Engineering Solutions
Control Cards entityCards-24
Previous topic Next topic Expand/collapse all hidden text
Control card entities are used to create solver control cards such as results file I/O options, CPU and memory limits, and others. A solver interface template must be loaded which defines control cards in order to create and edit control cards. Control cards are shown under the Card folder within the Model browser.
The following panels can be used to create and edit control cards:
Control Cards
model_browser_cards
Solver Card Support for Control Cards
hmtoggle_arrow1RADIOSS
Supported Card
Solver Description
Supported Parameters
Notes
/@TFILE
The time at which the time history file begins.
/@TFILE/Keyword2
/ABF
Describes the output of .abf files.
/ADMESH/GLOBAL
Defines the global parameters.
/ALE
Sets parameters for DONEA grid velocity formulation of ALE.
/ALE/2
Sets parameters for RADIOSS grid velocity formulation for ALE.
/ALE/3
When this keyword is used instead of /ALE or /ALE/2, no grid calculation is performed.  Grid does not move, unless constrained otherwise.
/ALE/4
Sets the RADIOSS Standard formulation.
/ALE/DISP
Describes the displacement formulation.
/ALE/DONEA
Describes the ALE grid velocity.
/ALE/SPRING
Describes the spring formulation.
/ALE/STANDARD
Describes the standard formulation.
/ALE/ZERO
Describes the Euler formulation.
/ALESUB
Sub-cycling on Lagrangian parts.
/AMS
Description of advanced mass scaling in the model
/ANALY
Describes the analysis flags.
/ANIM
Generates animation files containing results according to the keywords specified.
/ANIM/BRICK/TENS
Generates animation files containing tensor data for brick elements according to keyword.
/ANIM/BRICK/TENS/STRAIN
Generates animation files containing strain tensor for a specified integration point of a solid, in global coordinate system.
/ANIM/BRICK/TENS/STRESS
Generates animation files containing stress tensor for a specified integration point of a solid, in global coordinate system.
/ANIM/CUT/1
Defines a section cut on a deformed geometry.
/ANIM/CUT/2
Defines a section cut on the initial geometry.
/ANIM/CUT/3
Defines a section cut on a deformed geometry using three nodes.
/ANIM/DT
Write animation files (A-files) at a time frequency equal to Tfreq, the first file being written at time Tstart.
/ANIM/Eltyp/FORC
Generates animation files containing force and moment data for the specified type of element.
/ANIM/Eltyp/Restype
Generates animation files containing element data for the specified result.
/ANIM/GPS1
Generates animation files containing simple average GPS data.
/ANIM/GPS2
Generates animation files containing volume based averaged GPS data.
/ANIM/GZIP
Generates animation files in GZIP format.
/ANIM/KEEPD
In animation files, keeps deleted elements in their original part.
/ANIM/LSENSOR
Writes additional animation files (A-files) at a time frequency is equal to Tfreq, the first file being written at sensor activation time.
/ANIM/MASS
Generates animation files containing nodal masses.
/ANIM/MAT
Generates animation files with one part for each material.
/ANIM/NODA
Generates animation files containing nodal scalar data.
/ANIM/SENSOR
Writes additional animation files (A-files) with a time frequency equal to Tfreq, the first file being written once sensor is activated.
/ANIM/SHELL/EPSP
Generates animation files containing plastic strain as a function of a shell element integration point.
/ANIM/SHELL/PHI/ALL
Generates animation files.
/ANIM/SHELL/PHI/N
/ANIM/SHELL/TENS
Generates animation files containing shell tensor data for a specified result.
/ANIM/SHELL/USRi
/ANIM/VECT
Generates animation files containing vectorial data for the specified variable.
/ANIM/VECT/FREAC
Reaction forces for imposed velocities, displacements, accelerations and boundary conditions.
/ANIM/VERS
Generates animation files in RADIOSS environment post processing formats 41 and 44.
/ARCH
Describes the architecture flag.
/ATFILE
Defines the frequency of writing additional time history file of T-file “RunnameTnnx”.
/BCS/ALE
Given node numbers will be constrained in specified directions X, Y or Z for grid degrees of freedom: symbol_alpha = 0.
/BCS/LAG
Given node numbers will be lagrangian in specified directions X, Y or Z:  V = W.
/BCS/ROT
Given node numbers will be constrained in specified directions X, Y or Z for rotational degrees of freedom: symbol_alpha = 0.
/BCS/TRA
Given node numbers will be constrained in specified directions X, Y or Z for material translational degrees of freedom: V = 0.
/BCSR/ALE
Given node numbers will be released in specified directions X, Y or Z for grid degrees of freedom.
/BCSR/LAG
Given node numbers will no longer be lagrangian in specified directions X, Y or Z.
/BCSR/ROT
Given node numbers will be released in specified directions X, Y or Z for rotational degrees of freedom.
/BCSR/TRA
Given node numbers will be released in specified directions X, Y or Z for material translational degrees of freedom.
/BEGIN
Sets the run name, the version of the input manual, the number of Starter run and input and work unit systems.
/CAA
Describes the computation Aero-Acoustic formulation.
/DAMP
Describes the Rayleigh damping.
/DEF_SHELL
Describes the shell default values initialization.
/DEF_SOLID
Describes the solid default values initialization.
/DEL
Deletes element numbers N1, N2, . . ., NN.
/DEL/Eltyp/1
Deletes element numbers N1first to N1last, . . ., NIfirst to NIlast.
/DEL/INTER
Deletes interface numbers N1, N2, . . ., NN.
/DELINT
If a slave node is only connected to 2D solid elements that are all deleted, the node is deactivated from the interface.
/DT
Time step defaults for all elements.
/DT/AMS
Elementary time step for Advanced Mass Scaling.
/DT/Eltyp/Iflag
Time step for select entities.
/DT/Eltyp/Keyword3/Iflag
Time step with entity selection and time step control.
/DT/NODA/Keyword3
Nodal time step control.
/DT/SHELL
The time step for shell elements using /DT1 is lower but more accurate.
/DT/SHNOD or /DT/SHNOD/CST
Time step for shells.
/DT/SPHCEL
Generates the SPH cells time step.
/DT/SPHCEL/Keyword3
Generates the SPH cells time step control type.
/DT/THERM
Time step for thermal modeling.
/DT1/SHELL
The time step for shell elements using /DT1 is lower, but more accurate.
/DTIX
Sets initial and maximum time step for this run.
/DTSDE
The time step for degenerated or PENTA6 solid elements using this option is higher (almost factor 2).
/DYREL
Dynamic relaxation.
/DYREL/1
Dynamic relaxation applied to node group identifier grnd_ID.
/END/ENGINE
This keyword has to be set at the end of the Engine input deck when using Single File Input.
/FVMBAG/MODIF
Activates FVM airbag merging parameter modifications in Engine file.
/FXINP
Generates input files for flexible bodies from eigenmodes and static modes computation.
/IMPL
An implicit solution sequence will be called this.
/IMPL/AUTOSPC
A zero stiffness degree-of-freedom will be constrained automatically.
/IMPL/BUCKL/1
Euler buckling modes will be computed.
/IMPL/BUCKL/2
Euler buckling modes will be computed based on actual pre-stress stat.
/IMPL/CHECK
Implicit model checking will be run.
/IMPL/DIVERG/n
Divergence criterion with successive increasing residual number for nonlinear analysis.
/IMPL/DT/1
Implicit time step control method 1.
/IMPL/DT/2
Implicit automatic time step control method 2.
/IMPL/DT/3
Implicit automatic time step control with Riks method.
/IMPL/DT/FIXPOINT
Users’ input fix time points where implicit nonlinear computation will not miss with automatic time step control.
/IMPL/DT/STOP
The computation will be stopped, if DT_min is reached.
/IMPL/DTINI
Initial time step for nonlinear implicit analysis.
/IMPL/DYNA/1
Describes the implicit dynamics with asign -HHT method.
/IMPL/DYNA/2
Describes the implicit dynamics with a general Newmark method.
/IMPL/DYNA/DAMP
Rayleigh structure damping with dynamic implicit analysis.
/IMPL/DYNA/FSI
Defines the settings for Fluid Structure Interaction Analysis with AcuSolve.
/IMPL/GSTIF/OFF
Geometrical stiffness matrix will not be used for implicit nonlinear calculation.
/IMPL/INTER/KCOMP
Describes the stiffness matrix; due to contact interfaces will be assembled completely.
/IMPL/INTER/KNONL
Defines including some contact nonlinearities in PCG linear solver.
/IMPL/LBFGS/L
Change the maximum number of BFGS quasi-Newton method for implicit nonlinear.
/IMPL/LINEAR
Linear implicit solution will be computed.
/IMPL/LINEAR/INTER
Implicit linear analysis will take into account contact interfaces.
/IMPL/LRIGROT
Due to some linearization used in geometrical nonlinear analysis, small time step has to be chosen to avoid accumulated errors under large rotation. This option improves the accuracy, in this case using usual time step.
