FORMAT
Specify format for results file output and invoke zero-increment results file output
Options (Binary, ASCII)
ZeroIncrement
*FREQUENCY
Extract natural frequencies and modal vectors
Option (LANCZOS, SUBSPACE, AMS)
Normalization (None, Displacement, Mass)
Property Evaluation
Nset
Frequency SIM
Damping Projection (ON, OFF)
AcousticCoupling (ON, OFF, PROJECTION)
Bias
NumberInterval
No. Of Eeigen
Minimum Frequency
Maximum Frequency
AMS_CutOff_1
AMS_CutOff_2
AMS_CutOff_3
AMS_Range_Fac
ResidualModes
*HEAT TRANSFER
Transient or steady-state uncoupled heat transfer analysis
Deltmx
End (PERIOD, SS)
SteadyState
Mxdem
Time Increment
Time Period
Minimum Time Increment
Maximum Time Increment
*LOAD CASE
Begin a load case definition for multiple load case analysis
Number_of_LoadCase
LoadCase_maximum_data_
lines
*MODAL DYNAMIC
Dynamic time history analysis using modal superposition
Continue (YES, NO)
Time Increment
Time Period
*MONITOR
Define a degree of freedom to monitor
Value
NodeSet
Node
Frequency
*PRINT
Request or suppress output to the message file in an Abaqus/Standard analysis or to the status file in an Abaqus/Explicit analysis
Contact (NO, YES)
ModelChange (NO, YES)
Frequency
Plasticity (NO, YES)
Residual (YES, NO)
Solve (NO, YES)
AdaptiveMesh (NO, YES)
*RADIATION_ VIEWFACTOR
Control the calculation of viewfactors during a cavity radiation analysis.
Cavity
Blocking (NO, ALL, PARTIAL)
Range
Cavity TurnOff
Vtol
Reflection (NO, YES)
Defined in the load step card image; visible in *Heat Transfer analysis procedure
*RESPONSE SPECTRUM
Calculates estimates of peak values of nodal and element responses.
Number_of_Directions
SummationMethod (ABS, CQC, DSC, GRP, NRL, SRSS, TENP)
Modal_Damping
Select_Eigenmode
*RESTART WRITE
Save and reuse data and analysis results
Frequency
Overlay
*STATIC
Static stress/displacement analysis
Adiabatic
Direct (Direct, No_Stop)
Fully Plastic
Riks Stabilize (None, Riks, Stabilize)
Long_Term
Dataline
*STEADY STATE DYNAMICS
Steady-state dynamic response based on harmonic excitation
Direct SubSpace (None, DIRECT, SUBSPACE PROJECTION)
SubSpace Projection (ALL FREQUENCIES, CONSTANT, EIGENFREQUENCY, PROPERTY CHANGE, RANGE)
Frequency Scale (LOGARITHMIC, LINEAR)
Interval (EIGENFREQUENCY, RANGE)
Read Only
SSD DataLines
Modal_Damping
*STEP
Begin a step
CONVERT SDI
INCREMENT
NAME
NLGEOM
PERTURBATION
UNSYMMETRIC
AMPLITUDE=STEP, RAMP
EXTRAPOLATION=LINEAR, PARABOLIC, NO
Parameters are defined in the load step card image.
*VISCO
Transient, static, stress/displacement analysis with time-dependent material response (creep, swelling, and viscoelasticity)
Cetol
Creep
Factor
Stabilize
Initial Time Increment
Period
Note:Only load collectors with the HISTORY card image should be added to a load step.  Load collectors with INITIAL_CONDITION card images need not be added to any load steps. They will be ignored, if added.
hmtoggle_arrow1ANSYS
Supported Card
Solver Description
Notes
ACEL
Specifies the linear acceleration of the structure.
ACELX, ACELY, ACELZ
ANTYPE
Specifies the analysis type and restart status.
type (STATIC, BUCKLE, MODAL, HARMIC, TRANS, SUBSTR, SPECTR)
status (NEW, REST, VTREST)
LDSTEP
SUBSTEP
ANTYPE_Action (CONTINUE, ENDSTEP, RSTCREATE, PERTURB)
CECMOD
NEQN, CONST
CMACEL
Specifies the translational acceleration of an element component.
CM_NAME, CMACEL_X, CMACEL_Y, CMACEL_Z
CMDOMEGA
Specifies the rotational acceleration of an element component about a user-defined rotational axis.
CM_NAME, DOMEGAX, DOMEGAY, DOMEGAZ, X1, Y1, Z1, X2, Y2, Z2
CMOMEGA
Specifies the rotational velocity of an element component about a user-defined rotational axis.
CM_NAME, DOMEGAX, DOMEGAY, DOMEGAZ, X1, Y1, Z1, X2, Y2, Z2, KSPIN
EQSLV
Specifies the type of equation solver.
Lab, TOLER, MULT
LSSOLVE
Reads and solves multiple load steps.
LSMIN, LSMAX, LSINC
NLGEOM
Includes large-deflection effects in a static or full transient analysis.
Key
NSUBST
Specifies the number of substeps to be taken this load step.
NSBSTP, NSBMX, NSBMN, Carry
OMEGA
Specifies the rotational velocity of the structure.
OMEGX, OMEGY, OMEGZ, KSPIN
OUTRES
Controls the solution data written to the database.
Item, FREQ, Cname
TIME
Sets the time for a load step.
time
hmtoggle_arrow1Nastran
The Loadsteps panel is available when the Nastran user profile is loaded.   It is used to generate Nastran subcase definitions. The panel creates loadstep entities. These loadstep entities directly correspond to Nastran subcase definitions.
Use the Loadsteps panel to explicitly define load collectors as the referenced constraint (SPC), static load (LOAD), multi-point constraint (MPC), fictitious support (SUPORT1), non-linear parameters (NLPARM), eigenvalue extraction data (METHOD), frequency range (FREQ), damping (SDAMPING), dynamic load (DLOAD), thermal loading (TEMP), etc. for a subcase. Other input data is automatically generated (the SUBCASE header) or may be added to the subcase definition through the edit function.
It is recommended to set up a subcase using the Loadstep browser.
Supported Card
Solver Description
Notes
NLSTEP
Describes the control parameters for mechanical, thermal and coupled analysis in SOL 400 and for linear contact analysis in SOL 101.
GENERAL, FIXED, ADAPT
SUBCASE
LABEL, ANALYSIS, IC, BCONTACT, TRIM, OUTPUT
SUBCOM
SUBSEQ
TSTEPNL
Defines parametric controls and data for nonlinear transient structural or heat transfer analysis.
NDT, DT, NO, KSTEP, MAXITER, CONV, EPSU, EPSP, EPSW, MAXDIV, MAXQN, MAXLS, FSTRESS, MAXBIS, ADJUST MSTEP, RB, MAXR, UTOL, RTOLB, MINITER
See Also:
Model browser
Entities & Solver Interfaces
Model Setup
Element Property and Material Assignment Rules
