Visualization of Loads on Geometry and Loads on Mesh |
The Display panel allows you to visualize loads on mesh and loads on geometry either individually or together by setting the collector type to loadcols and using the toggle between elems and geoms. The elems option controls the display of loads on mesh while geom controls the display of loads on geometry. A simultaneous display is similar to the display of both elements and geometry belonging to a specific component.
Introduction to Loads on Geometry
Application of Loads to Geometry
HM-4040: Working with Loads on Geometry