/IMPL/LSEARCH/n
Line search methods for nonlinear analysis.
/IMPL/LSEARCH/OFF
Deactivating line search for nonlinear analysis.
/IMPL/MONVOL/OFF
Describes the stiffness of gas in monitored volume type 3 (tire modeling).
/IMPL/NCYCLE/STOP
The computation will be stopped, if Ncy_max is reached.
/IMPL/NONLIN
Nonlinear implicit methods.
/IMPL/NONLIN/SMDISP
Only small displacement effects will be considered with this option.
/IMPL/PREPAT
Describes the implicit option for pre-conditioning.
/IMPL/PRINT/LINEAR
Printout frequency for linear solvers.
/IMPL/PRINT/NONLIN
Printout frequency for nonlinear implicit iterations.
/IMPL/PSTIF/OFF
Deactivating load (pressure) stiffness matrix.
/IMPL/QSTAT
Quasi-static implicit solution will be computed.
/IMPL/QSTAT/DTSCAL
Quasi-static implicit solution with a factor for inertia stiffness matrix.
/IMPL/RREF/INTERF/n
Different reference force residual computations used for stop criteria on nonlinear analysis with contact.
/IMPL/RREF/LIMIT
Define reference force residual limit values used in stop criteria for implicit nonlinear.
/IMPL/RREF/OFF
Deactivation reference residual option and using the previous one in stop criteria for implicit nonlinear analysis.
/IMPL/SBCS/MSGLV
Describes the message level for BCS (Boeing) solver.
/IMPL/SBCS/ORDER
Reordering method definition for BCS.
/IMPL/SBCS/OUTCORE
BCS solver will use minimum in-core memory.
/IMPL/SHPOFF
The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the stiffness matrix and the internal force computations.
/IMPL/SHPON
The full projection of QEPH shell element for warped elements will be activated for stiffness matrix to keep  consistency with the internal force computations.
/IMPL/SINIT
Describes the initial stresses that will be imposed gradually (from V51).
/IMPL/SOLVER
Selects linear solver.
/IMPL/SPRBACK
Implicit spring back will be run in this session.
/IMPL/SPRING
Describes the linear or nonlinear stiffness choices for nonlinear spring in implicit nonlinear analysis.
/IMPLICIT
Allows the default values to be changed for implicit calculations.
/INCMP
Quasi-incompressible formulation for fluid material (compatible with type 6 and 11).
/INISTA
Describes the initial state file.
/INIV/AXIS/Keyword3
Initialize rotational velocity about an axis and translational velocity.
/INIV/AXIS/Keyword3/1
/INIV/ROT
Initialize rotational velocity in the specified direction X, Y or Z.
/INIV/ROT/Keyword3/1
/INIV/TRA
Initialize translational velocity in the specified direction X, Y or Z.
/INIV/TRA/Keyword3/1
/INTER
Describes an interface.
/IOFLAG
Describes the input-output flags.
/KEREL
Kinetic energy relaxation.
/KEREL/1
Kinetic energy relaxation applied to node group grnd_ID.
/KILL
The Engine is stopped if one of the following criteria is exceeded.
/MADYMO
Activates MADYMO-RADIOSS coupling.
/MEMORY
Describes the memory request.
/MON
Provides an estimation of the CPU time spent for each processor.
/OUTP
Write ASCII formatted output files.
/OUTP/LSENSOR
Writes an outp file each time a sensor in the defined list is activated.
/PARITH
Turns on/off the parallel arithmetic.
/PRINT
Sets printout frequency for list file.
/RAD2RAD/ON
Activates multi-domain coupling.
/RANDOM
Describes the nodal random noise.
/RBODY
Given rigid bodies will be activated or deactivated.
/RERUN
Permits to continue a previous RADIOSS run.
/RFILE
Writes a Restart R-File.
/RFILE/n
Rewrites a Restart R-File.
/RUN
Identifies the run number.
/RUN/Run Name/Run Number/Restart Letter
/SHSUB
Allows to activate new sub-cycling option, for which Isubcycle =2 in the /ANALY RADIOSS Starter option should be specified.
/SHVER/V51
The new large rotational body motion formulation for QEPH, QBAT and DKT18 will be deactivated.
/SPHGLO
Describes the SPH global parameters.
/SPMD
Describes the SPMD computation.
/STAMPING
Improvement of error messages for stamping applications
/STATE/BRICK/AUX/FULL
Describes the internal variable state for solid.
/STATE/BRICK/ORTHO
Describes Orthotropy Direction for orthotropic solid or thick shells.
/STATE/BRICK/STAIN/FULL
Describes the strain state for solid.
/STATE/BRICK/STRAIN/GLOBFULL
Describes the strain state for solid in global reference system.
/STATE/BRICK/STRES/FULL
Describes the stress state for solid.
/STATE/BRICK/STRESS/GLOBFULL
Describes the stress state for solid in global reference system.
/STATE/DT
Writes the state file.
/STATE/NODE/TEMP
Describes the temperature for nodes.
/STATE/LSENSOR
Writes a state file each time a sensor in the defined list is activated.
/STATE/SHELL/AUX/FULL
Describes the internal variable state for shell.
/STATE/SHELL/EPSP/FULL
Describes the Epsilon plastic state for shell.
/STATE/SHELL/ORTHL
Describes the orthotropy direction for shell.
/STATE/SHELL/STRAIN/FULL
Describes the strain state for shell.
/STATE/SHELL/STRESS/FULL
Describes the stress state for shell.
/STATE/STR_FILE
When writing the state file, /INISHE, /INISH3 and /INIBRI will be written in a separate file which can be asked for being compressed (using GZIP) or not.  The state file will then resume to the nodes coordinates and element connectivity.
/STOP
The Engine is stopped, due to energy error ratio criteria.
/TFILE
Defines the frequency of writing the time history file of T-file “RunnameTnn”.
/TH/VERS
Generates the Time History files in RADIOSS environment post-processing format “Version Number”.
/TITLE
Describes the title.
/UNIT
Describes the local unit system.
/UPWIND
Describes the upwind coefficient.
/UPWM/SUPG
Describes the Streamline Upwind Petrov Galerkin formulation.
/UPWM/TG
Describes the Taylor Galerkin method for momentum advection.
/VEL/ALE
Given node numbers have the same grid velocity in a specified direction or combination of directions (ALE links).
/VEL/ROT
Given node numbers have the same rotational velocity in a specified direction X, Y or Z.
/VEL/TRA
Given node numbers have the same velocity in a specified direction X, Y or Z for material translational degrees of freedom.
/VERS
Identifies the input data version number.
hmtoggle_arrow1OptiStruct
Control cards are used to support many different things for the OptiStruct user profile.
The following I/O option entries are supported as control cards when appearing before the first SUBCASE statement.  In many cases, information supplied on these entries is overridden by repeated definitions within subcases.
Supported Card
Solver Description
Notes
ACCELERATION
Controls the output of acceleration results
Found under GLOBAL_OUPUT_REQUEST.
ANALYSIS
Flag indicating that only analysis is to be performed (that is, no optimization), CHECK overrides ANALYSIS.
Supported as an output option on the subcase definition when it appears within a subcase.  (Use the edit button in the Loadsteps panel.)
ASSIGN
Identifies external files and their contents.
AUTOSPC
Automatically constrains stiffness singularities.
PRINT, PUNCH, NOPRINT, NOPUNCH
Found under GLOBAL_CASE_CONTROL
CFAILURE
Requests failure index output for elements referencing PCOMP or PCOMPG properties for all subcases or individual subcases, respectively.
CFAILURE is supported for static analysis only.
CHECK
Flag indicating that only a check run is to be performed (that is, no analysis or optimization). CHECK overrides ANALYSIS.
CMDE
Requests component modal synthesis damping energy output for all subcases or individual subcases, respectively.
CMKE
Requests component modal synthesis kinetic energy output for all subcases or individual subcases, respectively.
CMSE
Requests component modal synthesis strain energy output for all subcases or individual subcases, respectively.
CONTF
Requests contact results output for all nonlinear analysis subcases or individual nonlinear analysis subcases, respectively.
CSTRAIN
Controls the output of strain results for composite shells.
CSTRESS
Controls the output of stress results for composite shells.
DAMAGE
Controls the output of fatigue damage results.
DENSITY
Controls the output of density results from a topology or free-size optimization.
DENSRES
DESHIS
Controls the creation of the .hgdata file.
DGLOBAL
Defines input parameters required for the Global Search Option (GSO).
NGROUP, NPOINT, SPMETH, NOUTDES, DESTOL, MAXSP, MAXSUCC, MAXWALL, MAXCPU
NGROUP_OPT, NPOINT_OPT, NOUTDES_OPT, DGLOBAL_NUM_GROUP, DGLOBAL_IO
DISPLACEMENT
Controls the output of displacement (and rotation) results.
DMIGNAME
Defines the name given to the reduced matrices written to an external data file.
