Engineering Solutions
Optimization Equations entityEquations-24
Previous topic Next topic Expand/collapse all hidden text
Optimization equation entities are used to define and store equations for optimization problems.  Optimization equations are shown under the OptimizationFunction folder within the Model browser.  The Optimization View can be utilized to create, edit, and delete optimization problems.
Optimization equations do not have a display state.
Optimization equations have an active and export state.  The active state of an optimization equation controls the listing of the optimization constraint in the Model browser and any of its views.  If an optimization equation entity is active, then it is listed in the Model browser and any of its views.  If an optimization equation entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of an optimization equation entity controls whether or not that optimization equation is exported when the custom export option is utilized.  The all export option is not affected by the export state of an optimization equation.  The active and export states of optimization equation entities can be controlled using the Entity State browser.
The data names associated with optimization equations can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit optimization equations:
Dequations
Solver Card Support for Optimization Equations
hmtoggle_arrow1OptiStruct
An optimization problem is set up by defining responses, which are in turn constrained or set as objectives.
Design variables identify the varying quantities in an optimization problem.
All of the optimization panels are available from the Optimization menu when the OptiStruct user profile is loaded.
Supported Card
Solver Description
Supported Parameters
Notes
DEQATN
Equations referenced on DRESP2, DVPREL2.  Supported as an
optimizationequation entity.
Defined in the Dequations panel.
hmtoggle_arrow1Nastran
Some of the functionality of the optimization capability is general. This includes the equation utility, delete, rename, renumber, and reorder functions. To set up an optimization problem, responses, an objective function and constraints need to be defined. Further, design variables need to be defined. The optimization panels have separate Delete, Rename, Renumber, and Reorder panels to manipulate optimization entries.  These can be reached through the Optimization menu.
Supported Card
Solver Description
Notes
DEQATN
Defines one or more equations for use in design sensitivity or p-element analysis.
See Also:
Model browser
Optimization Browser View
Browsers
Entities & Solver Interfaces
Include Files
Optimization
