Engineering Solutions
Optimization Constraints entityOptimizationConstraints-24
Previous topic Next topic Expand/collapse all hidden text
Optimization constraint entities are used to define and store constraints on model responses for optimization problems.  Optimization constraints are shown under the OptimizationConstraint folder within the Model browser.  The Optimization View can be utilized to create, edit, and delete optimization problems.
Optimization constraints do not have a display state.
Optimization constraints have an active and export state.  The active state of an optimization constraint controls the listing of the optimization constraint in the Model browser and any of its views.  If an optimization constraint entity is active, then it is listed in the Model browser and any of its views.  If an optimization constraint entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of an optimization constraint entity controls whether or not that optimization constraint is exported when the custom export option is utilized.  The all export option is not affected by the export state of an optimization constraint.  The active and export states of optimization constraint entities can be controlled using the Entity State browser.
The data names associated with optimization constraints can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit optimization constraints:
Dconstraints
Solver Card Support for Optimization Constraints
hmtoggle_arrow1OptiStruct
An optimization problem is set up by defining responses, which are in turn constrained or set as objectives.
Design variables identify the varying quantities in an optimization problem.
All of the optimization panels are available from the Optimization menu when the OptiStruct user profile is loaded.
Supported Card
Solver Description
Supported Parameters
Notes
DCONADD
Collects constraints.  DCONADD do not exist within the database, they are created automatically on export for opticonstraint entities.
DCONSTR
A constraint definition, defining lower and/or upper bounds for a response.  Supported as an opticonstraint entity.
Defined in the Dconstraints panel.
DESGLB
Global constraint selection.  Automatically created on export for opticonstraints that do not require a loadstep (subcase) selection.
opticonstraints are defined in the Dconstraints panel.
DESSUB
Subcase dependent constraint selection.  Automatically created on export when a loadstep (subcase) is selected in an opticonstraint definition.
hmtoggle_arrow1Nastran
Some of the functionality of the optimization capability is general. This includes the equation utility, delete, rename, renumber, and reorder functions. To set up an optimization problem, responses, an objective function and constraints need to be defined. Further, design variables need to be defined. The optimization panels have separate Delete, Rename, Renumber, and Reorder panels to manipulate optimization entries.  These can be reached through the Optimization drop down menu.
Supported Card
Solver Description
Notes
DCONADD
Defines the design constraints for a subcase as a union of DCONSTR entries.
DCONSTR
Defines design constraints.
Constraint to define lower and upper bounds
DESGLB
Selects the design constraints to be applied at the global level in a design optimization task.
Global constraint; belongs in the subcase section
DESSUB
Selects the design constraints to be used in a design optimization task for the current subcase.
Constraint dependent on the load step; Belongs in the subcase section
See Also:
Model browser
Optimization Browser View
Browsers
Entities & Solver Interfaces
Include Files
Optimization