DSA
Requests Design Sensitivity Analysis results in a frequency response analysis.
ECHO
Controls the echo of input data to the .out or .echo files.
EDE
Requests element energy loss per cycle and element energy loss per cycle density output for all subcases or individual subcases, respectively.
EIGVNAME
Defines the prefix to be used for the saving and retrieval of external eigenvalue data files.
EKE
Requests kinetic energy and kinetic energy density output for all subcases or individual subcases, respectively.
ELFORCE
Controls the output of element force results.
ENERGY
Subcase information for explicit analysis
ERP
Control equivalent radiated power output.
FORMAT
GRID
OPTION
ESE
Controls the output of element strain energy results.
FORMAT
TYPE
DMIG
ESE_V1
FLUX
Controls the gradient and flux output for heat transfer analysis.
FORMAT
Controls the format of results output.
Formats are: H3D (default), HM, FLX, OPTI, OUTPUT2, PUNCH, PATRAN, APATRAN, NONE.
FOS
Requests fatigue factor of safety output for all fatigue subcases or individual fatigue subcases.
GPFORCE
Controls the output of grid point force results.
GPSTRAIN
The GPSTRAIN command can be used in the I/O Options or Subcase Information sections to request grid point strain output for all or individual subcases.
FORMAT, AVERAGING, TYPE, OPTION
GPSTRESS
Controls the output of grid point stress results (available for PSOLID components only).
HISOUT
Controls the contents of the .hgdata file.
INFILE
When using the two-file setup, INFILE indicates the prefix of the file containing the bulk data information.
Its extension must be .fem.
LIFE
Controls the output of fatigue life results.
LOADLIB
Defines the libraries to be loaded for external responses (DRESP3).
MBFORCE
Requests force output for a set of joints and/or force elements from multi-body dynamics subcases.
MODALDE
Requests modal damping energy (the energy loss per cycle) output for all subcases or individual subcases, respectively.
MODALKE
Requests modal kinetic energy output for all subcases or individual subcases, respectively.
MODALSE
Requests modal strain energy output for all subcases or individual subcases, respectively.
MODEL
Requests output for all formats for only a subset of the model and results.
This option is intended for multi-body dynamics and transient solution sequences with which users often require results for only a subsection of a model, but it is applied to all solution sequences.
MPCFORCES
Controls the output of MPC force results.
MSGLMT
Can be used in the I/O Options section to limit the number of ERROR, WARNING and INFORMATION messages output, or to elevate a WARNING or INFORMATION message to an ERROR.
TYPE (ERROR, WARNING)
VALUE (OFF, NONE)
TYPE_ID
VALUE_INT
NLLOAD
Requests nonlinear load output for Transient Response Analysis for each time step for all subcases or individual subcases, respectively.
OFREQUENCY
Defines a set of frequencies at which results are output for frequency response analysis.
OLOAD
Controls the output of applied force results.
OTIME
Defines a set of times at which results are output for transient analysis.
OUTFILE
Defines the path to, and the prefix of, the results files output by OptiStruct.
OUTPUT
Controls the frequency and format of results output by OptiStruct.
PARAM
Defines OptiStruct run parameters.
The following PARAM arguments are supported: ALPHA1, ALPHA2, ALPHAFL1, ALPHAFL2, AMLSMEM
CHKELSET
MBDREC
OP2GM34
RBE2FREE
RBE3FREE
RENUMOK
SHELOS11
STRTHR
THCNTPEN
UCORD
WRH
FASTCONT
CURVSHL2 FLLWER
If an unsupported argument is encountered on importing a PARAM card, the data is stored as UNSUPPORTED_PARAMS on the PARAM card.  It is also possible to create an unsupported PARAM card using the UNSUPPORTED_PARAMS option.
PEAKOUT
Can be used in the Subcase Information section to select the criteria for automatic identification of loading frequencies at which result peaks occur.
PFGRID
Can be used in the I/O Options section to request output of acoustic grid participation factors for all frequency response subcases.
GRIDS (SETG_SID)
GRIDF (SETFL_SID)
FREQUENCY (SETF_SID)
NULL
RPCUTOFF
PFMODE
Can be used in the I/O Options section to request output of modal participation factors for all frequency response subcases.
STRUCTURE (STRUCTMP, FREQUENCY, FILTER, NULL, RPCUTOFF)
FLUID (FLUIDMP, STRUCTMP, PANELMP, FREQUENCY, FILTER, NULL, RPCUTOFF)
PFPANEL
Can be used in the I/O Options section to request output of acoustic panel participation factors for all frequency response subcases.
PANEL
FILTER
NULL
RPCUTOFF
POWERFLOW
Requests output of the power flow field.
PRESSURE
Controls the output of pressure results.
PRETBOLT
Requests output of pretension force/adjustment values in the pretension bolts for all pretensioning and pretensioned subcases.
PROPERTY
Controls the output of the property definitions used in the last iteration of an optimization.
REQUEST
The REQUEST command can be used in the I/O Options or Subcase Information sections to select a multi-body request definition to be used in a multi-body problem.
RESPRINT
Controls the output of unretained optimization constraints.
RESTART
Flag that indicates that a restart run is to be performed.  Also indicates the prefix of the .sh file to be used as the starting iteration for the restart.
RESULTS
Controls the frequency of output of analytical results during an optimization.
SACCELERATION
Controls the form and type of modal participation acceleration output during an analysis.
Found under GLOBAL_OUPUT_REQUEST.  Supported as an output option on the subcase definition when it appears within a subcase.  (Use the edit button in the Loadsteps panel.)
SCREEN
Controls the information echoed to the screen during a run.
SDISPLACEMENT
Controls the form and type of modal participation displacement output during an analysis
SENSITIVITY
Controls the output of responses and sensitivities for size and shape design variables to a Microsoft Excel spreadsheet.
SENSOUT
Controls the frequency of output of responses and sensitivities to a Microsoft Excel spreadsheet.
SHAPE
Controls the output of shape optimization results from a shape, topography or free-shape optimization.
SHRES
Controls the frequency of output of the state files (.sh and .grid).
SINTENS
Requests Sound Intensity output for all frequency response subcases.
SPCFORCES
Controls the output of single-point force of constraint results.
SPL
Requests Sound Pressure output for all subcases or individual subcases, respectively.
SPOWER
Requests Sound Power output for all subcases or individual subcases, respectively.
STRAIN
Controls the output of elemental strain results.
STRESS
Controls the output of elemental stress results.
SORTING (SORT1, SORT2)
FORMAT (HM, H3D, OPTI, PUNCH, OUTPUT2, PATRAN, APATRAN)
FORM (COMPLEX, REAL, IMAG, PHASE, BOTH)
TYPE (ALL, VON, PRINC, MAXS, SHEAR, TENSOR, DIRECT)
LOCATION (CENTER, CUBIC, SGAGE, CORNER, BILIN)
RANDOM (PSDF)
STRESS_OPT (YES, NONE, NO, ALL, SID, PSID)
SUBTITLE
Defines a default subtitle for an OptiStruct model.
Individual subcases may have their own SUBTITLE definitions which are supported on the subcase definition (use the edit button in the Loadsteps panel).  These will override the default subtitle.
SVELOCITY
Controls the form and type of modal participation displacement output during an analysis,
SYSSETTING
Run control
OS_RAM
OS_RAM_INIT
CARDLENGTH
RAM_SAFETY
RAMDISK
SYNTAX
SPSYNTAX
LOADTEMP
NPROC_CPU
PLOTELID
SCRFMODE
THERMAL
Controls the temperature output for heat transfer analysis.
THICKNESS
Controls the output of thickness results from topology, free-size, or size optimization.
THIN
Can be used in the I/O Options or Subcase Information sections to request thinning and thickness output for all geometric nonlinear analysis subcases or individual geometric nonlinear analysis subcases respectively.
TITLE
Defines a title for an OptiStruct model.
TMPDIR
Defines a temporary directory where scratch files will be written.
OptiStruct allows multiple TMPDIR entries, but only one instance is currently supported.
UNITS
Defines a system of units for the model.
VELOCITY
Controls the output of velocity results.
XSHLPRM
Defines default shell element parameters for geometric nonlinear analysis.
XSOLPRM
Defines default SOLID properties for geometric nonlinear analysis.
The following Global Matrix Selectors are supported as control cards:
Solver Description
Notes
B2GG
Identifies a DMIG OptiStruct entry as a viscous damping matrix.
K2GG
Identifies a DMIG OptiStruct entry as a stiffness matrix.
K2PP
Can be used in the Subcase Information section to select a direct input stiffness matrix, which is not included in normal modes.
number_of_k2pps
K42GG
Identifies a DMIG OptiStruct entry as a structural element damping matrix.
M2GG
Identifies a DMIG OptiStruct entry as a mass matrix.
P2G
Identifies a DMIG OptiStruct entry as a load matrix.
