Engineering Solutions
System Collectors entitySystemCollectors-24
Previous topic Next topic Expand/collapse all hidden text
System collectors collect and organize systems.  System collectors are created, edited, and deleted from the Model browser and are shown under the SystemCollector folder.
Systems can be organized into a system collector using the Organize panel.  Every system must be organized into one, and only one, system collector and therefore are mutually exclusive to a system collector.  Newly created systems are automatically organized into the current system collector.
The current system collector is shown bold in the Model browser.  The current system collector can be set using the Model browser context menu on a selected system collector within the SystemCollector folder.  System collectors can also be card edited using the Model browser context menu on selected system collectors.
System collectors have a display state, on or off, which control the display of all systems organized within the system collector in the graphics area.  The display state of a system collector can be controlled using the icons next to the system collector in the Model browser.
System collectors also have an active and export state.  The active state of a system collector controls the display state of the system collector and the listing of the system collector in the Model browser and any of its views.  If a system collector is active, then its display state is available to be turned on or off and it is listed in the Model browser and any of its views.  If a system collector is inactive, then its display state is turned off permanently and it is not listed in the Model browser or any of its views.  If a find operation "finds" an inactive system collector, that system collector will automatically be set to active.
The export state of a system collector controls whether or not that system collector and all systems organized within the system collector are exported when the custom export option is utilized.  The all export option is not affected by the export state of a system collector.  The active and export states of system collectors can be controlled using the Entity State browser.
Operations performed on a system collector affect systems within the system collector.  For example, if you delete a system collector, the systems within the system collector are also deleted.
The data names associated with system collectors can be found in the data names section of the HyperMesh Reference Guide.
Solver Card Support for System Collectors
hmtoggle_arrow1RADIOSS
The supported RADIOSS cards in RADIOSS (Block Format) 100 are listed below. To create these cards, right-click in the Solver browser and select Create Cards from the context menu.
Supported Card
Solver Description
Supported Parameters
Notes
/TRANSFORM/ROT
Defines rotational transformation on the node set.
/TRANSFORM/TRA
Defines translational transformation on the node set.
/TRANSFORM/SCA
Defines scaling transformation on the node set.
/TRANSFORM/SYM
Defines symmetry transformation on the node set.
hmtoggle_arrow1LS-DYNA
The system collector cards can be previewed, but not edited.
Supported Card
Solver Description
Notes
*DEFINE_
TRANSFORMATION
Define a transformation for the INCLUDE_TRANSFORM keyword option.
OPTION (SCALE, ROTATE, TRANSL)
A1, A2, A3
Title
NumDatalines
Transformations can be created using the Transformation Manager.
*INCLUDE_PATH
Defines path for the include file location
Card Edit is not available. Keyword details can be accessed from the Include file options in the Include browser.
*INCLUDE_STAMPED_PART
Attaches a file that has stamping results for a part in the model as an include file.
FILENAME
PID, THICK, PSTRN, STRAIN, STRESS, INCOUT, RMAX
N1S, N2S, N3S, N1C, N2C, N3C, TENSOR, THKSCL
ISYM, IAFTER, PERCELE, IORTHO
X01, Y01, Z01
X02, Y02, Z02, X03, Y03, Z03
*INCLUDE_STAMPED_PART_SET
Attaches a file that has stamping results for a collection of parts (set) in the model as an include file.
FILENAME
X01, Y01, Z01
*INCLUDE_TRANSFORM
Include file that supports offset on its content IDs and transforms on its contents.
FILENAME
IDNOFF, IDEOFF, IDPOFF, IDMOFF, IDSOFF, IDFOFF, IDDOFF, IDROFF, FCTMAS, FCTTIM, FCTLEN, FCTTEM, INCOUT, TRANID
Engineering Solutions support offset on the entity ID's. During import, offsets are applied on to the ID's of the corresponding  include_transform file contents. During export, offset is subtracted from the ID's. The current release only supports Input and output therefore the offsets cannot be changed.
*NODE_TRANSFORM
Transformation defined on node set
TRSID, NSID
Title
hmtoggle_arrow1PAM-CRASH 2G
Supported Card
Solver Description
Notes
TRANSFORMATION /
NAME, Selection, Keyword, D, X, Y, Z, N1, N2
NumDatalines
See Also:
Model Browser
Organize panel
Entity State Browser
Entities & Solver Interfaces
Include Files
