You can apply loads to geometrical entities in a way similar to the manner in which loads are applied to mesh. The process includes two basic steps.
1. | Creating a load collector by using the Collector panel. |
2. | Applying loads to the geometry using one of the following panels: Forces, Moments, Constraints, Pressures, Temperatures, Flux, Velocities, and Accels. |
To apply a load to a geometrical entity, first create a load collector in which the loads applied to geometrical entities will be stored. Next, access a load panel (for example Forces, Constraints, and so on), and select the create subpanel. Third, select a geometrical entity on which the loads will be applied (points, lines, or surfaces) using the panel selection box, define the load or boundary condition parameters in the same way you would for the application of the load or boundary condition on a FE mesh entity (for example node), and click create. The loads/boundary conditions are stored in the database and displayed in the graphical window.
The following chart specifies the geometrical entities to which loads can be applied, in each of the load application panels listed above.
Panel |
Geometrical Entities |
points, lines and surfaces. |
points |
points |
points |
surfaces |
Introduction to Loads on Geometry
Visualization of Loads on Geometry and on Mesh
HM-4040: Working with Loads on Geometry