Other OptiStruct cards supported as control cards:
Supported Cards
Solver Description
Notes
ACMODL
Defines the fluid-structure interface parameters.
INTER
INFOR
FSET
SSET
NORMAL
SHNEPS
DSKNEPS
INTO
SRCHUNIT
MAXSGRID
CONTPRM
Defines the default properties of all contacts
STATIC_CONTACT (CONTGAP, GPAD, MU1, MU2, STIFF)
SLIDE_EXPLICIT (BMULT, C1 - C6, FDAMP, FGAP, FILT, FRIC, FRICPEN, GAPMAX, GAPMIN, IBC, IDEL, IGAP, IFFILT, IFRIC, ISTF, SDAMP, STFAC, STMAX, STMIN, TEND, TSTART)
TIED_EXPLICIT (DS, IDEL2)
UNSUPPORTED_CONTPRMS
DESVARG
Defines an override for design variable settings.
DTI_UNITS
Defines units for multi-body dynamics and component mode synthesis solution sequences.
GRDSET
Defines defaults for fields 3, 7, and 8 on all GRID entries.
GAPPRM
Defines parameters for gap element connectivity and configuration.
The following GAPPRM arguments are supported: CHKRUN, CKGPDIR, GAPCMPL, GAPGPRJ, HMGAPST, PRTSW, ERRMSG.
PARAM
The following PARAM arguments are supported: ACMODL12, ALPHA1, ALPHA2, ALPHAFL1, ALPHAFL2,  AMLSASPC, AMLSMAXR, AMLSUCON, AMLS, AMLSNCPU, AUTOMSET, AUTOSPC, AUTOSPC2, AUTOSPRT, BUSHRLMT, BUSHTLMT, BUSHSTIF, CB2, CHECKEL, CHKGPDIR, CHECKMAT, CK2, CM2, CMFTINIT, CMFTSTEP, CMSDIRM, CMSOFST, CNTNLSUB, COEFFC, COUPMASS, CP2, CSTEVAL, DISIFMCK, DFREQ, DUPTOL, EFFMAS, EHD, ELASRLMT, ELASSTIF, ELASTLMT, EXCOUT, EXPERTNL, EXTOUT, FLEXH3D, FLIPOK, FRIC, FZERO, G, GAPOFFSET,  GMAR, GMAR1, GYROAVG, HASHASSM, HFREQFL, INREL, INRGAP, ITAPE, KDAMP, KGRGD, LFREQFL, LMSOUT, MAXDAMP, MBDH3D, MEMTRIM,MODETRAK, NEGMASS, NPRBAR, NPRBE2, NPRGDE,  OGEOM, OMACHRP, OMID, PLIGEXT, POST, POSTEXT, PRESUBNL, PRGPST, REANAL, RBMEIG, RSPLICOR, SEP1XOVR, SEPLOT, SH4NRP, SIMPACK, SMDISP, SORTCON, SRCOMPS, SS2GC4, TOLRSC, TPS, UNSYMSLV, W3, W4, WTMASS, WR3, WR4.
SWLDPRM
Defines parameters for CWELD connectivity search.
The following SWLDPRM arguments are supported: CHKRUN, GSPROJ, PROJTOL, PRTSW, ERRMSG.
Other control cards for the OptiStruct interface:
Supported Cards
Solver Description
Notes
BULK_UNSUPPORTED_
CARDS
If a line (not a continuation line) occurs after the BEGIN BULK statement in an input file and starts with a keyword that is not recognized or supported, then the entire card gets written to BULK_UNSUPPORTED_CARDS.
It is also possible to manually define an unsupported OptiStruct card using the BULK_UNSUPPORTED_CARDS.
BULK_UNSUPPORTED_CARDS are exported near the bottom of the exported OptiStruct input file, just before the ENDDATA statement.
CTRL_UNSUPPORTED_
CARDS
If a line (not a continuation line) occurs before the BEGIN BULK statement and before the first SUBCASE statement and starts with a keyword that is not recognized or supported, then the entire card gets written to CTRL_UNSUPPORTED_CARDS.
It is also possible to manually define data cards appearing above the first SUBCASE statement using the CTRL_UNSUPPORTED_CARDS.
CTRL_UNSUPPORTED_CARDS are exported near the top of the exported OptiStruct input file, just before the first SUBCASE statement.
DEBUG
Some special or custom features can be accessed through the use of 'debug, <string>, <real>' statements.
GLOBAL_CASE_CONTROL
Handles the data selectors FREQ, METHOD, MPC, SDAMPING and SPC appearing above the first SUBCASE statement.
It also handles the data selector DESVAR, used to select a set of design variables for use in an optimization run.
It also handles the output control OMODES, used to define a set of modes for output requests.
ANALYSIS, CMETHOD, CMSMETH, CNTNLSUB, DEFORM, DESVAR, DLOAD, FATDEF, FATPARM, FATSEQ, FREQ, IC, INVEL, LOAD, MBSIM, METHOD_FLUID, METHOD_STRUCT, MLOAD, MOTION, MPC, NLOAD, NLPARM, OMODES, RANDOM, RWALL, RWALADD, SDAMPING_FLUID, SDAMPING_STRUCT, SPC, STATSUB, SUPORT1, TEMP, TEMP_LOAD, TSTEP, XHIST, XHISADD
This control card  OMODES is also supported as an output option on the subcase definition when it appears within a subcase.  (Use the edit button in the Loadsteps panel.)
INCLUDE_BULK
This control card is retained to support old database files.
INCLUDE_CTRL
Model Documentation
$HMBEGINDOC and $HMENDDOC indicate a section of comment cards which are supported on import and export.  The comments are stored on control card Model Documentation.
This information is exported at the top of the exported OptiStruct input file.
OSDIAG
Some special diagnostic information can be processed through the use of 'osdiag, <integer>, <integer>, <real>, <real>' statements.
hmtoggle_arrow1Abaqus
Control cards define model information, which needs to be specified only once in the input file.  The following Abaqus keywords are supported as control cards:
Supported Card
Solver Description
Notes
*CONSTRAINT CONTROLS
Reset overconstraint checking controls
NO CHECKS
NO CHANGES
DELETE SLAVE
*DEPVAR
Specify solution-dependent state variables
svcount
*HEADING
Print a heading on the output
Title
MultipleLines
*PREPRINT
Select printout for the analysis input file processor.
CONTACT
ECHO
HISTORY
MASS PROPERTY
MODEL
*RESTART
Save and reuse data and analysis results
READ
WRITE
STEP
INC
END STEP
FREQUENCY
OVERLAY
hmtoggle_arrow1ANSYS
The input translator recognizes the ANSYS cards listed below. If an unsupported field is found in a card, a message is displayed on the status bar. The messages are also printed to the file ansys.msg. General slash commands, SOLUTION commands, POST1 commands, and POST26 commands are referred to as control cards. Unrecognized cards are written to a *.hmx file.
Supported Card
Solver Description
Notes
ACEL
Specifies the linear acceleration of the structure.
ACELX, ACELY, ACELZ
ALPHAD
Defines the mass matrix multiplier for damping.
Value
ANTYPE
Specifies the analysis type and restart status.
Type (STATIC, BUCKLE, MODAL, HARMIC, TRANS, SUBSTR, SPECTR)
Status (NEW, REST)
LDSTEP, SUBSTEP
ANTYPE_Action (CONTINUE, ENDSTEP, RSTCREATE, PERTURB)
ARCLEN
Activates the arc length method.
Key (OFF/ON), MAXARC, MINARC
ARCTRM
Controls termination of the arc-length solution
Lab (OFF, L, U), VAL,
NODE, DOF (UX, UY, UZ, ROTX, ROTY, ROTZ)
/ASSIGN
Reassigns a file name to an ANSYS file identifier.
ldent
Fname
AUTOTS
Specifies whether to use automatic time stepping or load stepping.
Key (off/on)
/BATCH
Sets the program mode to "batch"
List
BETAD
Defines the stiffness matrix multiplier for damping.
Value
BFUNIF
Assigns a uniform body force load to all nodes.
Lab, Value
BUCOPT
Specifies buckling analysis options
METHOD, NMODE, SHIFT, LDMULTE, RangeKey
CGLOC
Specifies the origin location of the acceleration coordinate system.
XLOC, YLOC, ZLOC
CGOMGA
Specifies the rotational velocity of the global origin.
CGOMX, CGOMY, CGOMZ
CMDOMEGA
Specifies the rotational acceleration of an element component about a user-defined rotational axis.
CM_NAME, DOMEGAX, DOMEGAY, DOMEGAZ, X1, Y1, Z1, X2, Y2, Z2
CMOMEGA
Specifies the rotational velocity of an element component about a user-defined rotational axis.
CM_NAME, DOMEGAX, DOMEGAY, DOMEGAZ, X1, Y1, Z1, X2, Y2, Z2, KSPIN
CNVTOL
Sets convergence values for nonlinear analyses.
Lab, VALUE, TOLER,
NORM, MINREF
/COM
Places a comment in the output.
n/a
/COPY
Copies a file.
