NVH has the following boundary condition tools:
Quickly and easily create one or more contact interfaces at once between several parts of your model. This tool is only available when the OptiStruct user profile is loaded. |
Select the entities that are viewed in the card image subpanel. |
Place constraints or enforced displacements on a model. |
Create and modify contactsurf entities. |
Create contour plots of applied loads and boundary conditions contained within load collectors. |
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves. |
Create, review and update equations. |
Apply concentrated fluxes to your model. |
Create concentrated forces. |
Create and modify interfaces. |
Map loads or boundary conditions from geometrical entities (loads on geometry) to the associated FE mesh entities (loads on mesh). |
Creates a summary of the loads (node-based forces or moments and element-based pressures) applied to a model. |
Create concentrated moments. |
Allows you to (re)organize your database by copying or moving data (entities) among collectors or includes. |
Create concentrated pressures. |
Renumber entities. |
Create rectangular, cylindrical and spherical coordinate systems. |
Create temperature constraints. |
