This toolbar displays along the bottom of the Penetration tab, but only when the show manual fix toolbar button in the second toolbar is active.
Button |
Action |
Select Elements By Tree: When this mode is active, clicking the lowest-level component in the tree structure selects all of its failed elements. |
Select Elements Manually: When this mode is active, you can click each desired element belonging to the lowest-level component in the tree. This includes the ability to select non-failed elements or a sub-set of the failed ones. |
Select Nodes By Tree: When this mode is active, clicking the lowest-level component in the tree structure selects all of the penetrating nodes in its failed elements. This differs from Select Elements By Tree in that individual nodes can be moved to fix a penetration (thus changing the shape of a failed element) instead of moving entire elements. |
Select Nodes Manually: When this mode is active, you can click each desired node belonging to the lowest-level component in the tree. This includes the ability to select individual nodes of non-failed elements, or a sub-set of nodes belonging to the failed elements. |
Manual Fixes: Fix Direction. This modal button has several different possible functions, but each determines the direction that you wish to manually move the selected nodes or elements. Click the small triangle in the bottom corner to display a list of possible functions and then click the desired function: |
Move in Negative Direction: This button works in conjunction with the value entered in the numeric text box adjacent to it. Click this button to move the selected nodes or elements in the specified direction, by the negative of the amount specified in the numeric text box. |
Move in Positive Direction: This button works in conjunction with the value entered in the numeric text box adjacent to it. Click this button to move the selected nodes or elements in the specified direction, by the amount specified in the numeric text box. |