Fname1, Ext1, Fname2, Ext2, DistKey
CRPLIM
Specifies the creep criterion for automatic time stepping.
CRCR, Option
DCGOMG
Specifies the rotational acceleration of the global origin.
DCGOX, DCGOY, DCGOZ
/DELETE
Deletes a file.
Fname1, Ext1, DistKey
DELTIM
Specifies the time step sizes to be used for this load step.
DTIME, DTMIN, DTMAX Carry
DMPRAT
Sets a constant damping ratio.
RATIO
DOF
Adds degrees of freedom to the current DOF set.
LAB1 - LAB10
DOMEGA
Specifies the rotational acceleration of the structure.
DOMGX, DOMGY, DOMGZ
EMUNIT
Specifies the system of units for magnetic field problems.
LAB, VAL
EQSLV
Specifies the type of equation solver.
Lab, TOLER, MULT
ERESX
Specifies extrapoloation of integration point results.
Key
EORIENT
Reorient SOLID elements' axes
ETYPE, Dir, Tol
ETABLE
Fills a table of element values for further processing.
LAB, ITEM, COMP
OPTION (AVG, MIN, MAX)
EXPASS
Specifies an expansion pass of an analysis.
Key
HARFRQ
Defines the frequency range in the harmonic response analysis.
FREQB, FREQE, LogOpt
HREXP
Specifies the phase angle for the harmonic analysis expansion pass.
ANGLE
HROPT
Specifies harmonic analysis options.
Method, MAXMODE, MINMODE, MCout, Damp
HROUT
Specifies the harmonic analysis output options.
REIMKY, CLUST, MCONT
IRLF
Specifies that inertia relief calculations are to be performed.
Key
KBC
Specifies stepped or ramped loading within a load step.
Key
KUSE
Specifies whether or not to reuse the triangularized matrix.
Key
LNSRCH
Activates a line search to be used with Newton-Raphson.
Key
LSSOLVE
Reads and solves multiple load steps.
LSMIN, LSMAX, LSINC
LVSCALE
Scales the load vector for mode superposition analyses.
FACT, LDSTEP
MDAMP
Defines the damping ratios as a function of mode.
STLOC, V1, V2, V3, V4, V5, V6
MODE
Specifies the harmonic loading term for this load step.
MODE
MODOPT
Specifies modal analysis options.
Method, nmode, freqb, freqe, nrmkey, ModType, BlockSize, Scalekey
MXPAND
Specifies the number of modes to expand and write for a modal or buckling analysis.
NMODE, FREQB, FREQE, Ecalc, SIGNIF, MSUPkey, ModeSelMethod
NCNV
Sets the key to terminate an analysis.
KSTOP, DLIM, ITLIM,
ETLIM, CPLIM
NEQIT
Specifies the maximum number of equilibrium iterations for nonlinear analyses.
NEQIT
FORCEkey (OFF, FORCE)
NLGEOM
Includes large-deflection effects in a static or full transient analysis.
Key
NROPT
Specifies the Newton-Raphson options in a static or full transient analysis.
OPTION1, OPTION2, CRLIMIT
NSUBST
Specifies the number of substeps to be taken this load step.
NSBSTP, NSBMAX, NSBMIN, Carry
NUMOFF
LABEL, VALUE
OMEGA
Specifies the rotational velocity of the structure.
OMEGX, OMEGY, OMEGZ, KSPIN
OUTRES
Controls the solution data written to the database.
Item, FREQ, Cname, NSVAR
/POST1
Enters the database results post-processor.
n/a
PRED
Activates a predictor in a nonlinear analysis.
Sskey, Lskey
PRESOL
Prints the solution results for elements.
Item, COMP
PSTRES
Specifies whether prestress effects are calculated or included.
Key
RSYS
Activates a coordinate system for printout or display of results.
KCN
SLOAD
Loads a pretension section.
SECID, PLNLAB, KINIT, KFD, FDVALUE, LSLOAD, LSLOCK
/SOLU
Enters the solution processor.
n/a
SOLU
Specifies solution summary data per substep to be stored.
NVAR, ITEMLABEL, COMPLABEL, SOLUNAME
SOLVE
Starts a solution.
n/a
SSTIF
Activates stress stiffness effects in a nonlinear analysis.
Key
/STITLE
Defines subtitles.
NLINE
TITLE
SUBOPT
Specifies options for subspace iteration eigenvalue extraction.
SUBSIZ, NPAD, NPERBK, NUMSSI, NSHIFT, Strmck, JCGITR
/SYS
Passes a command string to the operating system.
String
TIME
Sets the time for a load step.
Time
TIMINT
Turns on transient effects.
Key, Lab
TINTP
Defines transient integration parameters.
GAMMA, ALPHA, DELTA, THETA, OSLM, TOL, --, --, AVSMOOTH, ALPHAF, ALPHAM
/TITLE
Defines a main title.
Title_string
TOFFST
Specifies the temperature offset from absolute zero to zero.
Value
TOTAL
Specifies automatic MDOF generation.
NTOT, NRMDF
TREF
Defines the reference temperature for the thermal strain calculations.
TREF
TRNOPT
Specifies transient analysis options.
Method, MAXMODE, Dmpkey, MINMODE, MCout, TINTOPT
TUNIF
Assigns a uniform temperature to all nodes.
TEMP
/UNITS
Annotates the database with the system of units used.
Label, LENFACT, MASSFACT, TIMEFACT, TEMPFACT, TOFFSET, CHARGEFACT, FORCEFACT, HEATFACT
UNSU_END
UNSU_PREP7
hmtoggle_arrow1LS-DYNA
*DATABASE_OPTION cards in Keyword are listed from the Setup drop down menu, after selecting Control Cards. An active field is output as the appropriate individual card in the data deck.
A control card can be in one of three states:
State
Color
Explanation
Undefined
Gray
The control card was either never created or was deleted.
Defined  (See Note)
Green
Any control card viewed in the card previewer is activated.
Inactive
Red
A card that has been defined may be disabled.  The attributes for that card remain; however, the control card is not output.
Note:Those control cards that are defined (green in the control card editor) are output.
Default values for attributes are common throughout the card previewer.  A default value field has one of the following states:
State
Default = ON
In this state, the field label color is yellow and no data entry is allowed.
Default = OVERRIDDEN
To override a default value field, pick the yellow field label.  When you override a default value field, the label text color changes to cyan and you can enter data in the field.
The following keywords are supported:
Supported Card
Solver Description
Notes
*CONTROL_ACCURACY
Define control parameters that can improve the accuracy of the calculation.
OSU, INN, PIDOSU
*CONTROL_ADAPSTEP
Define control parameters for contact interface force update during each adaptive cycle.
FACTIN, DFACTR
*CONTROL_ADAPTIVE
Activate adaptive meshing.
ADPFREQ, ADPTOL, ADPOPT, MAXLVL, TBIRTH, TDEATH, LCADP, IOFLAG, AdaptiveOptions
*CONTROL_ADAPTIVE_
CURVE
To refine the element mesh along a curve.
IDSET, N, SMIN, ITRIOPT
ITYPE (PartSetID, PartID),
*CONTROL_ALE
Set global control parameters for the Arbitrary Lagrange-Eulerian and Eulerian calculations.
DCT, NADV, METH, AFAC - EFAC, START, END, AAFAC, VFACT, PRIT, EBC, PREF, NSIDEBC
*CONTROL_BULK_
VISCOSITY
Reset the default values of the bulk viscosity coefficients globally.
Q1, Q2, TYPE, BTYPE
*CONTROL_CHECK
Check for various problems in the mesh.
PID, IFAUTO, CONVEX, ADPT, ARATIO, ANGLE, SMIN, Shell
*CONTROL_COARSEN
Adaptively de-refine (coarsen) a shell mesh by selectively merging four adjacent elements into one.
ICOARSE, ANGLE, NSEED, PSID, SMAX
*CONTROL_CONTACT
Change defaults for computation with contact surfaces.
SLSFAC, RWPNAL, ISLCHK, SHLTHK, PENOPT, THKCHG, ORIEN, ENMASS, USRSTR, USRRFC, NSBCS, INTERM, XPENE, SSTHK, ECDT, TIEDPRJ
*CONTROL_COUPLING
Change defaults for MADYMO3D/CAL3D coupling.
UNLENG, UNTIME, UNFORC, TIMIDL, FLIPX - FLIPZ, SUBCYL
*CONTROL_CPM
Global control parameters for CPM (Corpuscular Particle Method).
CPMOUT
*CONTROL_CPU
Control CPU time.
CPUTIM, IGLST
*CONTROL_DYNAMIC_
RELAXATION
Initialize stresses and deformation in a model to simulate a preload.
NRCYCK, DRTOL, DRFCTR, DRTERM, TSSFDR, IRELAL, EDTTL, IRDFLG
*CONTROL_EFG
Define controls for the mesh-free computation.
ISPLINE, IDILA, ININT, IMLM, ETOL, IDEB, HSORT, SSORT
*CONTROL_ENERGY
Provide controls for energy dissipation options
HGEN, RWEN, SLNTEN, RYLEN
*CONTROL_EXPLOSIVE_
SHADOW
Compute detonation times in explosive elements for which there is no direct line of sight.
n/a
*CONTROL_HOURGLASS
Set the default values of the hourglass control to override the default values.
IHQ, QH
*CONTROL_IMPLICIT_
AUTO
Define parameters for automatic time step control during implicit analysis.
IAUTO, ITEOPT, ITEWIN, DTMIN, DTMAX, DTEXP, KFAIL, KCYCLE
IAUTO_Option
DTMAX_Option
DTEXP_Option
*CONTROL_IMPLICIT_
BUCKLE
Activate implicit buckling analysis when termination time is reached.
NMODE
*CONTROL_IMPLICIT_
DYNAMICS
Activate implicit dynamic analysis and define time integration constants.
IMASS, GAMMA, BETA, TDYBIR, TDYDTH, TDYBUR, IRATE
*CONTROL_IMPLICIT_
EIGENVALUE
Activate implicit eigenvalue analysis and define associated input parameters.
NEIG, CENTER, LFLAG, RFLAG, EIGMTH, SHFSCL
NEIG_Option
OptionalCard2
*CONTROL_IMPLICIT_
FORMING
Activate implicit static analysis, primarily for metal forming processes.
IOPTION, NSMIN, NSMAX, BIRTH, DEATH, PENCHK
*CONTROL_IMPLICIT_
GENERAL
Activate implicit analysis and define associated control parameters.
IMFLAG, DT0, IMFORM, NSBS, IGS, CNSTN, FORM, ZERO_V, IMFLAG_Option
*CONTROL_IMPLICIT_
INERTIA_RELIEF
Allows analysis of linear static problems that have rigid body modes.
IRFLAG
THRESH
*CONTROL_IMPLICIT_
MODES
Request calculation of constraint and/or attachment modes for later use in modal analysis using *PART_MODES.
NSIDC
NSIDA
*CONTROL_IMPLICIT_
SOLUTION
Optional card that applies to implicit calculations.Used to specify whether a linear or nonlinear solution is desired.
NSOLVR, ILIMIT, MAXREF, DCTOL, ECTOL, RCTOL, LSTOL, ABSTOL
*CONTROL_IMPLICIT_
SOLVER
Optional card that applies to implicit calculations. The linear equation solver performs the CPU-intensive stiffness matrix inversion.
LSOLVR, LPRINT, NEGEV, ORDER, DRCM, DRCPRM, AUTOSPC, AUTOTOL
*CONTROL_IMPLICIT_
STABILIZATION
Optional card that applies to implicit calculations. Artificial stabilization is required for multi-step unloading in implicit springback analysis.
IAS, SCALE, TSTART, TEND, SCALE_Option
*CONTROL_IMPLICIT_
TERMINATION
Specify termination criteria for implicit transient simulations.
DELTAU, DELTA1, KETOL, IETOL, TETOL, NSTEP
*CONTROL_MPP_
DECOMPOSITION_
AUTOMATIC
Instructs the program to apply a simple heuristic to try to determine the proper decomposition for the simulation.
n/a
*CONTROL_MPP_
DECOMPOSITION_CHECK
_SPEED
Modifies the decomposition depending on the relative speed of the processors involved.
n/a
*CONTROL_MPP_
DECOMPOSITION_
CONTACT_DISTRIBUTE
Ensures that the indicated contact interfaces are distributed across all processors, which can lead to better load balance for large contact interfaces.
ID1 - ID5
*CONTROL_MPP_
DECOMPOSITION_
CONTACT_ISOLATE
Ensures that the indicated contact interferences are isolated on a single processor, which can lead to decreased communication.
ID1 - ID5
*CONTROL_MPP_
DECOMPOSITION_FILE
Allow for pre-decomposition and a subsequent run or runs without having to do the decomposition.
Name
*CONTROL_MPP_
DECOMPOSITION_
METHOD
Specify the decomposition method to use.
Name
*CONTROL_MPP_
DECOMPOSITION_
NUMPROC
Specify the number of processors for decomposition.
N
*CONTROL_MPP_
DECOMPOSITION_SHOW
Allows display of the final decomposition.
n/a
*CONTROL_MPP_
DECOMPOSITION_
TRANSFORMATION
Specifies transformations to apply to modify the decomposition.
TYPE(1)
VAL(1)
*CONTROL_MPP_IO_LSTC_REDUCE
Controls the decomposition of the model for solving in multiple CPU's.
n/a
*CONTROL_MPP_IO_
NOD3DUMP
Suppress the output of all dump files.
n/a
*CONTROL_MPP_IO_
NODUMP
Suppresses the output of all dump files and full deck restart files.
n/a
*CONTROL_MPP_IO_
NOFULL
Suppresses the output of the full deck restart files.
n/a
*CONTROL_MPP_IO_
SWAPBYTES
Swap bytes on some of the output files.
n/a
*CONTROL_OUTPUT
Set miscellaneous output parameters.
NPOPT, NEECHO,
NREFUP, IACCOP, OPIFS, IPNINT, IKEDIT, IFLUSH
*CONTROL_PARALLEL
Control parallel processing usage for shared memory computers by defining the number of processors invoking the optional consistency of the global vector assembly.
NCPU, NUMRHS, CONST, PARA
*CONTROL_REMESHING
Provide control over the remeshing of solids which are meshed with the solid tetrahedron element type 13.
RMIN, RMAX, VF_LOSS, MFRAC, DT_MIN
*CONTROL_RIGID
Special control options related to rigid bodies and the rigid-flexible bodies.
LMF, JNTF, ORTHMD, PARTM, SPARSE, METALF
*CONTROL_SHELL
Provide controls for computing shell response.
WRPANG, ESORT, IRNXX, ISTUPD, THEORY, BWC, MITER, PROJ
*CONTROL_SOLID
Provide controls for solid element response.
ESORT, FMATRIX, NIPTETS, SWLOCL
*CONTROL_SOLUTION
Specify the analysis solution procedure if thermal only or coupled thermal analysis is performed.
SOLN, NLQ, ISNAN, LCINT
*CONTROL_SPH
Provide controls for computing SPH particles.
NCBS, BOXID, DT, IDIM, MEMORY, FORM, START, MAXV, CONT, DERIV, INI, ISHOW, IEROD, ICONT, IAVIS
*CONTROL_SPOTWELD_
BEAM
Provides factors for scaling the failure force resultants of beam spot welds as a function of their parametric location on the contact segment and the size of the segment.
LCT, LCS, T_ORT, PRTFLG, T_ORS, RPBHX
*CONTROL_STRUCTURED
Write out a LS-DYNA structured input deck for version 970.
n/a
*CONTROL_STRUCTURED
_TERM
Write out a LS-DYNA structured input deck for version 970. Termination will occur after the structured input file is written.
n/a
*CONTROL_SUBCYCLE
Control time step subcycling.
n/a
*CONTROL_TERMINATION
Stop the job.
ENDTIM, ENDCYC, DTMIN, ENDENG, ENDMASS
*CONTROL_THERMAL_
NONLINEAR
Set parameters for a nonlinear thermal or coupled structural/thermal analysis.
REFMAX, TOL, DCP, LUMPBC, THLSTL,
NLTHPR, PHCHPN
*CONTROL_THERMAL_
SOLVER
Set options for the thermal solution in a thermal only or coupled structural-thermal analysis.
ATYPE, PTYPE, SOLVER, CGTOL, GPT, EQHEAT, FWORK, SBC
*CONTROL_THERMAL_
TIMESTEP
Set time step controls for the thermal solution in a thermal only or a coupled structural/thermal analysis.
TS, TIP, ITS, TMIN, TMAX, DTEMP, TSCP, LCTS
*CONTROL_TIMESTEP
Set structural time step size control using different options.
DTINIT, TSSFAC, ISDO, TSLIMIT, DT2MS, LCTM, ERODE, MS1ST
*DAMPING_FREQUENCY_
RANGE
Provides approximately constant damping over a range of frequencies.
CDAMP, FLOW, FHIGH, PSID
*DAMPING_GLOBAL
Define mass weighted nodal damping that applies globally to the nodes of deformable bodies and to the mass center of rigid bodies.
LCID, VALDMP, STX - STZ, SRX - SRZ
*DATABASE_ABSTAT
Specify time interval and file type for Airbag statistics time history file output.
*DATABASE_AVSFLT
Specify time interval for AVS database output.
*DATABASE_BINARY_D3PART
Dt for partial output states.
DT, LCDT, BEAM, NPLTC, PSETID
*DATABASE_BINARY_
D3PLOT
Dt for complete output states.
DT, LCDT, NOBEAM, NPLTC, PSETID, IOOPT
*DATABASE_BINARY_
D3DRLF
Dynamic relaxation database.
CYCLE
*DATABASE_BINARY_
D3THDT
Dt for time history data of element subsets.
DT, LCDT
*DATABASE_BINARY_
D3DUMP
Binary output restart files. Define output frequency in cycles.
DT
*DATABASE_BINARY_
FSIFOR
ALE interface force database
*DATABASE_BINARY_
INTFOR
Dt for output of contact interface data.
DT, LCDT
*DATABASE_BINARY_
RUNRSF
Binary output restart file. Define output frequency in cycles.
DT
*DATABASE_BINARY_
XTFILE
Flag to specify output of extra time history data to XTFILE at same time as D3THDT file.
DT
*DATABASE_BNDOUT
Specify time interval and file type for Boundary condition forces and energy time history file output.
*DATABASE_DEFGEO
Specify time interval deformed geometry file output.
*DATABASE_DEFORC
Specify time interval and file type for discrete element forces time history file output.
*DATABASE_ELOUT
Specify time interval and file type for element data time history file output.
*DATABASE_EXTENT_AVS
Specify output database to be written.
VTYPE, COMP
*DATABASE_EXTENT_
BINARY
NEIPH, NEIPS, MAXINT, STRFLAG, SIGFLG, EPSFLG, RLTFLG, ENGFLG, CMPFLG, IEVERP, BEAMIP, DCOMP,SHGE, STSSZ, N3THDT, IALEMAT, NINTSLD, PKP_SEN, SCLP, MSSCL, THERM
*DATABASE_EXTENT_D3PART
Controls, to some extent, the content of specific output databases.
NEIPH, NEIPS, MAXINT, STRFLAG, SIGFLG, EPSFLG, RLTFLG, ENGFLG, IEVERP, SHGE, STSSZ, NINTSLD
*DATABASE_EXTENT_
MOVIE
VTYPE, COMP
*DATABASE_EXTENT_
MPGS
VTYPE, COMP
*DATABASE_EXTENT_
SSSTAT
PSID(1), ArrayCount
*DATABASE_FORMAT
IFORM, IBINARY
*DATABASE_GCEOUT
Specify time interval and file type for Geometric contact entities force time history file output
*DATABASE_GLSTAT
Specify time interval and file type for global model data time history file output.
*DATABASE_JNTFORC
Specify time interval and file type for joint force time history file output
*DATABASE_MASSOUT
Export nodal masses into ASCII file MASSOUT.
NDFLG, RBFLG
*DATABASE_MATSUM
Specify time interval and file type for material energies time history file output
*DATABASE_MOVIE
Specify time interval for movie output
*DATABASE_MPGS
Specify time interval for MPGS
*DATABASE_NCFORC
Specify time interval and file type for nodal interface forces time history file output
*DATABASE_NODFOR
Specify time interval and file type for nodal force groups time history file output
*DATABASE_NODOUT
Specify time interval and file type for nodal point data time history file output
*DATABASE_OPTION
Control cards for all ASCII output
ABSTAT, ABSTAT_CPM, AVSFLT, BNDOUT, DCFAIL, DEFGEO, DEFORC, ELOUT, GCEOUT, GLSTAT, JNTFORC, MATSUM, MOVIE, MPGS, NCFORC, NODFOR, NODOUT, RBDOUT, RCFORC, RWFORC, SBTOUT, SECFORC, SLEOUT, SPCFORC, SPHOUT, SSSTAT, SWFORC, TPRINT, TRHIST
*DATABASE_RBDOUT
Specify time interval and file type for rigid body data time history file output.
*DATABASE_RCFORC
Specify time interval and file type for resultant interface forces time history file output.
*DATABASE_RWFORC
Specify time interval and file type for rigid wall forces time history file output.
*DATABASE_SBTOUT
Specify time interval and file type for Seat belt time history file output.
*DATABASE_SECFORC
Specify time interval and file type for cross section forces time history file output
*DATABASE_SLEOUT
Specify time interval and file type for sliding interface energy time history file output
*DATABASE_SPCFORC
Specify time interval and file type for SPC reaction forces time history file output
*DATABASE_SPHOUT
Specify time interval and file type for SPH element data time history file output
*DATABASE_SPRING_
FORWARD
Create spring forward nodal force file.
IFLAG
*DATABASE_SSSTAT
Specify time interval and file type for Subsystem data time history file output
*DATABASE_
SUPERPLASTIC_
FORMING
Specify the output intervals to the superelastic forming output files.
DTOUT
*DATABASE_SWFORC
Specify time interval and file type for nodal constraint reaction forces time history file output
*DATABASE_TPRINT
Specify time interval and file type for thermal time history file output.
Thermal output from a coupled structural/thermal or thermal only analysis.
*DATABASE_TRACER
Tracer particles will save a history of either a material point or a spatial point into an ASCII file, TRHIST.
TIME, TRACK,  X, Y, Z
*DATABASE_TRHIST
Tracer particle history information
*INTERFACE_
COMPENSATION_NEW
Calculate the deviation of the part from its intended design of the stamped part and automatically compensate the tool to minimize the deviation, modify the trimming curve after the die modification, and automatically detect the undercut problem
METHOD, SL, SF, ELREF, PSIDm, UNDCT
*STRESS_INITIALIZATION
Allows all or selected parts to be initialized on restart, using data from the d3dump or runrsf database.
PIDO, PIDN
*STRESS_INITIALIZATION_DISCRETE
Initializes all discrete parts from the old parts.
*STRESS_INITIALIZATION_SEATBELT
Initializes all seatbelt parts from the old parts.
hmtoggle_arrow1Nastran
Supported Card
Solver Description
Notes
ACMODL
Defines modeling parameters for the interface between the fluid and the structure.
INTER, INFOR, FSET, SSET, NORMAL, METHOD, SHNEPS, DSKNEPS, INTOL, ALLSSET, SRCHUNIT
AUTOSPC
Constrains stiffness singularities via m-sets or s-sets.
RESIDUAL, PRINT, NOPRINT, NOPUNCH, PUNCH-SID, EPS, EPSSING, SPC, MPC, ZERO, NOZERO
BEGIN BULK
Designates the end of the Case Control Section and/or the beginning of a Bulk Data Section.
n/a
When the model is created from Engineering Solutions, this card is on by default.
BULK-UNSUPPORTED_
CARD
n/a
On import, all unsupported bulk data will be written into this card.  You can edit the card.
CASE-UNSUPPORTED_
CARD
n/a
If CEND and SUBCASE exist, on import, all unsupported cards between CEND and the first SUBCASE will be written into this card.  You can edit the card.  If SUBCASE does not exist and BEGIN BULK exists, all unsupported cards between CEND and BEGIN BULK will be written into this card.
CEND
n/a
DIAG
Requests diagnostic output or special options.
DIAG
DIAGIDLEN
ECHO
Bulk Data Echo Request
SORT, EXCEPT, cdni, UNSORT, BOTH, NONE, PUNCH, FILE, NEWBULK
ENDDATA
Designates the end of the Bulk Data Section.
n/a
EXEC_UNSUPPORTED_
CARDS
n/a
If CEND exists in the imported deck, on import, all unsupported cards before CEND will be written into this card.  You can edit the card.  If CEND does not exist, on import, all unsupported cards before BEGIN BULK will be written into this card.
ERP
Equivalent Radiated Power Panel Participation Factor Output Request
SORTING, FORMAT, SOLUTION, KEY, FILTER, ERPRHO, ERPC, RHOCP, ERPRLF, CSV
FLSPOUT
Control for fluid-structure mode participation output.
FLUX
Request gradient and flux output for all heat transfer analysis subcases or individual heat transfer analysis subcases respectively.
FORMAT
OPTION (ALL, NONE, SETID)
GLOBAL CASE CONTROL
ANALYSIS, AUTOSPC, BOUTPUT, BCONTACT, CMETHOD, BCSET, BOLTLD, DEFORM, DLOAD, FREQ, IC, LOAD, LOADSET, METHOD_FLUID, METHOD_STRUCT, MPC, NLPARM, NLSTEP, NSM, RANDOM, SDAMPING_FLUID, SDAMPING_STRUCT, SPC, SUPORT1, TEMP, TEMP_LOAD, TRIM, TSTEP, TSTEPNL
GLOBAL OUTPUT REQUEST
ACCELERATION, DISPLACEMENT, EKE, ELFORCE, ESE, GPFORCE, GPSTRESS, MCFRACTION, MPCFORCES, NLSTRESS, OFREQ, OLOAD, OTIME, PARTN, SACCELERATION, SDISPLACEMENT, SPCFORCES, STRAIN, STRESS, SVECTOR, SVELOCITY, THERMAL, VELOCITY
GRDSET
Defines default options for fields 3, 7, 8, and 9 of all GRID entries
CP, CD, SEID, Single Point Constraint 1- 6
IC
ID
Specifies a comment.
l1, l2
INCLUDE_BULK
Inserts an external file into the input file
number of includes in bulk
INCLUDE_CTRL
number of includes in ctrl
INCLUDE_EXEC
number of includes in exec
K2PP
Selects direct input stiffness matrices, which are not included in normal modes
number of k2pps
MAXLINES
Sets the maximum number of output lines.
nmax
The maximum number of lines is 999999999 (Nastran default).
MONITOR_POINTS
Defines an integrated load monitor point.
MONPNT1, MONPNT2, MONPNT3
NLMOPTS
Specifies nonlinear material optional schemes in SOL 400. Extends to material options, property options including property mapping, boundary condition options.
CREEP, ASSM, TSHEAR, LRGSTRN, HEMICUBE, TEMPP, TEMGO, SPROPMAP, SPCRMPT, DEACTEL, ENTHALP, MAPTOL
OMIT_BEGIN_BULK
By selecting this control card, you are forcing HyperMesh to not write BEGIN BULK CARD
OMIT_CEND
By selecting this control card, you are forcing HyperMesh to not write the CEND card.
OMIT_END_BULK
By selecting this card, you are forcing HyperMesh to not write the END_BULK card.
PARAM
Specifies values for parameters.
ALPHA1, ALPHA2, AMLS, AMLSNCPU, ASING, AUTOSPC, AUTOSPRT, BAILOUT, COUPMASS, CURV, CURVPLOT, DDRMM, EPPRT, CLOSE
On import, all unsupported PARAM cards are written into the UNSUPPORTED PARAMS block within PARAM CARD in the Control Cards panel.  You can edit this data block.
PRESSURE
Pressure output request
All parameters
RADSET
Specifies which radiation cavities are to be included for radiation enclosure analysis.
RADSET_ICAVITY_NUM=
RESTART
Requests that data stored in a previous run be used in the current run.
PROJECT, VERSION, LOGICAL
RESVEC
Controls residual vectors
All parameters
RIGID
Rigid Element Method
LINEAR, LAGRAN, LGELIM
SET CARD
Defines a set of element or grid point numbers to be plotted.
setid, SET_realList
Only real number sets can be created using control cards.
For node and element sets, see Sets.
SOL
Specifies the solution sequence or main subDMAP to be executed.
Analysis (Statics, Normal Modes, Buckling, Nonlinear Statics, Dir. Complex Eigenvalues, Dir. Frequency Response, Dir. Transient Response, Model Complex Eigenvalues, Modal Frequency Response, Modal Transient Response, Nonlin. Transient Resp., Design Optimization, Statics & Lin. Heat Transfer, Implicit)
SUBTITLE
Defines a subtitle that will appear on the second heading line of each page of printer output.
n/a
SWLDPRM
Overrides default values of parameters for CFAST, CWELD, and CSEAM connectivity search.
GSMOVE, NREDIA
TIME
Sets the maximum CPU and I/O time.
MaxIO
TITLE
Defines a character string that will appear on the first heading line of each page of NX Nastran printer output.
n/a
TSTEPNL
Defines parameters for geometric nonlinear implicit dynamic analysis strategy.
ANALYSIS, AUTOSPC, BCONTACT, CMETHOD, BCSET, BOLTLD, DEFORM, DLOAD, FREQ, IC, LOAD, LOADSET, METHOD_FLUID, METHOD_STRUCT, MPC, NLPARM, NSM, RANDOM, SDAMPING_FLUID, SDAMPING_STRUCT, SPC, SUPORT1, TEMP, TEMP_LOAD, TRIM, TSTEP
hmtoggle_arrow1PAM-CRASH 2G
Supported Card
Solver Description
Notes
NA
Imported Model Documentation
n/a
The input deck can contain model documentation text that is imported and exported via the comment lines.  For decks not written by Engineering Solutions, all comment lines before the first non-comment line are treated as model documentation.  For decks written by Engineering Solutions, the documentation lines must be placed in a block that begins with the line $HMBEGINDOC and ends with the line $HMENDDOC.  The text can be created and changed using the card previewer. This card is always overwritten by the current model documentation.
NA
Model Documentation
n/a
This card is not created during FE input process. You can create this card, but once this card is defined, only this will be exported.  You can access macros from the PAM-CRASH 2G user profile to append or overwrite the information from Imported Model Documentation to this card.
AIRBAGCHECK
Airbag Check
Option (YES/NO)
Qualifier (VOLUME, ORIENT)
Added in PAM-CRASH 2004
ANALYSIS
Analysis
Analysis Selection (EXPLICIT, IMPLICIT_PCG)
AUTOSLEEP
Option (YES/NO)
CCTRL /
Contact Control Parameters
ITER_INIPEN_N
ITER_FORCE_N
ITER_FORCE_EPS
LEAKFILTER
This card contains all the information about the interfaces control parameters such as initial penetration.
COUPLING
Coupling
MADYMO, PAMFLOW
DATACHECK
Data Check
Yes/No
Execution (None, QUIT, STOP)
DEBUG
Debug
Yes/No
DCOMP
DMP Domain Decomposition
Type, Direction
ECTRL /
Element Control Parameters
ANTIDRILL, SPRINGBACK, STRAINRATE, RATEFILTER, RATESCALE, RATECURVE, KINJ, ENERMONT, MET3DLOAD
This card contains all the information about the element control parameters.
ENDDATA
End of Data
n/a
Cards after the ENDDATA card are ignored.
FILE
File Name
FILENAME
INCLU /
Include Cards
fileName
NUM_INCLUDES
INPUTVERSION
Input Version
n/a
MAXMEMORY
Max Memory
MAXMEMORY
MERGEGAP
Common Node Merge
tolerance
METRIC/
Initial Metric
metric, NUM_METRICS
METRICCHECK
Metric Check
Option (YES/NO)
Tolerance
OCTRL /
Output Control Parameters
THPOUTPUT INTERVAL TIOD
DSYOUTPUT INTERVAL PIOD
Output Parameters Selction (All, THOUTPUT, DSYOUTPUT, RSTOUTPUT, PRTOUTPUT, TOTAL_STRAIN, PRINT, PREFILTER, GLBTHP, SHLTHP, NODPLOT, SOLPLOT, SHLPLOT, BEAPLOT, MPPOUTPUT, RBODY_DISPLAY, FPM OUTPUT, SPHPLOT)
Thpoutput Qualifier (Interval, Point, Curve)
Dsyoutput Qualifier (Interval, State, Curve)
This card contains all the information about the output of data, such as PRINT, SHLTHP, THPOUTPUT, DSYOUTPUT, GLBTHP, BEAPLOT, etc.  In card previewer you have the option of defining all the parameters.
PIPE
Pipe
Yes/No
RESTARTFILES
Restart Files
NumberOfFiles
RUNEND/
End Of Run Definition
TIME
SENSOR_OPT
RWALL_KIN_CHECK
Option (YES/NO)
SHELLCHECK
Shell Check
Yes/No
Warpage, Aspect, QMinAngle, QMaxAngle, TMinAngle, TMaxAngle
SIGNAL
Signalling
Yes/No
SOLIDCHECK
Solid Check
Yes/No
Aspect, QMinFace, QMaxFace, TMinFace, TMaxFace
SOLID4N
Solid4N
YES/NO
This card must be defined in order to support 4-noded tetra elements by using SOLID / keyword in PAM-CRASH 2004.  Its value should be set to "YES".
SOLVER
Solver
CRASH, STAMP
SPCTRL /
KERNAL_OPT
NUMBER_NEIGHBORS_OPT
BUFFER_MULTIPLIERS_OPT
NN_ACCELERATOR_OPT
X_SYMMETRY_OPT
Y_SYMMETRY_OPT
Z_SYMMETRY_OPT
ARTVISC_TENSION_OPT
MOMENTUM_FORMALISM_OPT
DIMENSION_1D_OPT
DIMENSION_2D_OPT
SPH /
IDKERN, FACNEI, ISPHAC, LSPHAC, X, Y, Z, IOPSPH, IPBDIM, SECLA, FACBUF, IVSH
STOPRUN
Stop Run
ENERGY, CPULIMIT, TIMESTEP, CONTACT_DIVERGENCE
SUBRUN
Substructure Run
filename, TimeFactor, LengthFactor, FrameNumber
NUM_SUBRUNS
SUBTA /
Substructure Run Link Table
EQUIVALENCE, IDNEW, IDOLD
NUM_EQUIV_NODES
TCTRL /
Timestep Control Parameters
Timestep Parameters Selection (All, INITIAL, PREFER, SCALE, STIFFNESS_SCALE, INIT_MASS_SCALE, NODAL, DYNA_MASS_SCALE, SHELL_TIMESTEP)
This card contains all the information about the time step control parameters.
TITLE /
Title
TITLE
UNIT
Unit System
Length, Mass, Time, Temperature
Unsupported Cards
All unsupported information found in the input deck is imported in this card.  You can edit this card.
See Also:
Browsers
Entities & Solver Interfaces
Model Setup
